GU PATROL AND FINER FILTERS
Submitted: Tuesday, Jul 22, 2003 at 10:59
ThreadID: 6108 Views:3969 Replies:9 FollowUps:3
Gidday,
I'm new to the diesel game, I've heard a bit about "FINER FILTERS", what are they, worth getting and is there anything else I should be looking for or at.
GU Patrol 3.0TD Auto
Reply By: Truckster (Vic) - Tuesday, Jul 22, 2003 at 11:44
Depending who you talk to, which leg your standing on, and what day of the week it is, is to if they are any better or not.
I have been given 4 main Finer Filters, and 2 Precleaner ones for nothign from people who thought they werent worth the effort!
I ran them, and didnt find any difference, (TD42T).
The OEM filters are only $20 for mine, and I'll stick with them I think!
AnswerID: 25586
Follow Up By: Topcat (WA) - Tuesday, Jul 22, 2003 at 12:25
I agree with Truckster about them not making any difference. I had one fitted & had a dyno test done which in fact reduced performance due to the air flow being restricted. Went back to the factory fitted air cleaner. Much more efficient. Cheers.Have Wheels Will Travel
FollowupID: 17350
Reply By: Member - Andrew O - Tuesday, Jul 22, 2003 at 11:46
The oil in foam filters is known to destroy the air flow sensor in the 3.0 patrol ... a part that costs >$1000. I personally use only the genuine air filter, which is lightly oiled anyway. I have a snorkel fitted, and when going through extreme dust (generally convoy driving), fit a snorkel sock (over the snorkel inlet), which significantly reduces the dust load on the normal filter. Because the oil is at the top of the snorkel, and the paper filter sits before the airflow sensor, this provides maximum protection, without risking damage to the sensor.
CheersSo much to see, too little time ...
Andrew
AnswerID: 25587
Follow Up By: Patrol22 (Queanbeyan - Wednesday, Jul 23, 2003 at 12:08
Andrew
You mention a 'snorkel sock' - I've been improvising by using my wife's footlet stockings to trap some of the dust when travelling in convoy these are about $3 for 2 pair - are you using some sort of purpose made sock or are you too improvising?
Pete
FollowupID: 17419
Follow Up By: Member - Andrew O - Wednesday, Jul 23, 2003 at 15:28
Pete,
The snorkel sock is made by finer filter - and operates on the same principal as the oiled filters. Cost is about $20, from most 4WD shops.
Andrew
Andrew
FollowupID: 17429
Reply By: Hughesy - Tuesday, Jul 22, 2003 at 12:15
The only real advantage is if your OEM filter is fairly pricey and you do a lot of km's. Most of the finer filters I think are around $60 - $100 mark so if your changing your filter every 10000km and your OEM filter costs $30 bucks then it doesn't take long to recover the extra for the FF. I've had a finer filter for 5 years and still on the original bottle of oil (500ml). Any power or efficiency increase is 3/5 of bugger all. Another advantage is that you can clearly and easily see when it needs cleaning and it requires no mods to your vehicle.
Hughesy
AnswerID: 25594
Reply By: Member - Alan - Tuesday, Jul 22, 2003 at 15:37
My $'s worth -
Due to the high cost of a paper air filter for my Rocky I used a finer filter for 3+ years without any problems until about a year ago when the turbo developed a small oil leak. My mechanic said $1k should cover reconditioning the turbo which should fix the problem , another diesel mechanic said get rid of the finer filter,its restricting air flow , go back to a paper filter and see if that fixes the problem. Went back to the paper filter no sign of a leak since- I believe the finer filter was restricting airflow and putting presure on components??
It may cost a few $'s more but I will stay with the paper filter.
AnswerID: 25611
Reply By: Andrew - Tuesday, Jul 22, 2003 at 16:39
As Andrew O said, they will clog your air sensor and stop the cars management system. Don't do it.
Nissan filter in excellent and actually inpregnated will oil anyway. Use the genuine part in this instance. NO QUESTION
AnswerID: 25613
Reply By: Big John (QLD) - Tuesday, Jul 22, 2003 at 18:03
Mick,
When I did my power upgrade I asked John Whittaker of Dyno tuning &Turbocharging (they did my upgrade) the same question, his reply was to stick with the standard Toyota air cleaner.
Regards john
AnswerID: 25618
Reply By: Steve from Drive Systems Victoria - Tuesday, Jul 22, 2003 at 21:48
Arguably, the best filters on the market, in terms of air flow and longevity, would be K&N. However, the do not make one to fit Patrols, yet. Suggest a phone call or e-mail, to keep the pressure on to have them produced. They are a cotton spun fabric that filters finer than paper, flows twice the air so very good for turbo's, and are washable and reusable.
AnswerID: 25636
Reply By: djm67 - Tuesday, Jul 22, 2003 at 22:15
The K&N filters get my vote, been using them for 8 years (5.0l Commodore, 2.6l Rodeo & FJ1200 motorbike). Better fuel economy (slightly) and a heap more power (even the missus could feel the difference on her first drive)
A bit dear ($120 for the car, $140 for the Rodeo & $95 for the bike) but cheaper than constant replacement of the paper ones + all the above benfits.
Check Repco, a mate just bought one for his Hilux there and they had the best price he could find locally (Brisbane)
AnswerID: 25642
Reply By: crowe - Wednesday, Jul 23, 2003 at 15:41
k&n are the go, noticed huge difference in power, if you get one it is extrememly important to clean regulary, every 10thou, more in dust. They make one for the gq patrol, dont know why they wouldnt for the gu
AnswerID: 25700
