Monday, Feb 16, 2009 at 21:25
Quote - "Once you use one you get a good feel for the operating temp of the motor which is handy in very hot conditions (it shows up a lot more variance than the Toyota gauge). So you can back off a little and dave it from operating at high temps and stressing things more than they might like (the Toyota gauge doesn't allow you to do this because it only reacts when it gets REALLY hot and close to dangerous. "
Exactly what I've been saying all along Luke2.
Here's a story for you: I went for a drive today, a 200km round trip.
Temp here today was around 32 degrees, so not extreme.
I kept a close eye on my Engine Watchdog, as I've been having a few issues with the temp creeping up at times.
What I noticed was that the temp was rising sometimes (102 degrees), when I thought it shouldn't be, i.e. cruising along a flat road (no headwind) at 100km/h, then not dropping back when I reduce the speed.
At other times I was really getting up the thing, up to and
well beyond the 110 km/h speed limit, up
hill and down dale, and the temp stayed nice and cool, in the high 80's. I was expecting the temp to rise in these conditions, as that is what usually happens.
Then a bit further down the road, it would start getting hot again.
This would suggest to me that the thermostat is not functioning as it should anymore....it's an aftermarket one 90,000kms old.
Tomorrow I will get a new one from Mr Toyota. That will save me getting the sack for being late for work:-)
So the Engine Watchdog is telling me the story of what is going on under the bonnet, if I take the time to interpret the info it is giving me.
Now I don't know if any of you have experienced a thermostat that has failed and jammed shut. I have.
A few years ago my ex GF blew a hose in her Corolla coming home from work.
She rang me, and I went down there and fitted a new hose and re-filled the coolant. We took off for home, with me following close behind her. She only got about 1 or 2 km down the road before another hose let go....in spectacular fashion, big bang, big cloud of steam, even sprayed my car following behind with coolant.
It seemed obvious that the thermostat was stuck shut, so I removed it, and she continued on home without further incident.
Now a low coolant alarm would have sounded for sure, but the steam and green snot all over the windscreen would have given you an inkling, probably long before the alarm sounded.
The point I'm trying to make here is that the Watchdog has identified a faulty thermostat, and it can be replaced before it ever gets to the chance to fail like that Corolla one did.
A low coolant alarm would only alert you after the event.
Glenn
617682
