Slides to Dvd.
Submitted: Sunday, Mar 08, 2009 at 13:28
ThreadID: 66634 Views:3103 Replies:4 FollowUps:3
Hi what is the best way to put slides on to a Dvd.Thanks in advance.
Reply By: Crackles - Sunday, Mar 08, 2009 at 13:47
I've just got a Cannon scanner that has a special slide carrier. Bit time consuming but once digitised can burn to DVD.
Check out Slide Scanners for some examples. One like this special unit can do 4 at a time if you have losts to do.
Or the other option is to give it to the pros to do like this mob.
Cheers Craig............
AnswerID: 352907
Follow Up By: Geoff (Newcastle, NSW) - Sunday, Mar 08, 2009 at 14:18
I have to agree with Crackles.
I bought a scanner that does both slides and print negatives.
It's taken me about 12 months of part time scanning and I'm about half way through the project at the moment!
It's way cheaper in my case to do it myself even factoring in the cost of the scanner.
I think I was quoted somewhere between $1.50 and $2.00 per image.
At $1.50 per slide it would have cost me about $1,600 to get one trips worth converted to digital!
Geoff
Geoff,
FollowupID: 621109
Follow Up By: Geoff (Newcastle, NSW) - Sunday, Mar 08, 2009 at 14:26
Whoops, sorry gents too many "0's"
It should have been $160 NOT $1,600
No idea were my head was when I typed that number!
Geoff
Geoff,
FollowupID: 621110
Reply By: OzTroopy - Sunday, Mar 08, 2009 at 14:01
Mate had some done recently for only 0.50c each .... but that was a special deal .......
The camera shops normal price was 2.00 each .....
Anyone with a lot to do would probably be better off buying one of those scanners crackles posted links to ....
They are probably the same gear the shops are using but you could work on the images to YOUR satisfaction ... based on the fact that it was a two week + wait for the job to be done .... must be a hands on ... not automated computerised task.
AnswerID: 352911
Reply By: Sigmund - Sunday, Mar 08, 2009 at 14:02
Yep.
One cheap and cheerful technique is to mount and illuminate your slide and take a close up with a DLSR.
But if you want a good job hi res scanning prob with noise reduction is the go.
AnswerID: 352912
Follow Up By: Member - John and Val W (ACT) - Sunday, Mar 08, 2009 at 18:09
"Invented" a slide mount that slips over the front of the lense of my digital camera. Use macro setting for a quite impressive result, helped along by any amount of work in Photoshop or similar, as our slides are old and some have deteriorated. Cheap and effective.
J and V
- Albert Einstein
FollowupID: 621133
Reply By: Motherhen - Sunday, Mar 08, 2009 at 15:57
I have been watching the slide and negative scanners on Deals Direct. Prices vary according to daily specials or freight free days (price can be higher).
http://www.dealsdirect.com.au/search/scanner/
Has anyone tried these?
AnswerID: 352932
