2 questions 1re spirit of tassie 1 re air tank
Submitted: Friday, Aug 01, 2008 at 21:24
The Geriatric Gypsies
gooday all
q1 does the price of the car and van include the drivers fare or is that another extra?????
q2 thinking about putting an air
tank(5-10l)in the patrol where can it be placed safely ?? i would like to store about 100psi when in use but could get away with about 60psi
where have others put there tanks keeeping in mind it is a 4.2ltdi with twin batteries so nota lot of room under the bonnet
steve
Reply By: Member - Paul Mac (VIC) - Friday, Aug 01, 2008 at 22:03
G'day Steve,
I'll answer Q 1 for you mate.
No, your fare is on top of what you will pay for the car and van.
If you have a look at the TT line website you will see a fare calculator in there. Whilst you can't book online for the car and van it does show you how much it will cost based on the non standard car fare. You will need to know exactly how long your car and van are in length then rounded up to the metre.
eg: your car and van are 11.2 metres in length. Your fare is based on a 12 metre non standard vehicle. It is also detailed on their website their freight charges IF your car and van exceed their length allowances.
Cheers.
318589
Follow Up By: The Geriatric Gypsies - Saturday, Aug 02, 2008 at 09:51
thanks paul
just wondered if the driver got a freebie just trying to workout how much it will cost me
steve
585101
Reply By: Member - gujimbo - Friday, Aug 01, 2008 at 22:33
Hi Steve
I have a small air
tank mounted underneath the vehicle on the chassis , have a look at my rig pic.
Cheers Jim
318595
Follow Up By: Dave(NSW) - Saturday, Aug 02, 2008 at 08:54
Jim,
What size air
tank is that, I've looked at a few but was unsure what would fit.
Cheers Dave...
585091
Follow Up By: The Geriatric Gypsies - Saturday, Aug 02, 2008 at 09:48
goodday jim
what did you do for a pressure relief valve and pressure cut off switch
steve
585100
Follow Up By: Member - gujimbo - Saturday, Aug 02, 2008 at 11:56
Dave
The
tank measures about 400x100 mm (probably about 9 litres) it is aluminium with 3 inlet ports.
Cheers Jim
585113
Follow Up By: Member - gujimbo - Saturday, Aug 02, 2008 at 12:03
Steve
Still playing with the setup but the pressure limit switch is mounted on the air manifold that supplies air to the diff locks, the compressor is mounted under the front passenger
seat.I have front and rear air hose outlets that run from the
tank to the front and rear bars.
Cheers Jim
585114
Follow Up By: Vivid Adventures - Saturday, Aug 02, 2008 at 12:24
Have you spoken with Geoff (Dixon) about what happens when it explodes?
585116
Follow Up By: Member - gujimbo - Saturday, Aug 02, 2008 at 16:06
Rather be at ground level than at 36000 feet!!!
585142
Follow Up By: Member - JohnR (Vic) - Saturday, Aug 02, 2008 at 23:09
Andrew, there is a pressure difference too for an oxygen cylinder. LOL HP nitrogen could be good though to charge tyres or NOS for the engine ;-))
585242
Reply By: Member - Roachie (SA) - Saturday, Aug 02, 2008 at 14:00
G'day Steve,
When I had my 4.2 I had my tank/s mounted on the back-side of the cargo barrier. At one stage I had 2 tanks, a 3L and 4L (gas cylinder). Eventually decided the 3L was enough for what I need; which is the air horns and ARB air locker.
The idea of having a larger
tank (say 20L) to assist with pumping up tyres is (IMHO) a falacy. Once you use-up the initial
tank capacity, the compressor then spends it's trying to pump up the
tank AND the tyre at the same time. Even a 20L
tank is not enough to re-inflate 4 tyres from 16psi to say 35psi....no way.
What did you want to use the air for? If it's just to blow dust out of filter or blow muck out of radiator fins, then the idea of a 10L
tank would be good. It also depends what sort of compressor you've got too.
I just use the standard ARB cut-off switch (limits to about 95psi). I don't have a pressure relief valve but I do use a check valve to protect the compressor.
Roachie
318642
Follow Up By: Member - Duncs - Saturday, Aug 02, 2008 at 22:23
This is one of the many things I have spent a lot of time thinking about.
Roachie, if you put a manual solenoid in the line between the ARB Compressor and the extra storage
tank you can isolate the storage once the
tank is down to the same pressure as the tyre.
That way you get to use the stored air when you need it and you can isolate it when you don't. Best of both worlds. On the down side it is something else to go wrong.
Duncs
585235
Reply By: Holden4th - Sunday, Aug 03, 2008 at 10:10
Your car can be surprisingly cheap to transport across Bass Strait, but it really costs you to travel personally. Here is an example:
Standard Car (up to 5m in length and 2m wide) is $58 all year round
1 person travelling: [OP = Off peak, S = Shoulder and P = Peak]
One Way Day Ticket OP $132, S $138, P $188. For this you find your own
seat on board somewhere (though there is plenty of room) and this is the cheapest option.
An overnighter has the option of 3-4 berth inside cabin ranging from $173 - $196; season dependent. (you can just get a foot ticket) Many people use the 3-4 berth option when you consider that you're only going to be sleeping in it what's the point of going higher. You're off the boat so early it's just a place to sleep. I'll never do the day trip again - boring and you can't drink (too much) as both theTassie and Vic Police set up RBTs sepcifically for those who've overindulged on the boat during the day.
If you're towing a tralier then a car with trailer up to 9m in length will cost you $137 - $238 dollars season dependent.
SO what does it cost:
For me to travel return leaving on say Dec 10 and returning Jan 15 would cost me:
$58 + $58 + $181 (S) + $196 (P) = $493. Multiply the last two figures by the number of people travelling.
I did the calculations regarding fly/drive and for me travelling alone the ferry trip was the far cheaper option. However, the more people travelling starts to bring this back towards equity, the cost of the rental being the major factor.
So do your homework (and your maths). For me it's a cheap holiday, even travelling from the
Gold Coast.
Also, check this site
http://www.spiritoftasmania.com.au/index.htm
And ring to make your booking - it could pay off with some fare reductions.
318745
Reply By: Member -Toonfish - Sunday, Aug 03, 2008 at 11:32
keep in mind when travelling that far you would be spending the hard earned on fuel for the trip less wear and tear ,the bonus of a rest and a cruise ,makes for a great trip thats not so taxing stress wise and the price holds plenty of people back so more room on the road once your there.
beatiful place cant wait to get back there.
318753
