ANOTHER grenade issue
Submitted: Saturday, Mar 14, 2009 at 16:30
Kiwi and Grenade
Might be a big issue, might be a little issue so I need ya help if ya know what it might be.....(for those who dont know...Grenade is our 01 GUIII)
I noticed it today in 5th gear - and it happens in every gear - but there is a vibrating / rattle type noise coming from somewhere but it stops once it goes into neutral or I push the clutch in. There is no difference in the feel of the clutch or the gears ...
Got any idea where the noise is coming from??? Im thinking its a gear thing, but it happens in every gear so its probably not just one gear.....
Reply By: Pajpower - Saturday, Mar 14, 2009 at 16:38
some cars have a light come on when a service is due, Nissans just make a noise :)
hope ya sort it :) (cheaply)
353973
Reply By: Member - Bentaxle - Saturday, Mar 14, 2009 at 16:48
This may be a long shot but it could be the thrust bearing on its way out.
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
353976
Follow Up By: Kiwi and Grenade - Saturday, Mar 14, 2009 at 17:37
thats what Dad was thinking when I put it to him.....
622147
Follow Up By: fisho64 - Sunday, Mar 15, 2009 at 02:38
not the thrust bearing as the noise would START not stop when you push it in. Its likely the spindle bearing or input shaft bearings
622211
Reply By: Notso - Saturday, Mar 14, 2009 at 17:23
These, if it's the 3.00 diesel, have a dual element clutch and they have had problems with them rattling or "knocking", I have heard that the spigot bearing gets a rattle as
Suggest you have a look on
Site Link
There are a lot of fellas there with them and you'll probably get an answer.
353982
Reply By: toyocrusa - Saturday, Mar 14, 2009 at 17:24
Hi.Could be something to do with the tailshaft or uni joints. My 04 Prado has the transfer lever vibrate a bit but that is coming from inside the box and is a common thing. If yours goes away when no load on the drivetrain then I would check the first suggestion. Bob.
353985
Follow Up By: Member - Russnic [NZ] - Saturday, Mar 14, 2009 at 20:41
That was my initial thought to, then same sound under load/ off load.
Easy to check the uni's
You are a tiger for punishment kiwi
Yea Yea, the same thing can happen to Landrovers Toyotas Fords have had it all happen, maintanence ie a bit of gease helps.
Don't know much about Nissan, hubs engaged or not? is it full time 4 wd ?. Might be front shaft uni's
Just my thoughts
Russ
622188
Reply By: Thermoguard Instruments - Saturday, Mar 14, 2009 at 17:43
Dual-mass flywheel on the way out would be my bet.
Ian
353989
Reply By: Bonz (Vic) - Thoughtfully- Saturday, Mar 14, 2009 at 20:37
Laura, check the exhaust where it goes thru behind the passenger wheel
well, it may be loose.
354020
Reply By: Member - 120scruiser (NSW) - Saturday, Mar 14, 2009 at 21:03
Sounds like a new dual mass flywheel is on the cards. Expensive job too.
354027
Follow Up By: donks1 - Saturday, Mar 14, 2009 at 23:32
Hi all
Yeh its not the place you want to be looking ( expensive ) but more than likely the cause
If it is, change to a solid flywheel kit.
Good luck
Laura
Donks1
622204
Reply By: landed eagle - Saturday, Mar 14, 2009 at 23:01
N oises
I n
S elector
S hifting
A re
N ormal!
354043
