Varnishing a Timber Tray
Submitted: Saturday, Sep 13, 2008 at 17:09
Gone Bush (WA)
I have a timber tray in my 70 series.
Can anyone give me some hints on the do's and don't do's as far as varnishing it is concerned pls?
Preparation? Type/brand of varnish?
Any websites devoted to this sort of thing?
All reponses appreciated.
Reply By: darrell.QLD - Saturday, Sep 13, 2008 at 18:13
Cabots exterior varnish..
water based.....good stuff.
When it fades(and it will after about 2 years) do it again...
325114
Follow Up By: Brian, Mackay Qld - Saturday, Sep 13, 2008 at 18:56
totally agree, i use cabotts exterior varnish (rose mahogany), on the balau decking in my 75 series cruiser. recoat once a year.
592224
Follow Up By: Brian, Mackay Qld - Saturday, Sep 13, 2008 at 18:59
also add, do sand timber with 80-100 grit when new, 120 grit when recoats are needed. dont
putty screws, because it is a massisve pain in the butt when you need to ever replace the boards. dont worry about scrathes when they happen otherwise you will never put anything in your tray.
592225
Reply By: Member - Reiner G (QLD) 4124 - Saturday, Sep 13, 2008 at 18:17
Like Garden furniture varnish is not long lasting. I oil my tray once a year and no worries. A new tray needs to be oiled 3 or 4 times in the first year.
A lot of farmers use diesel, that works
well too.
Reiner
325115
Reply By: Member No 1- Saturday, Sep 13, 2008 at 18:40
tung oil.....is an option
it will require several coats and periodic maintenance thru out the year but tung is easier to maintain than polyeruthanes... but poly lasts longer...
Some use orangeoil
some also use linseed and terbine or diluted with "pure" turpentine (not to be confused with mineral turps)
I guess it comes down to what sort of finish you want, how long you want it to last and then redo versus doing periodic maintenance
325119
Reply By: disco driver - Saturday, Sep 13, 2008 at 23:55
Hi GB,
If you want a pretty shiny tray, use estapol type exterior finishes.
Be very aware that almost anything hard or sharp will scratch the surface.
On the other hand if you want practical long(ish) life use an exterior deck oil as often as necessary. It will absorb into the timber and act as a preservative as
I know that your tray is next to brand new and you will want to keep it that way,so don't forget to treat the timber underside of the tray as
well, this will almost stop moisture up take and assist in preventing cracking and warping as the tray gets older..
Hope this helps.
Disco.
325164
Follow Up By: Member - John (Vic) - Sunday, Sep 14, 2008 at 00:03
Treat the underside, now that would be a fun job (Not!!)
592277
Follow Up By: disco driver - Sunday, Sep 14, 2008 at 00:21
Hi John,
It's not that hard, a BIT messy but not difficult.
I put the decking oil into the kero washdown gun, connect up the compressor and "let 'er go".
OK I drop a elcheapo blue tarp down between the cab and the cab rail and a bit of black plastic over the spare wheel (On my old Landy, it's hung under the tray) and then I "let 'er go".
The Deck oil does not appear to damage the tray's steel framework
Generally need a shower and a change of clothing post spraying though.
I'm fortunate that the back of my block is sand so any spillage is absorbed. The Deck oil is reasonably environmentally friendly, much better than the first few years when I used a mix of used engine oil and Min Turps.
Disco.
592281
Reply By: Richard Kovac - Sunday, Sep 14, 2008 at 02:11
Old Gear Oil
325169
Reply By: Member - Christopher P (NSW) - Sunday, Sep 14, 2008 at 06:49
Wattyl matt lacquerfor exterior use, pretty good used whilst repairing and restoring old furniture. Looks good and easy to repair!!! to repair hit tray with 120 grit and wipe down with wax grease remover and spray!!!
325175
Reply By: Best Off Road - Sunday, Sep 14, 2008 at 10:20
For a long lasting finish use marine grade stuff. A bit fiddly tp apply but comes with an applicator. For a top quality finish allow it to completely harden between coats an sand with very fine paper.
About $35 a litre at Bunnings.
Jim.
325216
Reply By: JustT - Sunday, Sep 14, 2008 at 11:49
I had good results using cabbots decking oil. gave the timber a coat every 6-8 months, still looked new when i sold the ute after ~3 years of constantly in the weather.
quick and easy to apply, very little prep needed as
325223
