100 ser gearbox swap
Submitted: Friday, Feb 20, 2009 at 17:29
Johnny boy
Hi all,I have a 98 mod 100 ser diesel with an A/M turbo and I was wondering if I would benefit buying an 01 or 02 T.D gear box and transfer case as I have already built my box once and was told it was the smaller prado or hilux box and I would be better off with the later mod box which is larger and stronger, so what I'm asking is what I need to do the swap, I.E: box ,transfer, tail shafts ,coss members ? and is it a drama and are there any differences with ratios as in will I need to do diffs also?
Regards JB.
Reply By: Member - Shane D (QLD) - Friday, Feb 20, 2009 at 19:36
It doesn't have to be later model box, the T/D and 4.5 petrol in the 80 series is bigger than what you and I have got.
I think they have a higher 1st gear and slightly different ratios through out all the other gears (except 4th) but no-where enough difference to warrant a diff change.
I don't think ANY alterations are needed with fitting but not entirely sure.
Shane.
350126
Reply By: Member - Nick (TAS) - Friday, Feb 20, 2009 at 19:44
AFAIK, you need to change bell housing, flywheel, clutch and gear shift levers.Transfer case will fit off your old box if needed(may need one shaft changed).
You have the "R" 151 box and need to look for a "H"151 or "H"150 from an 80 series.
350129
Reply By: Member - Mark E (VIC) - Friday, Feb 20, 2009 at 22:00
Best place to look for this information is:
LCOOL forum
Go to the 100 series section and enquire there as there are many on there who have done both engine and gearbox conversions.
The above post that mentions the R151 and H151 gearboxes is correct, but there is a few variations on what bellhousing, input shaft, and transfer case linkages may be required to avoid cutting extra holes in the floor.
I will watch this space as I'm interested also........
Please let us know how you get on.
Mark
350160
Reply By: Member - DOZER- Saturday, Feb 21, 2009 at 20:45
Ok the box and transfer from a 4.5 petrol 100 is the one to get. If you were to buy an 80 series diesel box and transfer, it would also be good, but get later than 95 as the early ones had synchro problerms. The 80 box will also need a 100 shifter, hence the 4.5 100 box is better....you then need a diesel (turbo or 1hz) 80 or 100 series bellhousing for it and an fzj75 clutch plate to fit in the 1hz pressure plate.
1st, 2nd and 3rd are higher than you have, 5th is lower. You will be doing 2700rpm in 5th at 100 km/hr but it wont break.
Andrew
350309
