LC - How many k's is too many
Submitted: Wednesday, Jan 28, 2009 at 14:31
ThreadID: 65489 Views:3232 Replies:8 FollowUps:6
Hi all.
I'm looking around at various 4x4's including 80's series LC's, just wondering though, how many k's on to the clock is too many? Should I discount any with 400,000 or more, or will these engines happily do more than that if well maintained? Obviously how well the engine is looked after will play a big role, but really, what is the life expediency without major rebuilds. Or, is this just a "how long is a piece of string" question.
Reply By: Matt Watson - Wednesday, Jan 28, 2009 at 14:55
I should note, I'm specifically looking at diesels.
AnswerID: 346348
Follow Up By: Member - Tour Boy (QLD) - Wednesday, Jan 28, 2009 at 15:15
Mate I've had diesels and petrols with more km than that, but looked after. If you haven't seen a full service history, get a compression test done and a cooling system pressure test. At worst factor in some $ for a few years time.
You didn't say what model either, 2H, 12HT, 1HZ, 1HD-FTE
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 614355
Reply By: Shaker - Wednesday, Jan 28, 2009 at 15:19
Buy the vehicle, not the odometer!
AnswerID: 346354
Follow Up By: Matt Watson - Wednesday, Jan 28, 2009 at 15:22
Oh, I was planning on starting with the odometer and building the car up around it :)
FollowupID: 614359
Follow Up By: Shaker - Wednesday, Jan 28, 2009 at 15:43
Sorry, but a lot of buyers are obsessed with kms & forget the bigger picture.
FollowupID: 614365
Follow Up By: Matt Watson - Wednesday, Jan 28, 2009 at 15:56
haha. no problem. I'm just trying to get an idea of the kind of things I should be looking for. I wouldn't think of buying a 90's commodore with 500,000k on the clock.
FollowupID: 614367
Reply By: Matt Watson - Wednesday, Jan 28, 2009 at 15:19
Not really sure what model yet (really depends what comes along), Will only have about 10k to play with so my choices will likely be limited.
AnswerID: 346355
Follow Up By: Member - Tour Boy (QLD) - Wednesday, Jan 28, 2009 at 15:26
Mate an 80 series is the go over the 60/75 series as they are much more capable when it gets rough and more comfortable on the road. Plenty of 80's around sub 10k and the 1hz motors aren't that dear to rebuild, if looked after 750,000+ is not uncommon
Dave
2015 Fortuner
FollowupID: 614360
Follow Up By: Matt Watson - Wednesday, Jan 28, 2009 at 15:33
Thanks tb, looks likes its time to start picking some out of the trader and having a look then :)
FollowupID: 614363
Reply By: get outmore - Wednesday, Jan 28, 2009 at 16:11
the engine is only 1 part of a 4by there is alot more that wears out.
yea one with over 400k might keep going - but sorry after 200k the odds are diminishing
personally without extensive work I would consider 4-500k to be the lifespan of a vehicle only to be touched if very cheap
5 grand could easily be spent on an old vehicle without touching the motor
AnswerID: 346372
Reply By: Member - Phil G (SA) - Wednesday, Jan 28, 2009 at 16:16
You can always fix the mechanical stuff. But you can't always fix the body and chassis. Walk away from any vehicle with rust in bad places (eg sills, roof, windscreen) and cracks around the steering box on an 80series chassis.
I'd be willing to buy a vehicle with a good body and chassis that had done high k's, and passes a good test drive. I've had friends come away on desert trips with diesel LandCruisers with over 400k on the clock, but had reasonable maintenance.
AnswerID: 346373
Reply By: kevanancy - Wednesday, Jan 28, 2009 at 16:36
I bought an 80 series about 5 years ago with 174k on the clock , very tidy unit , great to drive , no slack anywhere and no rust , but had a cracked piston by 224k . There is an aftermarket turbo fitted and apparently the boost was way too high . Had to do a full rebuild at a great cost , kept the turbo and put a new core in it and had it set way below the reccomended boost . If I was to buy it again I would get it checked more thoroughly than what I did . Beware aftermarket turbos , make sure the boost is not too high . Now we have a great 4b but it cost a lot more than we anticipated .
Kevanancy
AnswerID: 346379
Reply By: Madfisher - Wednesday, Jan 28, 2009 at 18:52
If I had 10 grand to spend I would be looking at a petrol as you can get very good petrol Pajs, Jacks, 80 4.5 petrols. We just brought an immaculate 9/03 Nullabor jack with 76000ks for $14000.00.
As soon as I get it detailed our 3lt Paj is going in the trader. (98000ks) for arround $7500.00. It has some minor battle wounds but is in perfect mechanical condition.
Most Diesels in this price range are really to have BIG money spent on them.
But if you look long enough you will always find a low k vehicle.
I have never paid more then $15000.00 for a 4wd and the highest mileage when purchased was 130000ks on my 4 runner and that was only because I was in a hurry.
Good luck Pete
AnswerID: 346405
Reply By: Robnicko - Thursday, Jan 29, 2009 at 17:47
Matt,
My 95 LC80 with 4.5petrol is just about to clock 300K and I feel that it's just as good as when I bought it new, if not better. I have a Falcon wagon 2006 as a work vehicle and after using it all week and then getting into the cruiser on weekends it feels so much better.
I guess the diesel should be even better as they are known for longevity.
Mind you mine cost close to 50K back then so for 10 to 15K you should be ok if you find a genuine good one.
Good luck
Rob
AnswerID: 346600
