Jumper leads
Submitted: Thursday, Jan 29, 2009 at 20:26
Steve
Just noticed
Supercheap have a set of 200 amp leads for $30 -
mine are ok for the wife's car but I think I'm pushing my luck trying to start a big diesel with em
what's the go?
Are they good enough - any recommendations?
Reply By: Trevor R (QLD) - Thursday, Jan 29, 2009 at 20:39
Your average battery to start a "big diesel" will be a lot more than 200 amps.....closer to 700+cca so I figured I needed at least this in my jumper leads and went the 750amp set.
I could be way off the mark with my logic and would be happy for someone to set me straight.
Regards, Trevor.
346632
Follow Up By: V8 Troopie - Thursday, Jan 29, 2009 at 20:53
I would guess the $30.00 jumper leads have a lot of insulation and little copper within.
Easy to check on most by sliding back the clamp insulation and look where the wire is terminated to it.
Often that is just crimped on copper plated steel, not exactly a reliable long life method.
The best "big diesel" jumper leads are made from welding cable and welding earth clamps. Those will start a big diesel any time. They might cost a tad more than $30.00 though......
614663
Reply By: Michael ( Moss Vale NSW) - Thursday, Jan 29, 2009 at 20:55
Also the cheaper jumper leads generally have poor cable connection to the clamps, they have a small strip pressed into the clamp to create a slot. The cable is pushed into the slot and squashed to create a connection. They generally end up with a poor quality, high resistance joint at that point.. Go for clamps with connectors crimped to the cable and then bolted to the clamp,, Michael
346633
Reply By: autosparky - Thursday, Jan 29, 2009 at 21:00
run away from those they may rate 200amps but if you try and start anything larger than a lawn mower you will end up with smoking leads. the wire size is roughly a heavy insulated 6mm. for a diesel you need a minimum of 2B&S which is capable of at least starting your vehicle
346635
Reply By: Bullet2Deadly - Thursday, Jan 29, 2009 at 21:05
Hey Steve, used a set of these to try and jump start a commodore with a dead flat battery and they melted.Best used only on low battery's only and not left on to long.Price up some welding leads and good earth clamps and will start any big diesel.
Cheers.
346639
Reply By: Steve - Thursday, Jan 29, 2009 at 21:25
http://cgi.ebay.com.au/800AMP-BOOSTER-CABLE%2FJUMPER-LEADS-HEAVY-DUTY,-BRAND-NEW_W0QQitemZ260351641092QQcmdZViewItemQQimsxZ20090125?IMSfp=TL090125066001r8598
worth a punt?
346642
Reply By: Member - Graham H (QLD) - Thursday, Jan 29, 2009 at 21:36
I made
mine from welding cable from a metal merchant.
They are long enough to go right across two vehicles so I could pull up beside anything and reach the battery.
Crimped and soldered the ends onto the clamps and after 13 years they will still start a diesel.
Also soldered a antispike thingy across the clamps at one end so as to be able to use them on computer controlled cars.
Cost $15 for cable $19 for antispike A couple of hours to make them.
Made that first night taxi driving for two jump starts.
346646
Reply By: toyotabits.com - Thursday, Jan 29, 2009 at 22:26
G'day all, any & every lead needs to be soldered for maximum transfer irrespective of lead amperage, usually by soldering will nearly double amp transfer rate to what they state, if the crimp join is hotter than the cable - that's why they need soldering! maximum transfer, like your garden hose, green hose not much can get through, fire brigade hose lot's can get through, size does matter! Heavier cables rule. I've had
mine 35years, they don't wear out - ever. You get what you pay for, you don't pay much - you don't get much, buy quality first time,
Mine I made from welding cable, soldered, good clamps, regards, aussiedingo
346658
Reply By: Member - Doug T (NT) - Thursday, Jan 29, 2009 at 23:06
Steve
The go is .... don't waste your money, plus they'll be chinese crap.
Get nothing less than 400 amp, heavier if you see them ,
Also a little hint for those with dual systems, if the start battery won't turn the motor just connect the 2 positives using 1 lead only, you do not need the negitive , that should start the engine, I have both my leads cut down to 800mm long
346669
Follow Up By: Steve - Friday, Jan 30, 2009 at 16:27
Chinese crap was what I was wary of in the web-link on reply no.5
800 amp but......dunno????????
Good idea linking the batteries with one cable - I should've thought of that but sometimes you just get a bit flustered. It would've probably worked.
614776
Follow Up By: Member - Graham H (QLD) - Friday, Jan 30, 2009 at 20:26
You can of course put the lttle button on the dash and do it without moving.
Or if you are as lazy as me put a relay in so that when the key turns to '"start"it links both batteries to start the vehicle.
614826
Reply By: Member - Kiwi Kia - Friday, Jan 30, 2009 at 08:35
If you are just doing a quick jump start and there is no underlying engine problem then they will do fine. If you need to crank & crank & ... then get somthing more substantial. As previously mentioned it would pay to check the crimp conections to see that they are good & tight, you do not need to solder if they are good connections (crimping if done right is a far better job).
Most people don't understand that the cable size is not really the problem, it's the duty time and getting rid of excess heat that kills the cable.
346691
Reply By: austastar - Friday, Jan 30, 2009 at 10:10
So the pair I found on the side of the road that are so huge they only just go in a shopping bag and weigh about 4kg could be considered heavy duty?
346709
Reply By: howesy - Friday, Jan 30, 2009 at 17:21
Supacheap have a set of 750amp ones that weigh a ton and will start any 4WD they are excellent and they usually sell them for around the $60 mark (
well worth it)
346761
