12v light in caravan
Submitted: Tuesday, Nov 04, 2008 at 19:18
ThreadID: 63233 Views:9451 Replies:6 FollowUps:3
We have recently purchased a 2000 Coromal van - love it a lot - there seems to be provision for using the internal lights and the external light on 12v - i.e. when connected to car - but nothing happens when we try it - are we missing something or could it be there is a wire missing in the connector plug? We bought it privately and the guy we got it from didn't even know what the "black light switch" was for - and the manual supplied is no help either.
Hope someone can enlighten us.
thanks - jules
Reply By: Boobook2 - Tuesday, Nov 04, 2008 at 19:27
I am sure there is a master switch somewhere. Does the van have a battery?
AnswerID: 333641
Reply By: Member - Doug T (NT) - Tuesday, Nov 04, 2008 at 19:35
Julie
I reackon the problem would be in the wiring , 2 scenarios , 1 the socket on the car has no 12 volt live from the battery, 2 it's there but wired wrong , get a 12 v tester and check all the terminals in the car socket , turn all lights off on the car before the test, if the car does have a 12v live at the socket it should light up the tester , make a note of the pin number and change the caravan plug to suit, or vice versa.
Trailer Plug guide
AnswerID: 333644
Reply By: Supercalafreakinawesome- Tuesday, Nov 04, 2008 at 19:54
I've used the diagrams in the link that Doug T supplied and re wired car & caravan without problems.
Also in my van (bought it second hand) it has a battery in the boot and located near the battery is a couple of switches (similar to white household light switches) and I can isolate the 12 volt lights from there. There is also a number of 12volt fuses in a fuse box. If you can find any or all of these things it may be worth checking if all is ok.
AnswerID: 333648
Follow Up By: Dunaruna - Tuesday, Nov 04, 2008 at 20:03
I posted my '240v light switch' comment before realising that you had already referenced it, sorry.
FollowupID: 601441
Reply By: Dunaruna - Tuesday, Nov 04, 2008 at 19:59
Most caravans do not have reverse lights therfore pin 2 becomes an aux but it is lightwieght, much better to get a 12 pin plug or add an anderson plug alongside a 7 pin.
Julie, is there a 240v light switch inside the front boot of the van?
AnswerID: 333650
Reply By: Keith_A (Qld) - Tuesday, Nov 04, 2008 at 22:56
Hi Julie - we owned a Coromal, and they are brilliant vans.
(You are right about the manual.)
I do not remember any master 12V switch in the van.
Sounds likely the 12V supply from the car is missing.
They do have a fuse bank - worth checking for a blown fuse.
One simple thing you can do - plug in the 240V lead, and try the lights. They fit a transformer in the Coromals -(Usually a Zig X70 http://www.zig-electronics.co.uk/products.htm) so it provides 12V when connected to 240 (in a Cvan park - or at home). If they work when plugged into 240V, you know it is the car supply. If they do not, then you need to look for a fuse or switch. nb - our fuse box was next to the Zig, under one of the seats.
There are always small teething problems when you buy a van, but you have a great unit there.
If you intend camping in National parks etc away from 240V, it is fairly simple to get a deep cycle battery fitted, connected to the car by an Anderson plug, to keep it charged...............Keith
AnswerID: 333689
Reply By: Dunco (NSW) - Tuesday, Nov 04, 2008 at 23:07
I'm with boobook2 on this...Please check to see if the Van has a battery as I have seen other people with similar setups...but NO BATTERY so you cannot use the 12v system.
I haven't really seen anyway that uses their vehicles battery for their van lighting...a bit dangerous me thinks...fall asleep with something left on and flat battery in the morning !!!
AnswerID: 333690
Follow Up By: ross - Wednesday, Nov 05, 2008 at 00:30
I had a 23 ft York caravan years ago and it was wired through the plug to run 12volt lights off the car battery.
I think a lot of the older vans were wired like that once.
FollowupID: 601494
Follow Up By: Member - Julie P (VIC) - Thursday, Nov 06, 2008 at 17:19
G'day - thanks for all the advice - we have a dual battery system in the car - was thinking maybe to have it transferred to the van - anyway we'll think on that - will get "the boss" to check out some of the advice and see what eventuates.
jules
FollowupID: 601725
