wireless internet which one?????
Submitted: Tuesday, Jul 01, 2008 at 13:03
ThreadID: 59401 Views:3114 Replies:12 FollowUps:9
hi everyone,
can anyone tell me which one to go with
which has the best value?
all i want to do is check/send emails
start online blog that sort of stuff
will be using it on an 8 week trip
cheers everyone!
Reply By: Notso - Tuesday, Jul 01, 2008 at 13:10
If you want the best coverage it's Telstra. Depends where you are going, but an option that doesn't lock you in to a contract is to use your Next G Mobile phone and buy a data pack for it
Cheaper is Optus
AnswerID: 313250
Reply By: sepp5762 - Tuesday, Jul 01, 2008 at 13:16
I also use Telstra..best coverage, but still limited, so depends how romote you are going. You would need to join a plan for 24 months, which seems over the top for 8 weeks, enqires about a data pack for your nextG phone.
AnswerID: 313251
Follow Up By: archar - Tuesday, Jul 01, 2008 at 13:19
i will still use it at home as our home computer when i get back so a plan doent worry me!
and i dont have a next g phone!
cheers archar
FollowupID: 579282
Reply By: Dunco (NSW) - Tuesday, Jul 01, 2008 at 13:18
Depending on where you are going...but the only way to go is with Bigpond as they have the monopoly on the wireless broadband. The other carriers DO NOT have the coverage that Bigpond has. If you can get a signal on your phone, you can access the internet.
I just spent 5 weeks in the NT with NO access ot Optus, but access to Telstra.
Good luck with your choice
AnswerID: 313252
Reply By: Member - Graeme W (NSW) - Tuesday, Jul 01, 2008 at 13:44
Like it's been said above, Next G wireless will be the best coverage.
I had the Next G USB modem while travelling last year and you should get reception anywhere you have mobile phone coverage.
It really isn't good value though and I've got rid of it in favour of an ADSL connection for home and intend to use internet cafes etc when travelling in the future.
It was costing me about $75/month for a plan with a 1GB limit. This plan was also at a reduced speed. 3GB was about $115/month. I found performance was not as good as an ADSL connection either.
Plans could have changed, but wireless also has excess usage charges to consider.
For me, the cost downside outweighed the convenience of wireless internet. Of course in your case it might be worth it. Everyone's different after all.
Graeme
Lake Eyre 2011
AnswerID: 313260
Reply By: Member - Norm C (QLD) - Tuesday, Jul 01, 2008 at 14:31
Next G is certainly the way to go. It is the only one with reasonable coverage in the bush.
There are two options - Bigpond and Telstra.
As far as I know, Bigponds plans all need a modem and a conract (normally 2 years). They have plans based on usage and time (10 hours per month).
With Telstra, you have the option of a modem (under contract) or using your Next G phone as the modem on casual data packs (no contract).
We use our Samsung A 412 (or 411) phone connected direct to the laptop via the supplied data cable. We use the 1G data packs which cost $89 per month. 200MB costs $59 per month. No contract. Order the pack to be applied to your phone before you head off. Call Telstra and cancel it when you get back.
I'm currently in the NT on the McArthur River about 40KM from Borroloola (middle of nowhere). Works fine with the high gain antenna on top of a 20 ft sapling. People next to us have a modem card and can not get access. They have to drive to Borroloola for better signal strength to get on. I think the problem is that the antenna for the modem card is not good enough and they have not been able to get a better one that will connect.
If you won't use the mobile broadband all year, IMHO, the casual data packs are the way to go.
Norm C
AnswerID: 313267
Follow Up By: DesF - Tuesday, Jul 01, 2008 at 16:22
Hi, My mate has a Bigpond data pack, no contract, $30.00 for 50meg using his Nokia 6120 Next G as the modem and if you get a longer ( and dearer) package, you can put a hold on it,if you dont need it for a month or so they will shut it down until you notify them again, works good here and he is going QLD next month to give it a good try out,he checked with Telstra and you have to have a plan.
You can just ring them and they switch it on for you and it is charged to your phone bill.
Cheers Des.
FollowupID: 579326
Follow Up By: Member - colin J (VIC) - Tuesday, Jul 01, 2008 at 17:05
Hi Norm,
I have the same phone and data pack etc and have just purchased a high gain antenna. If the phone is connected to the laptop where does the antenna get connected to.
Sorry to annoy you up there, hope all's well
Regards from Big Col
FollowupID: 579332
Follow Up By: Member - Norm C (QLD) - Monday, Jul 07, 2008 at 10:47
Hi Col. Thought I'd responded to this, but seems not - or I pressed the wrong button.
Laptop connects via data cable to the same plug as you use for charging. Antenna connects via a small plug in the back of the phone. There is a small plastic cover on it which you have to dig out with something sharp. You will need an antenna patch cable which you can get from a lot of phone shops. I got mine on the net for about $20. This just converts from the small plug into the phone to the larger connector on the antenna cable.
Good luck.
Norm C
FollowupID: 580247
Follow Up By: Member - colin J (VIC) - Tuesday, Jul 08, 2008 at 16:23
Thanks Norm,
I've been able to remove that pesky little button on the back of the phone, seen how it will plug in and ordered the patch cable. i really appreciate your help. Will be remote myself soon, not quite as much as you but it's good to be still in touch with the world sometimes.
Kind regards from Col.
FollowupID: 580415
Reply By: stephen looking - Tuesday, Jul 01, 2008 at 14:58
G'day Archar why pay for the internet I've been travelling now for 7 months and get by with free hot spots.
I guess it all depends on where you are but most coffee shops have free wireless, and the library is also a great place to go, and there are so many people that just don't secure the wireless
Cheers........Steve
AnswerID: 313270
Follow Up By: archar - Tuesday, Jul 01, 2008 at 15:24
hey steve,
im a bit of a laptop/wireless newby! can you tell me how that works?
FollowupID: 579316
Follow Up By: stephen looking - Tuesday, Jul 01, 2008 at 16:03
Archar i use a mac and its pretty simple in the top tool bar you have a wireless icon use this to make shaw its on. I know with some PC you have a physical switch that you use to turn on your wireless.
The wireless signal will then find your computer and you can choose which network to join if they have a pass word just try a different network.
With a mac i use a program called istumbler it finds all available networks and gives me a signal strength i then choose the strongest.
FollowupID: 579320
Follow Up By: Mainey (wa) - Tuesday, Jul 01, 2008 at 23:12
Yes, "free wireless" really is terrific in town, I also use it as my internet source and would not worry about any other way, as when I'm out of a town it's also well out of the range of Telstra & Bigpond coverage anyway.
Mainey . . .
FollowupID: 579417
Reply By: Member - Russnic [NZ] - Tuesday, Jul 01, 2008 at 15:49
Last year I used Vodafone, sounded good with the sale talk
Only any use in the City's. would work in places further out but the cost was horrendous $800.00 plus for three weeks on top of the usual rental took a few minutes of my Internet time to find that out.
Buy Hema maps that show the towns that have Internet, spend $3.00- 5.00 an hour and talk to locals as well, great value.
Never used it for an hour at any time, just to to check with family and let them know all OK and destination.
Only way to go I reckon.
Do business with the locals not the Internationals
Russ
AnswerID: 313277
Reply By: ctaplin - Tuesday, Jul 01, 2008 at 19:16
Can anyone tell me how easy it is to just purchase 10 hours of NextG usage for $34.95 as shown on the Bigpond website?Site Link
I have recently bought a Maxon ModMax 3G Data Modem and Radome 4db Marine antenna but don't really want to sign up to a long term contract, as I only need mobile internet access while travelling for a few weeks per year.
Thanks,
Chris
AnswerID: 313315
Follow Up By: Member - Andrew (QLD) - Tuesday, Jul 01, 2008 at 19:32
Read the fineprint link under that table.....12 months is the minimum signup period.
That "10 hours" is per month.....
Andrew
FollowupID: 579363
Reply By: Member - Ian F (WA) - Tuesday, Jul 01, 2008 at 21:43
Hi Archar
I have been using the Telstra wireless for 6 months (7.2 USB Card)
The initial cost was high ( $349 USB Card & $84.95 per mth for 1gb !2months ) I find it good and also have an external antenna
for use in fringe area's
Don't fall for Teltra's so called special for 36 months with a free modem as it will cost more in the long run.
I have used the mobile phone as a modem but found it very slow
Hope this is of some help
Ian
AnswerID: 313356
Reply By: psproule - Wednesday, Jul 02, 2008 at 06:55
Do you already have a decent 3G / NextG phone? Then chances are you already have wireless internet. Telstra wont tell you unless you ask them but generally a NextG phone plan includes a small amount of data, to which you can purchase more, and your phone acts as the modem via either bluetooth or the data cable that would have come with the phone. Works a treat with my Nokia E51 on a $40 plan, and used to work on my Samsung A701. You dont need to go and buy dedicated hardware and another "plan" to do this.
Pat
AnswerID: 313376
Reply By: stevesub - Wednesday, Jul 02, 2008 at 21:41
We are traveling in NW QLD and in Longreach right now. We have not had phone coverage for 3 days (Telstra GSM) but each night (close to some small town), we have had NextG coverage with our USB modem and 3dB gain antenna. There are a lot of smaller towns in NW QLD that only have NextG, nothing else. Even in Longreach you can only get NextG, Telstra GSM and Optus (Vodafone, who).
We have a VOIP account and that works fine for phone calls from the laptop over NextG.
Stevesub
AnswerID: 313510
Reply By: Bob of KAOS - Monday, Jul 07, 2008 at 09:45
Archar
I am using the Telstra Next G wireless broadband modem. Most of the time in the car (in town) it works well on its two little side mounted antennae but when stationary in fringe areas I attach the optional external antenna which can be on a long stick or up a tree. The Maxtor antenna comes with a 5m lead. On trips its mounted on the roof. Unfortunately, with Next G, UHF, HF, TV and multiple satellite antennae aloft, the car looks like a porcupine.
Even when phones aren't receiving I can log on.
Initially I had the superfast connection, but have down graded to the cheaper, slower connection. Its a 1 GB plan so you need to be careful when driving around running google maps or google earth connected to the GPS.
AnswerID: 314222
