Oziexplorer and map files
Submitted: Friday, Feb 13, 2009 at 11:20
buick
I have ozi explorer and have the natmap maps running successfully on it however I have bought great desert tracks which I wish to use when I travel the
Canning stock route this year.I have forgotten how to get oziexplorer to find the GDT maps. I need to get them into a map folder and tell ozi explorer the correct path to find them . Can anyone help me in simple terms or is there someone near
Geraldton WA or
Perth who I can get together with to help me sort this out.
Reply By: wicket - Friday, Feb 13, 2009 at 11:37
If you have loaded them and know where they are then open windows explorer and drag them into the map folder of oxiexplorer which is also in windows explorer
348838
Reply By: The Explorer - Friday, Feb 13, 2009 at 11:51
Hello
Copy both the image files (*.ozf or *.ecw) and the calibation files (*.map) into a folder on your PC. May be easier if you dump them in the same folder you have you natmap series...or the default Map folder under C:\OziExplorer\Maps.
Then open OziExplorer. Under File - Configuration select Map Images tab and in the image file paths select the folder where you maps are. Save . All should be sweet. Main thing is to keep images and calibration files together - this saves some messing around.
348840
Reply By: bgreeni - Friday, Feb 13, 2009 at 12:20
There are many options for how to arrange your map and data files depending on how you want to use them and search for maps. I have reorganised
mine a coiple of times but am still not sure I like the way I have done it - searching now seems to take for ever (but I probably have a couple of thousand maps all up)
If you want some help I live in
Perth (
Scarborough).
Bruce
348846
Follow Up By: buick - Friday, Feb 13, 2009 at 14:11
Bruce
Thanks for your help
Would like to catch up with you to discuss Ozi Explorer sometime when I'm in
Perth.
My email is jshalden@wn.com.au
617108
Reply By: The Explorer - Friday, Feb 13, 2009 at 13:03
..sorry forgot to mention - most importantly - in Configuration under System tab you should select the Map file path - this is the Folder where the map (.map) files are kept (as recommended, images are best kept here as
well) .
OziExplorer will always look in this folder and its subfolders for maps, the preferred choice is to create a folder called MAPS under the OziExplorer folder (default anyway). You could then create subfolders under the MAPS folder to separate your maps into various categories. Even though you can open a map file from any folder the map find function and moving map "find next map" will look in the Map File path folder as the default.
The Map image configuration setting I mentioned before plays a part in the sequence in which images are searched for but having this setto a particular folder is not essential as OziExplorer searches for images in the following sequence..
The link to the image file stored in the .map file is checked
The folder where the .map file is stored is checked
The Image File Paths are checked (if specified)
The Drives which have been ticked are checked
The CDROM drives (if the option is enabled) are determined and checked.
348850
Reply By: buick - Friday, Feb 13, 2009 at 14:07
Ok Thanks everyone for your quick and informative replies.
Got it sorted out now.
Just needed it explained in simple terms
Buick
348861
