Broken rear windows
Submitted: Saturday, Jan 24, 2009 at 21:15
Kim and Damn Dog
I came across this yesterday which may be of interest to caravan and camper trailer users. Certainly not cheap, but could reduce stone damage and broken rear windows.
http://www.rocktamers.com.au/
Kim
Reply By: Willem - Saturday, Jan 24, 2009 at 23:02
G'day Kim
Yerr....may be OK for the
Birdsville Track and Tanami Road but come the first serious bush
creek crossing and those things are history....lol
345798
Follow Up By: Member - Bevan (QLD) - Sunday, Jan 25, 2009 at 01:53
yeh i cant see them lasting on step rutted out buggy tracks
613822
Reply By: Member - Willie , Sydney. - Sunday, Jan 25, 2009 at 08:51
Hi Kim,
A few years ago I made myself up a similar design from
conveyor belt rubber.
It sort of worked, but I found that when I was travelling in wheel tracks they swept rocks up from these and made the situation worse.
I did not do any heavy 4WD stuff with the and if I had say, used them in mud, I think they would have been totalled pretty quickly.
I have seen these Rock Tamers ones at the Penrith Show. They do look great , but are very expensive .
Willie.
345817
Reply By: Member - Julie P (VIC) - Monday, Jan 26, 2009 at 19:18
In my opinion the only real answer (proven time and time again by us) is to cover the rear window - and the best stuff is a uv impervious product called Tuffex - 2mm thick - does not crack in the sun like perspex - ours lasted years - we attached it initially with velcro - but dust, rain and heat is a problem, so we got some suction caps that have a screw fitting, drilled holes and put them on - never had a problem after that. There is a mob sometimes mentioned on here called "obeys outback" O'Briens or something like that - they supply them with velcro attachments.
jules
346059
Reply By: Member - Mike DID - Monday, Jan 26, 2009 at 20:36
I did 19,000km through Central Australia without a single stonechip on the rear door.
I attached shadecloth to the front of the trailer and to a bar that attached to the rear bumper. Each edge was cable-tied to an occy strap to stop the edges sagging down.
346076
Follow Up By: Member - Beatit (QLD) - Tuesday, Jan 27, 2009 at 09:29
G'day Mike,
Do you have pictures? Trying to understand the non dragging bits when turning.
Kind regards
614096
Follow Up By: Member - Mike DID - Tuesday, Jan 27, 2009 at 09:41
I still have the net, but I don't have any photos of it in place - I don't have the campertrailer any more. I really need to take a photo of the net though !
I hooked on two occy straps from the outer ends of the bumper bar and the front of the trailer - long enough for when in a tight turn.
I then used cable-ties every 10cm to attach the shadecloth to the occy strap.
614098
Follow Up By: Member - Beatit (QLD) - Tuesday, Jan 27, 2009 at 12:42
Hi Mike,
So the occy straps would need to be no longer than the shortest distance on an inside turn? I was wondering if they were "special" occies of sorts? I can't imagine the ordinary types lasting getting stretched that much.
Kind regard
614120
Follow Up By: Member - Mike DID - Tuesday, Jan 27, 2009 at 13:19
They're just standard Occy-straps with metal hooks.
Keep in mind that the drawbar supports the centre of the shadecloth.
614124
Reply By: Member - Rod N (QLD) - Monday, Jan 26, 2009 at 21:15
Also see these topics for stone guards
Topic 64795 and
Topic 64541
RodN
346083
