Tuesday, Aug 12, 2003 at 16:46
The diesel engine as we know it has been evolving for a number of years, as for this technolagy being applied to larger capacity motors it already is. an example is the 3lt jackaroo engine the 3.2 lt pajero. power output and torque are up over the basic boat acnhors fitted to most 4wd. they allready can go 10,000klm between
services as the high pressure common rail direct injection produces far less soot than the older generation of oil burners. low end torque with high pressure direct injection is better know matter what engine capacity.
the nissan owners make a lot of noise about the new 4.2 lt turbo motor. (old tech) 114kw 360Nm still doesnt meet euro engine emmisions. 3lt jackaroo 118kw 330Nm
pajero 132kw
They use the same injection tech. in large trucks (C.A.T) plus others.
apply the same 4 valves per cylinder and injection tech. to larger capacity turbo motors and the effieciny an power goes up allong with the drop in emmisions.
compare the latest 4.2 nissan turbo to the toyota the same size with electronic injection it's a stagering differance.
as for servicing, electronic injection has been used in cars for years, you will not find a single car without injection today. common rail High pressure direct injection diesel uses the same engine managment principals as has been used with petrol engines for years(without the spark timing of course!)
within a few years every motor will have it and people will be wondering what all the fuss is about.
By the way the next generation of petrol engines will be using high pressure direct injection petrol(a compresion ignition engine that uses light
fuel[petrol] instead of deisel) less smelly & the public like filling cars up with the same stuff, now that will be something to talk about!
happy motoring
jack
19002
