Saturday, Dec 06, 2008 at 19:42
G'day Wayne,
I've just returned from a short trip to the VHC and have travelled extensively in many areas up there over the years, having lived in a number of towns at the base of the mountains on both sides of the range.
This is my take on camper trailers, given that I am not particularly experienced at camper towing and I take it gradually as I don't want any nasty surprises! . Make of it what you will and some will disagree.
I think they are great for ALL of the access
routes, most of the 'easier' tracks, some of the moderate tracks, but NOT for the harder/hardest tracks. That being said, there is a great deal of variation in all of the above. The way I approach it is to tow the camper into an area that is fairly central to what I want to see and then do day trips to areas of interest. If I want to
camp in more remote
places that are harder to get to, such as down in the Caledonia Valley, I leave the camper at home and travel lighter with tent etc. This also makes room for more recovery gear, a hand winch and chainsaw for self sufficiency. You really should carry a chainsaw in the VHC, since after the fires, there are many dead trees just waiting to fall across your path. VERY hard work with an axe or bowsaw.
Here are a few examples of some of the track I travelled this week:
McMillan's Track in to
Talbotville.....easy, 2WD and no problems whatsoever with the camper. There was a Peugeot 307 in there the other day! Like wise the
Dargo High Plains Road to Mt. St. Bernard.
Crooked River Road from
Talbotville to Kingwell Bridge....probably OK most of the time, but there are a number of river crossings which can either be easy or difficult depending upon rain.
We went that way a couple of days ago and all was fine (without camper) except for one quite deep
river crossing (the last before Kingwell Bridge) that came up to the top of the bonnet. There were a couple of largish rocks that needed to be avoided. I'd be reluctant to take the camper across that crossing as it was quite deep, even for the 4WD. The rivers down there can rise and fall quite quickly and some of the crossings can be a trap for the unprepared and those unwilling to get out and have a look or walk the crossing first to check the route.
Billy Goat Bluff track to
the Pinnacles. This is a very steep climb. I approached it with lowered tyre pressures and didn't have a problem (no camper), but I thought about whether I could tow the camper up there and it is probably possible, but meeting another vehicle at some points would make it 'interesting' to say the least and the 'strain' on the vehicle's drive train would be quite high dragging another thousand or so kilos of junk up there. Approaching from the Moroka end would present little problem.
Crooked River Track from
Talbotville to Bulltown Spur.....again probably possible and easier than the
Billy Goat Bluff Track but still depends upon river levels and how much 'strain' you are prepared to put on your setup. It is a fairly steep climb up out of most of these valleys.
I would be more comfortable towing up these steep grades if I had difflocks and very low gearing, but it is an individual preference.
Given that I have significant experience without camper in these areas, I will read further replies with interest, as I may be a little bit conservative for some......
Mark
338581
Follow Up By: Wayne David - Saturday, Dec 06, 2008 at 20:09
Mark - Brilliant stuff from you and some good sound advice too.
I appreciate the effort you made very much.
I shall now print out what you and others have written & get checking maps.
Thanks everyone for your tips and advice.
Cheers - Wayne D
606126
