Thursday, Apr 09, 2009 at 15:53
Hi Dave,
You are absolutely entitled to ask for information regarding recalls from any Holden dealership regarding any outstanding recalls for your vehicle and once asked the dealership is obliged to follow up.
When the injector recall (as opposed to the injector seal recall) came out there were huge issues with supply from CAT who make the injectors. NB this was a world wide recall. In many cases it was only when customers raised hell that Holden would supply from a reserve stock.
Unfortunately even if the injectors have been replaced there can still be problems. Irecall several cases where we had comebacks from faulty "new" injectors. If your problem is one of these then the dealer should be able to get approval to replace a faulty injector as a supplementary claim.
Going back to the oil- the high pressure pump operates from oil flow and pressure. If the cold rated viscosity is too high the pump will not work causing cold start issues.
FYI the first digit in an oil rating ie 5 in 5w30 is a measure of the oils ability to flow through a series of small holes at 0degC.
If you live in a cold climate area you could run the engine on 0w30. many modern engines run on this oil.
One of the issues with the 4JX1 is the bores in the cylinder head into which the injector sleeve is fitted. Sometimes even with new sleeves and injectors fitted there can still be
fuel bypassing into the coolant or oil. It is the latter that triggered the recall because if the
fuel fills up the sump the engine can feed directly off the fuel/oil mix through the pcv system and the result is the engine runaway situation. We had a few of these. Quite exciting on a road test.
SO
keep an eagle eye on your coolant and oil levels. If either show an unexplained increase (NB only check when cold) find out if there is any
fuel present. If there is talk to your local Holden dealer. If it can be demonstrated that the fault is still recall issue then it has to be done again and in some cases Holden have come partially to the party in replacing the cylinder head. But i did have to fight really hard!!!
There are also issues where the
fuel pressure sensor and oil sensor can leak down the inejector/engine harness corrupting the information to the ECU. this can cause all sorts of issues that can be hard to diagnose.
When the 4JX1 is going
well they go really
well. However there is always the threat of all these problems occuring or re occuring. You might want to consider changing to a 4WD with a simpler injection system.
All the best
Mike
626987
