99 Holden Jackaroo. What to look for?
Submitted: Monday, Dec 29, 2008 at 17:50
ThreadID: 64636 Views:5349 Replies:3 FollowUps:5
My mate is looking at buying a 99 model L8 3.5 v6 Jackaroo.
I saw the vehicle and it looks to be in very good nick but I was wondering what to look out for with this model. I know this may have come up before but I have had a search and couldn't find anything. As always any advice would be greatly appreciated.
Cheers, Scott
Reply By: Wherehegon - Monday, Dec 29, 2008 at 21:22
Hi Scott, the only thing I have heard about is the inlet manifold gasket which easily replaced and at a reasonable price if needed. Other than that its only the diesel jacks that everyone seems to say, stay clear of. Plenty of go. If you have the last 4wd monthly magazine they have a build up of one in there, looks a treat. Bit like the mitsi's pajero, very underated. If you want to do serious rock hopping then in my opinion you cant go past the patrols or cruisers with live front end, you will never get the wheel tavel from an IFS front end even with major mods. If not rock hopping and just using it for touring or off road but not real hard core stuff then it will be fine. I think the prado's, pajeros, jacks are all as good as each other. You will get some one telling you they drink it in V6 form, would be no worse then a prado,if any thing they are around the same figures as the pajero V6's which is less the the prado's. All the best with it and get out there and have fun, thats what its all about. WHG
AnswerID: 341777
Follow Up By: Madfisher - Tuesday, Dec 30, 2008 at 17:37
Hi Whg,
after watching Prados in action at the vic gathering I have no doubt they will go further in hard terrain. They where modded similar to yours and very impressive with the tyres let down. They have better front suspension travel.
Cheers Pete
FollowupID: 609554
Reply By: Rangiephil - Monday, Dec 29, 2008 at 21:47
My son had one until recently.
Look at the usual suspects like CV gaiters gone. He didn't and it cost him $700.
He bought one with 170KK on it and at 200Kk the auto died. he managed to trade it with a dud auto. He was told it is about $3.5K for a rebuild.
Otherwise the car was good if crude, and it drank like a sailor at about 20l per 100 kms around town..
Regards Philip A
AnswerID: 341781
Reply By: Steve63 - Tuesday, Dec 30, 2008 at 11:27
Hi Scott,
There will be a list:
CV boots cracked/split
Test clutch if manual
front bash plate brackets may be cracked (ours fell off at 169,000km)
Look to see if mechanics have taken off the bash plate over the sump. It can be akward and a few mechanics take them off and drop them in the bin without telling there customers.
Check aircon works and bearings are quiet. This is expensive to fix and if it siezes the car is unusable as the serpentine belt breaks.
If it has a sub tank fitted check the mounting points as they are not often mounted all that well. Also check the grease nipple on the shaft as there is a good chance it has been broken off by the sub tank.
Not a bad car, they can get around. They are pretty thirsty we used to get 16l/100km. If you have a heavy foot it will be 20l/100km.
Steve
AnswerID: 341846
Follow Up By: Scotty76 - Tuesday, Dec 30, 2008 at 16:11
Thanks everyone my friend decided to buy the car but when he rang the bloke he had decided that he didnt want to sell it after all.
FollowupID: 609544
Follow Up By: Madfisher - Tuesday, Dec 30, 2008 at 17:33
Lots of good ones arround Scotty, best to get one with little off road use. We are looking for a 2nd one to replace our Paj.
They are good on fuel if manual, and well maintained. Best I have got was 8.6k/l at 105kph. Good ones are very grunty.
Mind you if Prados and Jacks where arround the same price I would go a Prado. I brought mine with 101000ks now has 137000, only problems are inlet manifold gasket which cost $360.00 including labour and a cv boot.
Towing my boat the jack is very stable and barely slows on hills in 4th where as our 3lt Paj is working a lot harder, and using more fuel.
Cheers Pete
FollowupID: 609553
Follow Up By: Member - Tony B (QLD) - Wednesday, Dec 31, 2008 at 07:06
Scotty76. Loved my JACKAROO. Very good motor, but very thirsty if you stick your boot too it. 15ltr per 100k Highway. I had the CV boots split and replaced and the front bash plate brackets cracked which I welded. Other than that it was bullet proof. Good looking vehicle as well and very comfortable. You will get a good one if you look around as the resale value is quite low for some unknown reason. Regards Tony
FollowupID: 609603
Follow Up By: Madfisher - Wednesday, Dec 31, 2008 at 11:34
Hi Tony, cannot quite work the economy thing out as I get 14l/100 towing my 4.2m boat full of camping gear but with a boat cover, this is on flat going trying to stick to 95 to 100. Mind you as soon as I hit the mountains and put the foot down its is a diff story.
But I have mild ats,running 10/30 oil and have removed the restrictors in the y piece and it is manual. Autos are known gas guzzlers in jacks.
Cheers Pete
FollowupID: 609628
