HJ 45 Drum Brakes
Submitted: Tuesday, Jun 17, 2008 at 19:45
Mudripper
Hi all. I'm having some problems with the braking system on my 1976 Landcruiser. Just to satisfy my curiosity, I performed this primitive
test in my paddock (under controlled conditions!). I applied the brakes hard so that they would lock up and skid. I did this a few times. I opened the door and looked out as I was doing this and noticed that only the front wheels lock up. I even applied the brakes with my left foot and the back wheels would still drive no probs. Just the front brakes work. I drained the (very) old brake fluid and bled the entire system and still the rear brakes don't work. I checked the wheel cylinders and they do operate. I also checked the brake pipes and all looks good. I'm suspecting the master cylinder. The pistons perhaps? I don't know. When I was bleeding the rear brakes, fluid would come out. It's good I have a tailshaft drum hand brake!
Any replies appreciated.
Reply By: Mikee5 (Logan QLD) - Wednesday, Jun 18, 2008 at 14:55
From memory the 76 model had two reservoirs on the master cylinder the big one was the front wheels and the small one fed the rears. Re-building this by replacing the rubbers and sanding out the
bore with emery paper will not cost much. Because the fluid was old it would be full of moisture causing internal rust everywhere. I reckon you should re-build the wheel cylinders as it doesn't cost much if you DIY. Cleaning out the crap and putting kits in them should cost about $20 per wheel for the rubbers, or you can buy new wheel cylinders from an after market
shop like Autobarn and they are quite cheap. Make sure you grease the adjuster threads and do not
puncture the covering rubbers when you put them back. I owned a 76 shorty then a 79 troopy and went to Fraser Island three or four times a year. This means I re-built my brakes many times as the salt got to them. Don't use the transmission brake to stop the vehicle, it is only bolted into the back of the aluminium transfer case with small bolts making it quite weak for this purpose, you can rip the back off the T/case.
310764
Reply By: Mudripper - Wednesday, Jun 18, 2008 at 18:44
Thanks all of you, a lot of great info.
Yes, I had to adjust the brakes and also I had to invert a wheel cylinder that was installed up side down on one side of the car. So I had an opportunity to inspect just that cylinder and it looked very good inside. It doesn't leak either. The brakes now work perfectly, with the front brakes locking up just before the rear do. I just wonder why that one cylinder was up side down. That means that only one shoe was being pushed towards the drum. Funny stuff. The cylinders on the other side were mounted correctly, one pointing upwards, one downwards. Anyway, it's all fixed and going good.
And no, I wasn't using the tailshaft brake to stop the vehicle!
Thanks guys.
310813
