Off Road Trailer Couplings ????
Submitted: Thursday, Dec 11, 2008 at 17:28
DBT
Hi to all !!. and to you camper trailer travellers who might be lucky enough to have internet access.
Hoping to get some realistic advice and experiences with Off Road trailer couplings. Seems I have 3 choices.
The Tregg
The Hyland
The Orac
Have seen cheaper and similar variations to the ones listed but am considering one of the above brand.
Experiences would be much appreaciated.
Reply By: Stiphodon - Thursday, Dec 11, 2008 at 17:40
I've had Tregg and Hyland. My personal choice is a Hyland. They have plenty of articulation, are easy to couple on uneven terrain and you dont need to constantly swap your ball fitting for a Tregg coupling if you need to tow other trailers around that dont have a tregg hitch. We use them on all our offroad trailers at work as
well and have never had a problem with them.
339242
Follow Up By: DBT - Thursday, Dec 11, 2008 at 18:01
Had a tregg on a previous trailer some years back. Never got to use it much. Usual story, kids, now they have left home its time for us to enjoy the country. We did find it a bit awkward to hitch. The hyland does appear to be the better choice for us. (Hey, we are in our 50s, keep it simple. eyes going etc. and yes we drive)
606790
Reply By: Member - Captain (WA) - Thursday, Dec 11, 2008 at 17:49
I have a Tregg hitch and while I am happy with its performance, it is a pain in the proverbial to hook up when on anything other than a firm surface.
If I was buying a new off-road coupling, I would give the Hyland a go for sure.
Captain
339245
Follow Up By: DBT - Thursday, Dec 11, 2008 at 18:04
Great! We thought it was just our ageing eyesight. Might try and thread a needle just to check. We had many a hassle on an uneven surface.
606792
Reply By: Member - 1/2A - Thursday, Dec 11, 2008 at 17:52
I have a Hitchmaster AT 35 Mk111 from
Vehical Components
Its fantastic and I've found it easy to connect to the vehicle and it has two safety lock features.
339246
Follow Up By: Member - lyndon K (SA) - Thursday, Dec 11, 2008 at 17:57
As above, the AT 35 is simply the best on the market. Iv'e used treg and Trig and they are fine too.
I find the AT 35 hard to couple up but i still wouldn't swap it!
Iv'e had the pin pulled out of the bottom of a Treg hitch more than once while in the bush!
Cheers Lyndon
606789
Follow Up By: Member - 1/2A - Thursday, Dec 11, 2008 at 18:02
Mine is easy to connect up but this my be because my camper is so light (600 KG empty).
606791
Follow Up By: Motherhen - Thursday, Dec 11, 2008 at 23:13
We put an AT35 on the caravan; hitching is not difficult, but unhitching can be, as if on uneven ground or at an angle, the pressure on the pin makes it difficult to extract. The Hyland would be easier for hitching up, and no doubt also easier for unhitching.
606857
Reply By: Member - Ed. C. (QLD) - Thursday, Dec 11, 2008 at 18:00
I'm using a Hyland (3500), and am not considering changing it for any other......
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
339249
Follow Up By: DBT - Thursday, Dec 11, 2008 at 18:21
We thought the hyland is an easier hook up than the other two.
606796
Reply By: MEMBER - Darian (SA) - Thursday, Dec 11, 2008 at 18:14
I'm about to get experience using a Hyland on a new van, but have used the two SA products for a number of years each - Treg and Trigg - both very robust and easy enough to use on camper trailers - you can nudge the trailer a little when hitching up - vans are heavier and harder to nudge - I think the Hyland will shine regarding that aspect.
339251
Reply By: Member - Paul Mac (VIC) - Thursday, Dec 11, 2008 at 18:49
Reply By: Geoff (Newcastle, NSW) - Thursday, Dec 11, 2008 at 19:20
Hi DBT,
I have the Tregg on my trailer and the thing I love about it has nothing to do with articulation off road.
They are totally silent!
You can feel the trailer on the back but there is none of that rattle and bang associated with the regular ball coupling.
For the silence alone I'd fit the Tregg to any trailer I owned.
Geoff
| Geoff,
339262
Reply By: Member - Paul W (VIC) - Thursday, Dec 11, 2008 at 21:23
I have the Orac on my c/t and it is very simple, works
well and easy to connect/disconnect. is not noisy or rattly either cheers Paul
339296
Follow Up By: Member - MUZBRY-(MURRAY)(Vic) - Friday, Dec 12, 2008 at 08:07
Gday Paul
I have ORAC on my camper as
well. No problems with coupling ,as i have two tow hitches to choose from.One with 50mm ball and ORAC as part of the trailer.
Murray
606875
Reply By: SPRINT-GTO - Thursday, Dec 11, 2008 at 22:41
Happy with the Hyland on my (3500kg) rig
339316
Reply By: Member - Oldbaz. NSW. - Friday, Dec 12, 2008 at 08:06
I agree with the beauty of the silence afforded by the Treg. As a
earlier respondent said, the pin is a worry, so I replaced it with a key lockable version. available from the EO
shop. A bit fiddly to do up but has the added advantage of locking the coupling when you
leave the trailer. Never had any issues connecting Treg, just level
with jockey wheel & slide in. no doubt all 3 systems work, a matter
of choice really, the treg works for me....oldbaz.
339336
Reply By: Member - Rodney B- Friday, Dec 12, 2008 at 10:02
I've got a Hyland on my off road camper and I love it. There is no noise as the hitch is a snug fit at the bottom of the ball as
well (you have to use a slightly longer shaft on the tow ball) so try the ball in the Hyland before you buy it).
Easy to hook on and off and full articulation. Can be locked for safety with a bolt or padlock.
339356
Follow Up By:- Friday, Dec 12, 2008 at 14:00
Nice to know with the Tregg and Orac that the polyurethane block is asorbing all the shock, that otherwise would be transferred to the tow vehicle.
606922
Reply By: Member - greg S (QLD) - Friday, Dec 12, 2008 at 22:40
Hi DBT,
We have used the Hyland and the AT 35 (the At 35 is on our camper ).
Both are great hitches.
Yes it can sometimes get a little tricky with the At 35 when you are on slopes and such, but it is a great hitch and bloody strong (rated to 3.5T).
The hyland is great for it's ease of use. You can use a 50mm towball (so you can use the same towbar tongue arrangement for you're box trailer). It articulates with the best of them, and I am pretty sure you can get them in two sizes (2000kg and 3500kg).
Haven't used the Tregg or Orac, so sorry cannot comment on these.
339441
Reply By: DBT - Sunday, Dec 14, 2008 at 16:30
Thanks for your input guys, much appreaciated. We think that we might go with the Tregg again. Appears to be very little negative comments from our reasearch on this site and else where.
Thanks again
D & S
339702
