Globe replacement on GU Aux tank and demister switches
Submitted: Tuesday, Sep 23, 2008 at 19:46
Michael ( Moss Vale NSW)
Hi all, I was sick of the dash light globes on my Gu, Aux
tank and Rear demister switches not working. I removed the switches, managed to get them apart without destroying them and then of course, Nissan told me they are not servicable... The tiny globes are pushed into a rubber housing and are removable from the inside of the switch. I bought some 12 volt mini globes from Jaycar and stripped the insulation from the wire and wound the bare wires back through the rubber housing the same way the original globe was and BINGO!!! I didnt even ask the price of the new switches form Nissan but i guess they would be upwards of $80 each. The original globes have a blue silicone membrane over the glass to change the diffused colour through to the front of the switchor just to dull them, and the new globes are clear. They appear to me to look the same as the original only a little brighter.. Im happy, .90 cents each globe.. Michael
Reply By: Member - shane (SA) - Tuesday, Sep 23, 2008 at 19:57
Hi Michael, do you mean the globes that light up when you push the switch on or the globes that light up when you turn your lights on?
326790
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Sep 23, 2008 at 20:22
Gday Shane,
in my case the globes when you turn the
parking lights on had blown but the other globes are set in exactly the same way and easily removed and repaired. The globes that light when you push the switch on are white and glow clear when turned on. You can use the same globe from Jaycar. It is a bit tricky to get the switches apart, you need to remove the whole centre dash surround and push the switches out and disconnect the plug, the top part of the switch that moves has 4 rectangle holes, two on each side, a small screwdriver to prise gently the little plastic clips and the top of the switch comes away, a pair of tweezers to remove the bulb, carefully look at how the bulb wires are wrapped around the rubber holder,you will need good eyes or in my case , my 12 year old sons... basically the bulb is put back into the same place as the old one, threading the bare wires through the holes below it , bend the wires back 180degrees and thread them back through the holes that the copper contacts on the switch and where the contacts touch the rubber housing.. sounds like double Dutch but when you see it, it makes sense.. Jaycar part number is SL-2685 and the yellow insulation on the flying leads are yellow to denote that it is 12V.. You do need to be patient and take extreme care to get the switch apart without damage.. Michael
Michael
593935
Reply By: Michael ( Moss Vale NSW) - Tuesday, Sep 23, 2008 at 20:34
The original globe in the rubber housing and the new globe. Michael
Image Could Not Be FoundImage Could Not Be Found
326809
Reply By: Michael ( Moss Vale NSW) - Tuesday, Sep 23, 2008 at 20:49
Just another view of the new bulb in the middle.
326813
Reply By: Peter 2 - Tuesday, Sep 23, 2008 at 21:23
Might be worth replacing the globes with LED's, either straight leds or LED replacement globes, never have to do them again in a normal mortals lifetime.
326826
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Sep 23, 2008 at 21:56
Hi Peter, i thought of that after the event, there is room to add a dropping resistor in the front of the switch for a basic led. If it happens again I will do that. Michael
593963
