Sand Anchor
Submitted: Monday, Mar 30, 2009 at 20:14
ThreadID: 67347 Views:7479 Replies:10 FollowUps:11
Was chatting to a mate (who is very proficient with a welder) on Saturday and talking about sand anchors and said "Could you make one for me?" Said I needed it by end May. I took some bit of steel over to him later althugh he has a whole heap of scrap lying about
He called this arvo and asked me to come over to look at the my Sand Anchor.
Will test it in the next couple of weeks after I recover from recent surgery.
Image Could Not Be Found
Reply By: Wayne (NSW) - Monday, Mar 30, 2009 at 20:31
Willem,
Nice sand anchor.
If I might be so bold as to suggest a lock ring that is free to move up and down the long shaft.
When the hinged part of the anchor is retracted against the shaft the ring would slide down from the top of the shaft, fit over the tip of the anchor to hold the anchor in place.
Wayne
AnswerID: 357111
Follow Up By: Willem - Monday, Mar 30, 2009 at 20:38
Thanks Wayne. It is held by a rubber ring at the moment :-)
FollowupID: 625192
Reply By: Best Off Road - Monday, Mar 30, 2009 at 20:32
Willie,
That looks, to me, to be very similar to a "Danforth" boat anchor. Not surprising really, a Danforth is designed to dig into sandy bottoms to hold boats of substantial size against the force of tides and wind.
In essence I suppose the principle is the same.
My estimate is that a "Gal" Danforth Anchor of that size would set you back about $50.
Jim.
AnswerID: 357112
Reply By: Member - DAZA (QLD) - Monday, Mar 30, 2009 at 20:33
Hi Willem
Looks ok to me, it should dig in and hold, is it very heavy? looks similar to a boat anchor without the pivot.
Daza
AnswerID: 357113
Follow Up By: Willem - Monday, Mar 30, 2009 at 20:50
Daza
Weighs 13 kg
Should be strong enough. Not quite sure if ther angle is right so it will be tested in a sandy creekbed somewhere closeby
FollowupID: 625196
Reply By: Member - Footloose - Monday, Mar 30, 2009 at 20:45
Hi Willem. I had the commercial product here for ages and never actually had the occasion to use it in anger.
It was heavy.
It was difficult to stow and carry.
It worked brilliantly in sand (especially wet sand).
It was useless in stony country.
Good luck with your version. It's got to be better than digging a hole for the spare ?
AnswerID: 357117
Follow Up By: Willem - Monday, Mar 30, 2009 at 20:58
Hi Footy
Yep, going to see a bit of sand this year and burying the spare isn't fun when things go pear-shaped. Been there...................lol
Hope this contraption works. Has to be stowed on the front of the trailer.
FollowupID: 625199
Reply By: Geoff (Newcastle, NSW) - Monday, Mar 30, 2009 at 21:09
Hi Willem,
That looks great!
I have a DVD here made by Peter Ikin from Cape York Connections on a trip down the Canning Stock Route.
In it they test a commercial sand anchor to winch a vehicle over one of the dunes.
They ran into a problem were the sand was way to soft for the anchor to actually gain a purchase.
It might pay to test yours in a couple of different applications to be sure of its success.
Geoff
Geoff,
AnswerID: 357119
Reply By: Member - Mick O (VIC) - Monday, Mar 30, 2009 at 22:29
Big W,
why a sand anchor when you're already carrying the best sand anchor possible, a spare tyre! Failing that I'd reccomend an 80 or 100 series Toyota or an 02 GU parked on the other side of the sandhill lol!
Cheers Mick.
AnswerID: 357152
Follow Up By: Willem - Monday, Mar 30, 2009 at 22:37
Go Break yer back, Mick....Been there done that.
I need all the gear as I do not like to rely on others to get me out of strife should I find myself there.
FollowupID: 625240
Reply By: Member - Kiwi B - Monday, Mar 30, 2009 at 23:15
Willem,
Had occasion to use one of these once a few years ago. I've got a feeling it had an eye on the back end of the shaft and was fitted with a tail-rope 2-3metres long. Proved to be quite handy as it was capable of burying itself pretty deep, and you just pull it backwards.
Good luck,
AnswerID: 357160
Reply By: Blaze (Berri) - Monday, Mar 30, 2009 at 23:59
Are you hiring it out mate, LOL
Can see I time I might just like to use it coming up. If not guess I will make one, lets see some more pics.
AnswerID: 357173
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 07:28
Nah! I think I can safely lend it to you as it is very well built and strong and probably Blaze-proof.
FollowupID: 625271
Reply By: Member No 1- Tuesday, Mar 31, 2009 at 07:46
going by the size of the finger at the top and comparing that to material size it is made of, looks a bit light on to me
doesnt look as if it would hold together getting my empty LC out...let alone yours with all the stuff you carry...
what do you think?
AnswerID: 357192
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 08:34
Still have to test it as mentioned above
It is supposed to be an anchor and not a 4 in 1 backhoe bucket!
FollowupID: 625288
Follow Up By: Member No 1- Tuesday, Mar 31, 2009 at 09:14
how heavy does your nissan weigh when full?...i'm thinking you may need that 4 in 1
FollowupID: 625301
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 15:26
FYIyoung fella....my GQ weighs in at 2780kg, (full fuel and stuff and with humans and dog on board), which is 20kg under GVM.!!!
But it's the trailer that is the heavy bastard....LOL
FollowupID: 625349
Follow Up By: Member No 1- Tuesday, Mar 31, 2009 at 15:50
know what you mean...we always take too much shi....gear
FollowupID: 625355
Follow Up By: Member No 1- Tuesday, Mar 31, 2009 at 15:51
also...bout time you did some weeding
FollowupID: 625356
Follow Up By: Willem - Tuesday, Mar 31, 2009 at 16:29
Nah...just the summer grasses...first frost and they will be gone....I cannot live by numbers and meticulous gardens....there has to be a bit of untidyness around
FollowupID: 625366
Reply By: Bushed-Tracker - Tuesday, Mar 31, 2009 at 16:39
I just get the 'Dragon' to grab the end of the wire in her teeth and dig her heels in.......LOL
AnswerID: 357276
