flangeless hub supplier in Adelaide
Submitted: Tuesday, Feb 17, 2009 at 10:44
ThreadID: 66042 Views:4888 Replies:7 FollowUps:3
Hi chaps.
Have rung treg trailers asking for a flangeless hub, as I am changing my spare wheel carrier from bush's to bearings.
They didnt know what it was.
Any suggestions for where to get one in Adelaide.
Trains
Reply By: garrycol - Tuesday, Feb 17, 2009 at 11:13
What is a flangeless hub?
Garry
AnswerID: 349457
Follow Up By: Gramps - Tuesday, Feb 17, 2009 at 18:04
Do you work for Treg Trailers :)))
FollowupID: 617787
Reply By: Member - Ed. C. (QLD) - Tuesday, Feb 17, 2009 at 11:49
If ya can't find one locally,
Martins Trailer Parts
in P e rth have 'em, and have an on-line ordering facility...
Confucius say.....
AnswerID: 349462
Reply By: Wayne (NSW) - Tuesday, Feb 17, 2009 at 12:40
I also made the conversion from a bush to bearing set up some time ago and need a hub.
I have since changed vehicles and have made a rear bar, twin wheel carrier now needing two hubs.
I obtained two Holden HQ stub axle and hubs with bearings to suit.
I machined the hub down but left a section so that it is part of the locking system.
Image Could Not Be Found
Hub machined down with locking holes drilled.
Wheel carrier locked with spring load pin into the flange.
This might be a better option than the flangeless hub.
Why I went for the Holden HQ hubs and bearings is that they should be available at a corner store. Compared to the wheel bearings for the Troopie the HQ ones are very small.
Wayne
AnswerID: 349465
Reply By: MEMBER - Darian (SA) - Tuesday, Feb 17, 2009 at 13:54
Mullins Wheels ? - they always had a lot of hub stuff - also try....
S.A. Trailer & Chassis Equipment Pty Ltd
(08) 8262 7170136 Port Wakefield Rd
Cavan SA 5094
(08) 8262 6123
satrailer@senet.com.au
www.satrailer.com.au
AnswerID: 349476
Follow Up By: trainslux - Wednesday, Feb 18, 2009 at 11:43
Hiya Darian,
I tried them, but unfortunately, they dont have any.
They suggested searching the net to find someone who does.
Of which I already have, and come up with the affore mentioned WA crowd, but wanted to shop locally.
Hmm May take up the offer to cut off a flanged section, where are you located, Im near castle plaza Edwardstown.
Trains
FollowupID: 617894
Follow Up By: MEMBER - Darian (SA) - Wednesday, Feb 18, 2009 at 11:55
That was Louie making the offer re machining - just as well - I would probably get horribly tangled up in lathe.
FollowupID: 617896
Reply By: Louie the fly (SA) - Tuesday, Feb 17, 2009 at 18:01
You might have to buy a stock hub and machine the flange off. If you don't have facilities to do it I may be able to assist with the machining.
Louie
AnswerID: 349517
Reply By: Member - Nick (TAS) - Tuesday, Feb 17, 2009 at 18:02
When I built our spare wheel carrier, I machined up one myself.Any machine shop should be able to knock one up pretty quick and not to dear.
AnswerID: 349518
Reply By: Ozhumvee - Tuesday, Feb 17, 2009 at 19:09
The trouble with using a normal cast hub is that they quite often crack when welding to the casting, if not when you are welding but later when in use.
I had a local machine shop make them for $30 each. They were about 3" OD and the internal was machined to take normal holden trailer bearings, seal and grease cap. Just buy a stub axle and bearings from a trailer place.
AnswerID: 349530
