damper/bread recipe
Submitted: Friday, Mar 06, 2009 at 18:52
Member - one way ticket (VIC)
does anyone have a good damper/bread recipe for the
camp oven
Reply By: Member - Ian H (NSW) - Friday, Mar 06, 2009 at 19:05
Yes and even a dummy like me can do it.
Put a can or stubbie of full strength beer in a bowl and add self raising flour till you have a bread / damper consistency. Add a little salt if you wish and bake in
camp over till done. About 2 beers time it takes. It should be eaten that day as it doesn't keep
well but ours always disappears before bed time.
If you like you can add sultanas,chocolate, or other goodies and have it as a desert damper. Beauuuutiful.........
Hope you enjoy it. Ian
352605
Follow Up By: Member - Robert R1 (SA) - Friday, Mar 06, 2009 at 22:04
If you drink more beers does it taste better?
620830
Follow Up By: Member - Damien L (Cairns) - Friday, Mar 06, 2009 at 22:48
don't add salt, it causes a chemical reaction and spoils the bread.
620838
Reply By: Notso - Friday, Mar 06, 2009 at 19:12
Yep above recipe is good.
You can add stuff too, like sultanas etc for a sweet damper, Cooked bacon, sun dried tomatoes, olives and cheese for a savoury one.
Good stuff.
If you are cooking it in a
camp oven use a trivet under a flat pan as it stops it buring on the bottom.
352606
Follow Up By: Member - Cram (Newcastle NSW) - Friday, Mar 06, 2009 at 19:49
If you don't have beer you can use ginger beer....
620810
Follow Up By: Axel [ the real one ] - Saturday, Mar 07, 2009 at 10:31
For a sweet damper use lemonade , if want a real special soak a handful of dried fruit [raisins,apricots ect] in some Cointreau for 1/2hr before adding to a sweets damper mix.
620854
Reply By: Von Helga - Friday, Mar 06, 2009 at 22:07
Google COCIA for all your
Camp oven cooking
352653
Reply By: Member - Roger B (VIC) - Friday, Mar 06, 2009 at 23:00
Ask Mr. Google. There are about a million
recipes.there. You're sure to find a good one. Cheers.
Roger......
352663
Reply By: PradOz - Saturday, Mar 07, 2009 at 10:17
here is one they use at the
jondaryan woolshed on the
darling downs. i have not tried to make it as yet so interested in knowing how yours turns out.
into a bowl add 4 cups S R flour, a pinch of salt and 2 1/2 cups
water. mix by using a broadblade knife. work into a ball shape and cut in half and mix again. turn out onto table and work by pressing mixture up (do not mix by pushing down as it takes the air out). fluff it up. sprinkle flour on base of oven and
cook on low heat 45 mins. if when tapped it sounds hollow it is cooked. knock off the flour and slice up and eat - yum yum - let me now how it goes
352693
Reply By: Hairy (NT) - Saturday, Mar 07, 2009 at 11:27
Gday,
Just but packets of bread mix from the
supermarket.
Comes with yeast and all.
352700
Reply By: Best Off Road - Saturday, Mar 07, 2009 at 12:03
This is simple and it works. We made thousands of loaves of this in our Restaurant instead of Bread Rolls. It was a big hit.
Put whatever quantity of Self Raising Flour you reckon you need into a bowl. Good shake of salt. Add
water and stick your mit in and mix it up. Keep adding
water until the consistency is "gloopy", that is between a dough and batter consistency.
Don't worry about lumps, they
cook out.
Jim.
352702
Follow Up By: Lucko - Saturday, Mar 07, 2009 at 16:28
Jim, sounds good. What temp do you
cook at, if using an oven?
620900
Follow Up By: Best Off Road - Sunday, Mar 08, 2009 at 07:41
About 200 to 230 depending on your oven. Has to be hot to get a good brown crust.
Ideally cooked in real bread tins. They are the black ones. Need to be seasoned, then simply brush with oil each time before use. Never wash them.
621034
Reply By: Steve Ellis - Saturday, Mar 07, 2009 at 21:25
COCIA is the guru. Go there Simply the best,better than all the rest,better than anyone. Google COCIA
352824
