Running a 3 way fridge on 12 volt for short periods
Submitted: Tuesday, Jul 15, 2008 at 16:21
ThreadID: 59786 Views:6213 Replies:11 FollowUps:6
We have ordered an Ultimate Camper and like the 3 way fridge. I would like to increase the battery capacity so that for short periods I can run it on 12 volt. e.g. Stopping somewhere for a couple of hours where I don't want to, or can't, move it over to gas.
Has anyone have a similar requirement and setup?
Reply By: Notso - Tuesday, Jul 15, 2008 at 16:28
Personally I never run the three way on Battery Power during shortish trips.
Providing you aren't trying to keep frozen goods you can go for 3 or 4 hours without power.
I usually have a couple of large Esky Freezer Blocks in the freezer compartment and they will stay frozen for 5 or 6 hours whilst travelling.
You may get 4 hours out of a fully charged 100AH battery using it on a three way. I think they draw around 12 amps and run full time.
AnswerID: 315437
Follow Up By: Findanomad - Tuesday, Jul 15, 2008 at 16:54
If we can get 3 - 4 hours then we probably don't need to move to 12 volt as I know they draw a fair bit of power.
FollowupID: 581576
Reply By: Member - barry F (NSW) - Tuesday, Jul 15, 2008 at 16:39
Howdy, We plug ours into 240V 12 hours or so before leaving & switch over to 12v while travelling. Apparently, from what I have been told, they will flatten your battery fairly quickly if the motor is not running. We have had a solenoid fitted under the bonnet so that when the ignition is switched off it cuts the power to the frig. If you don't open the Frig door while stopped for a couple of hours your beer will still stay cold!!
Before we had the solenoid fitted & when we pulled up for an hour or so I used to simply change the switch on the frig to 240V which of course simply stopped it from drawing on the battery, or sometimes we just used to disconnect the plug supplying power to the van.
AnswerID: 315438
Reply By: trains - Tuesday, Jul 15, 2008 at 16:48
3 ways on 12v draw about 10A continuos.
So it dosent take long to draw down a battery.
Use that to calculate the size battery you require.
Putting 12v computer fans to blow over the top cooling fins on the rear part of the unit can help alot in heat transfer, and increase the efficiency of the fridge, as too with good sized cables to the fridge, and a good connector to minimise voltage drop.
With these additions we can freeze on 12v under 35deg outside temp.
Trains
Ps, with our old borrowed brown 32l chescold, I covered it in 1" packing foam, then put packing tape over the foam to give it abrasion resistance. made a large difference in its keeping its temp down too.
AnswerID: 315439
Follow Up By: Findanomad - Tuesday, Jul 15, 2008 at 16:55
From What I can gather the Tropical kit fitted to the Dometic fridge is basically a fan which does what I think you are talking about.
FollowupID: 581577
Reply By: Member - Gary P (VIC) - Tuesday, Jul 15, 2008 at 17:03
We have an Ultimate, and the way the standard Ultimate wiring works is that it runs the fridge from the car but only when the engine is running. If we only stop for a couple of hours the fridge seems to stay cold (depending on the outside temp of course!), but if in doubt we have to change it over to gas.
The 3 way is so power-hungry that we don't run it on 12volts at any other time, even though we have upgraded the Ultimate's power system (Ours has two 100ah agm batteries).
We have a compressor fridge in our fourby that is much more power efficient. The 3-way is fine, though, when camped - it runs efficiently on gas, even in 35+ weather.
Hope you enjoy your Ulti as much as we do!
Gary
AnswerID: 315445
Follow Up By: Findanomad - Tuesday, Jul 15, 2008 at 17:11
I think I am convinced not to worry about running the three way on 12 v for short periods as it should keep cold anyway.
I understand the battery will be a 70ah which we will probably double.
What do you run the compressor fridge on when stopped, is it the trailer batteries?
FollowupID: 581581
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 15, 2008 at 20:33
We have an older Ultimate (circa 1998; number 56) and I got the chits big time with the useless 3 way fridge. Sometimes it would work too damn well and freeze the lettuce and tomatoes. Other times things went off because the damn thing couldn't keep up to the prevailing ambient temp.
I fitted a Engel upright fridge of the same physical size (100 or 110 litres I think?). I fitted 2 x Supercharge Gold Series SLA batteries in parrallel and have never looked back. Great fridge.
We tend to travel most days; 3 days in one spot would be exception and I can fire-up the Yamaha gennie for a few hours if need be in those circumstances.
I believe the newer 3-way fridges are much more efficient than the older style, so I wish you good luck.....but I too strongly recommend you don't run it off the battery/ies.
Roachie
FollowupID: 581643
Follow Up By: Member - Gary P (VIC) - Friday, Jul 18, 2008 at 16:57
We run the compressor fridge off the dual battery system in the fourby (80ah agm isolated from the cranking battery.) Lasted inside the fourby for four days of 30+ temps. Hate to think how hot it got inside, as we were parked in the sun.
Usually if it's hot I put the fridge outside, but still plugged into the dual system, but I wanted to test it to see how long it actually lasted.
We rarely prop for more than two or three days without driving somewhere, so that takes care of recharging.
Gary
FollowupID: 582143
Reply By: Mainey (wa) - Tuesday, Jul 15, 2008 at 17:33
Increase the battery capacity to at least 100AH (2 x 80ah even better) and make sure you get AGM Deep Cycle batteries, because they will charge much faster.
Mainey . . .
AnswerID: 315454
Follow Up By: Nomadic Navara - Tuesday, Jul 15, 2008 at 20:59
Do not run a 3 way fridge off 12 V without your alternator operating. It gives any battery too hard a time.
FollowupID: 581651
Reply By: Barry - Tuesday, Jul 15, 2008 at 17:45
The Ultimate 3-way fridge, when switched to 12V, never draws power from the Ultimate battery, but may draw power from the vehicle battery. The Ultimate battery is used for all other Ultimate electrics (lighting, water pump and radio) and this battery is charged when you connect to 240V power.
As Gary P has said above, the standard Ultimate vehicle wiring ensures that the fridge is only connected to the vehicle battery when the fridge is switched to 12V and the vehicle ignition circuit is on. This happens via a relay fitted to the Ultimate electrical box and is done to avoid flattening the vehicle battery by inadvertently running the fridge from it.
Hope this helps.
AnswerID: 315457
Reply By: Ray - Tuesday, Jul 15, 2008 at 19:36
I believe that I have a unique system to run my 3 way Eletrolux when ON THE MOVE.
My caravan has 140 amp hr batteries mounted on the draw bar. These are charged from either the car's alternator or via a smart charger permanently mounted in the caravan of the mains or an alternator (generator)
The cables from the car to the caravan are 4 aswg (18mm2)
When the engine of the car is running the 3 way fridge draws it's power from the batteries on the caravan but of cause these are being charged by the car at the same time.
When the ignition of the car is turned off the 3 way fridge is isolated from the system but there is still power to run all the other accessories in the caravan including an Engel fridge.
I did a check some time ago of the voltage at the 3 way fridge as installed by the caravan manufacturer and found that due to line loss (voltage drop) I had only 10.75 volts so don't trust caravan manufacturers to install adequate weight cables
AnswerID: 315480
Reply By: Member - Hughesy (NSW) - Tuesday, Jul 15, 2008 at 21:08
Don't know what 3way you have but the 90L one in my Jayco uses a 175W heating element on 12v (150w on 240v). I would say that it would run full time on 12v to try and keep the fridge cold.
On the fridge (mine was on the back of it) it says what size the heating element is so you should be able to work out how many amps it will pull over a set time and hence calculate how long you can run it off you batteries or how many batteries you need.
I always have my fridge cranked on 240v for about 36-48hrs before I head off so that you could leave it off for about 4 hrs and it would make very little difference to the fridge temp (dependant on outside temp obviously).
Good luck mate.
AnswerID: 315504
Reply By: Nomadic Navara - Tuesday, Jul 15, 2008 at 21:27
If you have heavy enough cable from the alternator to the fridge then you should not have to worry about running the fridge off battery during extended lunch stops. In fact a lot of travellers get by not powering their fridges when they are travelling.
On the crossing to Tasmania you can not power your fridge. Batteries will not last long and you are not allowed to run the fridge on gas. We switched the fridge off at 1900 on the night sailing. The fridge was only opened for the quarantine check the following morning. We travelled to Burnie after we got away from the ferry. When we checked the freezer at Burnie the contents were just getting mushy. We were not worried about the safety of the contents as the under certain conditions food can be refrozen. The "you can't refreeze food" applies to food that is removed from the fridge to thaw. If you thaw food properly - ie thaw it in the fridge - then it can be refrozen. Also the food would have only been above the recommended temperatures for a short period. Generally food is not kept in a caravan fridge as long you keep your food at home, which is also a factor in your favour.
Compared with those crossing Bass Straight and surviving, your 3 hour lunch stop is harmless if you have good cables to your alternator. Just don't keep opening the fridge, if you do then run it on gas.
AnswerID: 315511
Reply By: Member - kevin Y (SA) - Tuesday, Jul 15, 2008 at 22:22
was delayed once getting back to van ---battery flat -----ever since when i leave it for over 2 hours i switch to gas thats what its for ----only run on 12volt when travelling
AnswerID: 315523
Reply By:- Wednesday, Jul 16, 2008 at 12:13
The 3 way fridge in our van is connected to the auxillary battery in our vehicle by an Anderson plug & heavy wire.
As the auxillary battery is isolated from the cranking battery, i have no problems leaving the fridge running for an hour or two whilst stopped.
We also run a 50L Waeco in the back of the tug & we have had no problems with this set up.
AnswerID: 315577
