handle nut like things...where to purchase
Submitted: Sunday, Nov 09, 2008 at 11:46
ThreadID: 63369 Views:3630 Replies:9 FollowUps:5
ghullo (due to the phlem in my throat at present),
I am chasing some nuts (go on, I can hear you...) yes, some nuts that have the black plastic or rubber knobs attached (is this sounding really bad now...;)), the ones you see attached to accessories that are taken apart quite regularly or used for easy adjustments. Basically my kayak mounts have been somewhat destroyed by a lower than normal pipe in an underground carpark, and rather than by new brackets, I will make my own, but need the knob like nuts so that they can be quickly removed.
Ideas in Perth would be great but not necessary
Mike
Reply By: disco driver - Sunday, Nov 09, 2008 at 14:51
Mike,
Don't know if these will work for you but you could try your local mower shop. Most mowers have what you described to locate the handle (fold up and down to fit in car boots).
they may not be the correct thread but you may be able to modify your design to use them.
Disco.
AnswerID: 334358
Follow Up By: mike w (WA) - Sunday, Nov 09, 2008 at 19:15
Perfect!! exactly what I was thinking of. I shall check it out. Thanks
Mike
FollowupID: 602145
Reply By: Flywest - Sunday, Nov 09, 2008 at 15:00
Mike they are called wing nuts!
Prince Charles ears stick out like wing nuts!-
AnswerID: 334360
Reply By: Shaker - Sunday, Nov 09, 2008 at 16:07
I think you will find them in almost hardware store!
They will most likely be whitworth thread.
AnswerID: 334364
Reply By: Member - res.q.guy (Vic.) - Sunday, Nov 09, 2008 at 16:33
Hi Mike
You could try a Nut and Bolt specialist, or I sometimes get them from a local bearing shop. I think I even saw them in a Bunnings once !
Neil
AnswerID: 334370
Reply By: Member - 120scruiser (NSW) - Sunday, Nov 09, 2008 at 17:26
Something like this.
AnswerID: 334376
Follow Up By: Member - 120scruiser (NSW) - Sunday, Nov 09, 2008 at 17:27
Bunnings will be your best friend.
FollowupID: 602133
Follow Up By: Shaker - Sunday, Nov 09, 2008 at 18:11
I think he meant these .....TRI KNOBS
As I said before, most hardware stores have them.
FollowupID: 602137
Follow Up By: mike w (WA) - Sunday, Nov 09, 2008 at 19:17
Shaker,
yes more like the tri knobs.
Unfortunately, wing nuts would be too hard on the fingers when they are cold, and too fidly
Mike
FollowupID: 602146
Reply By: lancie49 - Sunday, Nov 09, 2008 at 18:39
Dems da wuns Shaker..............
I've got a box ofem in the garage 'cos ya never know when ya gonna need one.
It always take them of something before it goes to the tip.
I never knew what they were called and I've never seen them out at retail.
Good find.........
lance
AnswerID: 334386
Reply By: Louie the fly (SA) - Sunday, Nov 09, 2008 at 20:26
Mike, a long way from you, but D & D Barry in NSW are the go. We buy all sorts of machine elements from them. They have a huge range of stock.
D & D Barry
Louie.
AnswerID: 334404
Follow Up By: Louie the fly (SA) - Sunday, Nov 09, 2008 at 20:29
Click on the Elesa+Ganter icon. They have probably the best range.
FollowupID: 602158
Reply By: Member - Duncs - Sunday, Nov 09, 2008 at 23:03
I put a right angle bend in a piece of light steel rod and welded it to a nut of the appropriate size.
I use the with pieces of long thread with a hook bent in the end for securing all manner of things to my trailer or the spare wheel on the car. They work a treat.
Maybe I was just born too close to Scotland. But I really did it because I wanted them NOW and had the bits and pieces lying around the shed.
Duncs
AnswerID: 334435
Reply By: dundermodel - Tuesday, Nov 11, 2008 at 06:13
There is a huge selection of different types at
Small Parts Knobs Index
AnswerID: 334585
