gxl free wheeling hub Conversion Kits
Submitted: Friday, Oct 03, 2008 at 07:19
Gdad
has anyone yoused or had a mate that has done it is it any good i was looking at the Marks 4WD Adaptors Part time 4WD kit suit 100 series cant see the point of driveing this front diff around on the black stuff
Reply By: Hairs & Fysh (NSW) - Friday, Oct 03, 2008 at 08:23
I've got constant 4wd on my 91 80 series GXL and love it. It feels more shore footed on wet roads and it drives great on dirt roads.
I like the way it pulls around a cnr not pushing. That's fine in a car to be pushing from the rear and I've had my fair share of V8's over the years.
How much difference is there in
fuel economy and power loss driving the front diff anyway?
How many k's would you have to do to make your money back on the cost of the conversion? If you only saving about a liter per 100k's.
I don't know what the figures are, but it's something you've gotta add up.
328229
Reply By: zumzum - Friday, Oct 03, 2008 at 10:31
why change something perfect?
Luca
328248
Reply By: Wizard1 - Friday, Oct 03, 2008 at 13:21
Off the topic a bit, what is a "yoused"?
Is it a mophing of you and used to save on letters?
328262
Reply By: Member - Phil G (SA) - Friday, Oct 03, 2008 at 14:19
I don't notice any real difference in
fuel consumption whether my hubs are locked or not.
328267
Reply By: Sea-Dog - Friday, Oct 03, 2008 at 14:49
I went through the same questioning procedure when I was looking to put a part time kit in my 80 series GXL..
At the end of the day I was swayed away from the idea as the only real saving is the drive flange on the front hub...
fuel economy change is minimal and you loose the constant 4x4 ability so you have to engage the front hubs and centre diff lock to put it in 4x4.. should take a fair bit of the drive line clunking away though as you only have the slack through the rear and not the front also.
Some people do the conversion so you can engage low range to reverse big vans etc without getting transmission wind up.. a quick fix to this is to disengage the fly lead that is on top of your transfer case.. essentially you still run constant 4x4 but if you want to engage the diff lock you have to push the button on the dash.
From what I could see on the instructions it is a relatively easy install to do yourself if you are half handy on the spanner.
It all boils down to the question of whether you want to spend $500 to turn your car into a part time four wheel drive or not.
328272
Follow Up By: Hairs & Fysh (NSW) - Friday, Oct 03, 2008 at 18:14
'you loose the constant 4x4 ability'
Your right Sea-Dog.
This is what I also like about constant 4wd, not having to get out in the mud to lock the hubs in.
You can drive from the black top, on to the sand and not have to get out and lock'em in.
I guess it comes down to personal choice.
595565
Reply By: Kroozer - Friday, Oct 03, 2008 at 15:00
I thought that most people did it to save premature wear and tear on the front drivetrain components. Supposedly wears out bearings and seals quicker then normal. This is just what i was told by a mechanic so dont shoot me down please.
328275
Reply By: Davewest - Friday, Oct 03, 2008 at 19:23
Mate I did it to my 80 mainly because i had to replace my drive hubs and c.v's. I also had a bit of wear on the font diff bearings so it was a lot cheaper then repairing the lot. The effect on
fuel wasn't noticable but the handling was a lot worse even on the black stuff. I lost a lot of confidence on gravel roads. If i had my time again i would have fixed the other parts.
328324
