Willem raised the issue of broken bits caused by overweight vehicles in another thread.
A couple of years ago I started a weight reduction programme and it resulted in a few bits and pieces that may be of interest to others. Many of you would have seen some of these before.
1. Bead breaker (pic below)
2 pieces of 12mm aluminium welded together.
It easily breaks any bead, even my 305/70R 19.5s, and it is ¼ the weight of most other bead breakers.
2. Tyre to tyre air adaptor. (pic below)
I run my tyres at a maximum of 65psi on the bitumen, but they have a safe capacity of 115psi, so that is what I run my spares at. There is enough air in a spare to inflate a flat or blow the dust out of the tool box or ….. without even starting the compressor. Blow them up at the
truck stop when we get
fuel.
3. Air compressor accumulator (no pic).
When I built the camper section on the OKA, I sealed the 2 chassis rails. They are my air accumulator. I have seen the same done using a bull bar and a trailer chassis.
4. Pumping diesel from a 200L drum (top item in pic below)
This cap attaches to a length of
fuel hose and the air hose from the compressor. Pretty easy job. Just don’t put too much pressure in the drum.
5. My EMERGENCY ONLY air compressor (bottom item in pic above).
Not sure if I should explain this one.
Air hose QC on the left hand end, LPG gas fitting (LH thread) on the other end.
Do NOT do this. No correspondence will be entered into.
If you like any of these, post a new one for us to share.
OKA196 Motorhome
