Holden Rodeo (Jackeroo?) Lift Kits
Submitted: Friday, Aug 01, 2003 at 09:16
Dennis (Brisbane)
After much searching for info I just got a reply from Eddie @ 4WDUSA link textregarding Calmini (made in the USA) lift kits to suit Holden Rodeo's (kits available for the Jackeroo too I believe).
2" torsion bar, shocks & rear shackle lift $995
3" upper control arm, torsion bar, cross member, shocks & spring lift $1995
Upper control arms alone (allows over 2" of wind up on the torsion bars) $885
4WDUSA
1a Chalkley Place, Bayswater, WA, 6053
Ph (08) 93703440 Fax (08) 93703369
eddieat4wdusa@bigpond.com
Reply By: Matt M - Friday, Aug 01, 2003 at 10:45
Gee thats gone up a fair amount, you would think with the fall in the US dollar and the strengthin ours, the prices would fall proportionately!! I think someone is cashing in a little in this time of goodfortune!!
I would hit them up for a indexed price due to the fall, would be curious and maybe even consider purchasing if they were to pass on the discount!
I have been looking at the Calmini gear for years but thought the changeover cost from the states was prohibitive!!
Matt.
26505
Follow Up By: Truckster (Vic) - Friday, Aug 01, 2003 at 11:26
Our $$ is diving again at the moment..
but its supply and demand.. I agree those prices are stupid!
18124
Follow Up By: Dennis (Brisbane) - Friday, Aug 01, 2003 at 19:18
Stupid prices maybe, but what are the options?
I can't find any other specialised lift kits anywhere (with new upper control arms). There are plenty of 'wind it up' or 'bigger torsion bar' options with
suspension kits, but no other genuine 'lift' kits.
18186
Reply By: yarda - Friday, Aug 01, 2003 at 16:32
Most interesting, I have heard a lot of people report problems with excessive cv & uni wear when lifting jackaroos, have you guys heard this also , and do you know what effect this lift conversion has on the front end geometry - if it can be shimmed out etc. My jack could certainly do with a few more inches ( as could i !!)
Also has anyone also fitted these style of kit and had any feedback from a vehicle engineer / vicroads etc.
Cheers brad
26556
Follow Up By: Dennis (Brisbane) - Friday, Aug 01, 2003 at 19:22
That is the purpose of the new upper control arms. Supposed to correct steering goemetry.
18187
Follow Up By: Matt M - Sunday, Aug 03, 2003 at 18:37
If you are running the constant front hubs then of course you will get more wear from lifting the front of any IFS setup! If like most of the IFS setups the hubs lock maually then you only have a little more stress on the CVs when in 4wdrive. But be reasonalble we are only talking a few inches of lift, these kits are only 2 or three inches and winding the torsion bars up can give you two inches!!
The new upper control arms do correct the geometry a little and there are also ball joint spaces that can correct even more for more lift!
They are a quality product and highly used and recommended in the states for all the Isuzus out there!!
18244
Reply By: Dennis (Brisbane) - Friday, Aug 01, 2003 at 19:05
Perhaps I should have mentioned that the 3" lift is a complete kit, brake hoses, shackles, nuts, bolts, new bump stops etc (everything needed to fit the kit).
26566
Follow Up By: Truckster (Vic) - Friday, Aug 01, 2003 at 22:53
Just seems expensive for what it is, do you need a 3inch lift on a Rodeo??
My 6in lift cost $2200 Engineered and all came with the works, and panhards etc etc...
Suppose as I said, not much call for them, so they can charge what they like, criminal ;-)~
18200
Follow Up By: Dennis (Brisbane) - Friday, Aug 01, 2003 at 23:22
Need, mmmmmmmm ................................. will WANT suffice as a reason? :-) hahahaha
We (the 4WD community) really need some competition in this area of vehicle modification. Especially for us that don't have the 4 established modification kings (landcruiser, disco, jeep and patrol).
Whoever did yours, do they (or can they) do Rodeo's?
That upper control arm is the key, and at $885 just for that from 4WDUSA, by the time you add ANY
suspension kit to it the cost is massive.
Any engineering firms out there want to jump in on this???? Tritons, Rodeos, Pajeros, Couriers, Bravos, (not sure about Navara's) there are a lot of torsion bar front end 4WD's out there and the control arm is the key to any substantial lift. There is an untapped market for this stuff.
18202
Follow Up By: Truckster (Vic) - Friday, Aug 01, 2003 at 23:49
The other thing with Qld being so strict, would it be legal in Qld???
Talk to an engineer before you spend $3000+.. would be heart and wallet breaking..
18205
Follow Up By: Truckster (Vic) - Friday, Aug 01, 2003 at 23:50
Have you looked at importing the shiat yourself from USA?? Cut the middle mans profit.. could be worth looking into.
I know heaps of blokes that import their own tires, (large boggers etc) and save.
18206
Follow Up By: john- Tuesday, Aug 05, 2003 at 20:07
Gooday All, I've been following your conversation over the last couple of days and would like any info ( who do I ring ) about lifting a 2002 jackaroo. I always seem to be told its all to hard. Truckster, you reported you have had you 4wd lifted for $2200. Could you let me know by who. Thanks.
18396
Follow Up By: Truckster (Vic) - Tuesday, Aug 05, 2003 at 20:29
John.
Mines a GQ patrol, you could get a 4-6inch lift done almost anywhere for the price.
I recommend Total 4wd Center in Epping Vic, they did
mine, Brett and Rod nice blokes and knows their shiat.
18400
Follow Up By: Dennis (Brisbane) - Tuesday, Aug 05, 2003 at 20:47
John,
Let me know what they have to say about lifting Holden/Izuzu vehicles. This is ridiculously hard to achieve ...... apparently.
Also have a look at the Vic Jackaroo Club site link text, someone there may have some ideas.
Maybe search here link textas
well
18404
Reply By: Member - Peter D M - Saturday, Aug 02, 2003 at 07:34
dennis
you could contact calmini direct. with duty, freight and gst, import as little as possible. the u c a is all you need. calmini the only people who make them.
the upper ball joint move is a more common way to increase ground clearance.
ive imported parts 8-10 days have a look at [ www.independent4x.com ] and the isuzu
forum at [ www.4x4wire.com/isuzu/? ]
with the ball joint move and the spacer with torsion bar crank and with 265x 75 x16 tyres my front, ground to underneath guard is 925mm.
the ball joint move allows you to crank and keep wheel alig ok.
you need to think about these changes cv wear, speedo, shackle and tyre legality
the 4x4 wire site especially their
forum has heaps of info.
remember our rodeo is a pickup and jackeroo is a trooper. all rodeos from 86 to 02 have same
suspension and jackeroos without rack and pinion steering the same as rodeo.
hope this helps
regards peter
26605
Reply By: yarda - Monday, Aug 04, 2003 at 08:38
Sounds good dennis and Matt, I shall have to check Calmini out further, I was about to fit the Jack with a full set of Ranchos anyhow , so I might as
well go the whole hog, Thanks guys.. Brad
26733
Follow Up By: Dennis (Brisbane) - Monday, Aug 04, 2003 at 18:53
Do you think it worth canvassing the exploroz 'forumites' and any other interested parties (like 4WD clubs) and guaging interest in doing a bulk order and import? (perhaps through an independant third party to keep it all honest etc, perhaps someone who has a mechanical business?)
To compare with the above quoted prices from 4WDUSA in West Oz, direct from Calmini, for my Rodeo (US = Pickup) the 4/8/03 conversion rates mean that the 3" lift kit is AU$1151.02 (a saving of AU$843.98) and the UC arms are AU$480.76 (a saving of AU$404.24)
Of course then there is freight + import duties/taxes to be added to that, but it still could be an option.
$843 and $404 respectively is massive savings, enough I imagine to more than cover freight and import duties. Anyone up on that stuff??
Also found rear spring over axle kits for Izuzu's for around the US$130 mark, wonder how they go with legals here?
18307
Reply By: yarda - Tuesday, Aug 05, 2003 at 09:08
As far as private importing goes , I'm not sure about the import duties etc, but I know that freight wouldn't get any cheaper until you got a full pallett load. Anyone else got any info on private import duties / taxes ??
26822
Follow Up By: jackablue - Wednesday, Aug 20, 2003 at 13:35
yarda you are looking at 5% duty on commercial vehicles (4wds) parts & 10%gst. The calculation of gst is( the cost of the goods + freight + insurance + duty) x 10%. Work it out before you commit. May not be worth it.
19776
Reply By: Dennis (Brisbane) - Tuesday, Aug 05, 2003 at 21:04
And yet another option????
Taken from a Australian website explaining the hows and whys in their *** 4" *** lift to IFS Hilux's. But at $3.5k it ain't cheap either.
.......................The front subframe assembly is replaced with new parts that locate all the components lower down. The angle of the front CV joints is maintained at the factory setting.
Why not just turn the torsion bars until it's at the height you want ? Because then it'll ride terribly, the CV joints will be at 90% of their maximum operating angle and give very poor travel and the torsion bars will quickly sag.
New drop down brackets are provided for everything, including the brake lines.
Sway bars are retained with the use of the included extensions.......................
Can this be done to Rodeos/Jackaroos?
26878
Follow Up By: dogart - Monday, Aug 18, 2003 at 03:01
keep this post going peoples
it's getting interesting
I was considering a range of diff 4wds
posting a little while ago about
explorers!
coming from the ole '84LS jack
I'm starting to go full circle and I'm thinking of
getting another one.
I'm still amazed at the amount of room in the back
of my 'ole tractor compared to all the other's (except for the cruizers/patrols)
anyway...
this raising option will be one of the factors in my final choice of 4x4.
have ~6 months to go before I'll upgrade
wolf
perth
19563
