Waeco can size Inverter,
Submitted: Saturday, Nov 01, 2008 at 16:51
ThreadID: 63110 Views:6004 Replies:6 FollowUps:12
Hi Folks,
I've been looking on the Waeco website at their 100W can size inverter.
Waeco Inverter
For the life of me I can't find any electrical characterisitcs for the output side of them. ie, modified sine wave which I suspect for the price or pure sine wave.
Do any of you know which they are?
Thanks,
Geoff
Geoff,
Landcruiser HDJ78,
Reply By: Wayne (NSW) - Saturday, Nov 01, 2008 at 17:06
Geoff,
I just had a look at the one that I have got and there is nothing on the unit about the out put side other than what is on there web site.
I have used it for recharging camera batteries and it works well for that.
I would guess, because you are inquiring about modified sine wave and pure sine wave, you might want to power the lap top.
I have not used the Waeco Inverter for charging a lap top as I have a inverter that is designed to power lap tops.
Wayne
AnswerID: 333029
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Nov 01, 2008 at 17:19
Hi Wayne,
Thanks for that!
I'm looking at charging camera batteries as well as running as weird as it may sound a CTek battery charger (6 Volt 0.8 Amp version).
Sounds like from your experience it will do what I want.
I was a little scepticle about it running switch mode power supplies but I'd guess your camera charger will be one.
Sounds like your new RV Troopy is serving you well!
Thanks agan,
Geoff
Geoff,
Landcruiser HDJ78,
FollowupID: 600887
Reply By: RV Powerstream P/L - Saturday, Nov 01, 2008 at 17:39
Hi Geoff
There is a Truck Show on the wharf up past the Brewery tomorrow starts at 9AM maybe someone will have something there.
Ian
AnswerID: 333032
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Nov 01, 2008 at 17:43
Hi Ian,
Forgot about that one!
How's life treating you?
Geoff
Geoff,
Landcruiser HDJ78,
FollowupID: 600894
Reply By: Member - Nick (TAS) - Saturday, Nov 01, 2008 at 18:08
Modified sine wave for sure, have one and its ok for for little charging jobs.
AnswerID: 333037
Follow Up By: RV Powerstream P/L - Saturday, Nov 01, 2008 at 18:25
Good Geoff
Hey your vehicle picks dont look like the one I last seen you in .
Rods County Camping will be there tomorrow demo ing DC Wheel nut removers and step down nut removers for trucks and Ive got to drop off some bits for him.
Also with him will be Jason Wilson and his brother Paul pushing Amsol synthetic oils and the new Sequent 11 Diesel Gas System Designed in the Hunter Valley by Hunter Gas Technolgies and appears to be superior to every thing else available.
Ian.
FollowupID: 600902
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Nov 01, 2008 at 19:11
Ian, ya silly bugger you missed by one reply.
Sounds good, do you want to sell me one of your small Sterling Inverters?
I'll give you a ring on Monday to discuss.
I'm also doing a project at work that will probably interest you, can't discuss it on an open forum.
I've still got the Troopy. Same one as you saw me in last time.
Don't forget your always welcome for a cuppa.
Geoff
Geoff,
Landcruiser HDJ78,
FollowupID: 600907
Follow Up By: RV Powerstream P/L - Saturday, Nov 01, 2008 at 20:07
Yep Thats me .Silly B.
Ill be back down probably wednesday and I can call by if you like and Ill make it cuppa time.
You might stick one on the oscilliscope and see what it looks like.
I wonder if it will be as fuzzy as that Inverter gen that you tested you know the one that would not run a thurister controlled washing machine but I believe that has now been corrected.
Be in Touch
Ian
FollowupID: 600922
Follow Up By: RV Powerstream P/L - Saturday, Nov 01, 2008 at 20:09
I hope they dont moderate you for bad spelling I meant Thyrister not Thurister.
Ian
FollowupID: 600923
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Nov 01, 2008 at 20:31
Your spelling is probably safe, I'm in strife for calling a silly bugger a silly bugger though.
Yep, no problems on the oscilloscope, we'll do that on Wednesday too.
Nobody in head office has noticed it's missing so it's available anytime you need the output of something checked.
Throw in one of your Strong Box adjustable battery boxes too, I need a second one. For a silly bugger you have good gear!
"I wonder if it will be as fuzzy as that Inverter gen that you tested you know the one that would not run a thurister controlled washing machine but I believe that has now been corrected."
We'll find out on Wednesday won't we! I'll toss the transformer we used for the last tests into the wagon in the morning.
See you Wednesday,
Geoff
Geoff,
Landcruiser HDJ78,
FollowupID: 600929
Reply By: Member - Doug T (NT) - Saturday, Nov 01, 2008 at 18:14
Geoff
You might some info HERE
AnswerID: 333038
Reply By: Member - Mike DID - Saturday, Nov 01, 2008 at 18:49
If it's a Sinewave Inverter, it will advertise it in big letters.
If it's a Modified Square Wave output, it will absurdly describe it as a Modified Sinewave (the output looks nothing like a sinewave).
AnswerID: 333043
Follow Up By: Member - Graham H (QLD) - Saturday, Nov 01, 2008 at 19:12
You can have mine for $35 including postage Its been used twice then I bought a 12v converter for the Laptop
FollowupID: 600908
Reply By: Paul Grabonski. Vic - Sunday, Nov 02, 2008 at 12:32
cannot beat Jahycar for inverters
Jaycar only sell electrically isolated inverters
Jaycar can inverter only $49.95
Jaycar 180w PURE SINE WAVE inverter only $199
run a small fan off modified sine and then pure sine inverter and hear the difference.
everything powered from modified sine wave gets super hot
sine wave can be used for everything and uses less power
AnswerID: 333138
Follow Up By: RV Powerstream P/L - Sunday, Nov 02, 2008 at 18:54
Due to the complexity of sine wave versus modified sine the sine wave inverters have a higher useage quiescent power need thean the modified sine.
Maybe hardly noticeable in small units but becomes more noticeable as the capacity increases.
Ian
FollowupID: 601070
Follow Up By: Paul Grabonski. Vic - Sunday, Nov 02, 2008 at 20:57
Ian time you went to university or did some studying to update your knowledge. On the other hand to bring that up here in the context of the inverters being discussed is bordering from ludicrous to ridiculous and useless.
Overall and in the majority of situations a sine wave inverter will have a lower power requirement for the equipment users here would be using with the inverters. Leave the wanky unecessary stuff for the technical forums where it may be relevent.
FollowupID: 601089
Follow Up By: RV Powerstream P/L - Monday, Nov 03, 2008 at 09:52
Thank you Paul for your post I did not realise that you knew me so well but to enrol to study further may well mean that I would displace someone younger that may really need to upgrade their knowledge to get a better foothold in life today.
If as you say I have to update my knowledge why should you state that the contents of my post should be placed in technical forums where it may be relevant (not relevent).
I try to keep up with technological changes today and that is difficult and the information was gleaned by me from a qualified engineer that designs for a major US OEM supplier of electronics including inverters.
He stated and wrote words like the following:
People think that the Quasi Sine Wave (Square Wave .Modified Sine Wave) was dead and that Pure Sine Wave would rule the world but Quasi Wave Inverters have continued to outgrow sales of pure sine wave proving that there is a lot of life left in this technology and the reason for this is a that a lot of equipment such as mobile phones ,TVs, drill chargers and all sorts of equipment that used to be a problem with Quasi sine are no longer a problem as this equipment now uses switchmode power supplies which will work fine on quasi sine wave form inverters.
We have always found the quasi sine inverters to be smaller, lower cost, better performance, more efficient and more reliable than sine wave.
With new technology and features new quasi sine can reduce running costs with a lower quiescent power need than pure sine.
There is the odd appliance such as a washing machine and some breadmakers where quasi sine wave inverters simply do not work but all in all we find this technology is adequate for the general requirements in boats and vehicles.
As much as this is a personal opinion of this engineer it is still one that is at the coalface of change and with direct involvement in the industry.
My post was of general information that I considered appropriate to inverters and your statement of “ludicrous, to ridiculous and useless” should be responded to with an explanation for the person or persons that may think it holds some value to them and its up to the individual to apply it or not apply it to their own use and your input would have had better value for the readers of the forum if you due to your now indicated superior knowledge ask further why the statement was made rather than show your condemnation in a way that does nothing for the general readers and perhaps turns them away from further input.
Ian
FollowupID: 601171
Follow Up By: Geoff (Newcastle, NSW) - Monday, Nov 03, 2008 at 21:55
Perhaps the posting of my testamur, my industry experience, my current industry position, current relevant power generation and current power reticulation project experience as well as several TAFE qualifications would add some credence to this discussion?
Paul, I asked a specific question on a specific device.
I did get some great alternative information from some really genuine people, you included. This really supports the power of ExploreOz.
As to Ian's very relevant point, he is 100% correct. The quiescent current of the Pure Sine Wave inverter (another oxymoron if you introduce an oscilloscope) is greater than the quiescent current of the Modified Sine Wave come Modified Square Wave inverter. (The exact terminology is open to interpretation)
Is this relevant in my question? Not really.
Is it relevant if I was chasing a 2kw inverter? Very definitely.
I suspect the recent retaking of the Forum by the owners and moderators is in no small way driven by these personal attacks without substance.
Why do these electrical type threads always attract this kind of vitriol?
Sadly the vitriol is of the "guerilla warfare" variety, dive in, fire a round and run for cover without any substantial backup.
I'm over it, I'm sick of answering questions in a field where I have over 30 years experience and the formal qualifications to back it up only to have someone who's skills and experience are based on internet guerilla warfare and/or Google dive in and attempt to drag the post into the gutter.
I can actually understand how Mike Harding feels on this subject right now.
Geoff
Geoff,
Landcruiser HDJ78,
FollowupID: 601328
