Info please on Nissan Patrol 3.0LT Turbo Diesels???
Submitted: Sunday, Apr 19, 2009 at 19:57
just goin
Looking at upgrading our current vehicle for a trip around OZ and like the look of the Nissan Patrols 3.0LT Turbo Diesels but heard that a certain release of these particular models had a problem with a shaft breaking in the engine.
We will be able to afford a used model around 5 years old maybe and would appreciate any comments or history on these vehicles that would be useful for us to consider.
Reply By: Member - Graeme W (NSW) - Sunday, Apr 19, 2009 at 20:04
Try searching the
forum for ZD30. There's been plenty of threads about the 3lt Patrol motors.
Graeme
360415
Reply By: On Patrol & TONI - Sunday, Apr 19, 2009 at 20:25
just goin
Many, by no means all, suffer from turbo over-boost that burns out pistons,
mine included. Very expensive to fix.
The new Common Rail system in latest models MAY have fixed this problem ?????
Read all you can before making your decision, including the Patrol Forums, it may just save you from an expensive repair bill.
Cheers, Colin.
360420
Reply By: garrycol - Sunday, Apr 19, 2009 at 20:57
Don't do it - even the newer ones are blowing as they reach 100K+ kms - it is just not worth the risk.
Garry
360426
Reply By: Member - extfilm (NSW) - Sunday, Apr 19, 2009 at 21:04
just don't go a nissan and you will be a happy man for ever
360429
Follow Up By: Willem - Monday, Apr 20, 2009 at 04:00
Hey!!!! Go wash yer mouth
young fella!!!....LOL. Just because you did acrobatics with yours.............................
628241
Reply By: Member - Troy and Kate - Sunday, Apr 19, 2009 at 21:50
G'day Just goin,
We are just about to go around Oz and have picked up a Nissan Patrol 4.2 Turbo Diesel 2001, it has nearly 230,000 on the clock and goes like a dream. Our mechanic has gone right over it and he said that it was a good buy for the price, (His a member of the Nissan 4WD club, Knows his stuff!!) A lot of my mates told me to stay away from 3.0lt, as they will end up costing me a lot of money, due to motor problems. Being new to this, i did a lot of homework before i handed over my money,we have had our rig since NOV 08 and all is
well, We are towing a Jayco Expanda 18 footer, so the extra power is good. We average between 17 to 20lt per 100klm's, depending on the travelling conditions.
I hope this helps.
HAPPY DAYS,
Troy and Kate.
360442
Follow Up By: Member - Malcolm (Townsville) - Sunday, Apr 19, 2009 at 23:49
[so the extra power is good]
Actually Troy, you get MORE POWER from the 3 litre engine !
3.0 litre turbo diesel DOHC inline 4 cyl with intercooler.
116 kw @ 3600 rpm, 354 Nm @ 2000 rpm, 17.9 compression ratio,
2953 cc, 96 mm
bore, 102 mm stroke.
4.2 litre turbo diesel OHV inline 6 cyl.
114 kw @ 3600 rpm, 330 Nm @ 2000 rpm, 22.7 compression ratio,
4169 cc, 96 mm
bore, 96mm stroke.
Malcolm
628230
Reply By: Member - Malcolm (Townsville) - Sunday, Apr 19, 2009 at 23:41
Hi just goin
I bought a 2003 ZD30 Patrol with 100K on the clock three years ago. Did 50K towing 2500kg caravan and never had one problem with it. Just sold it this week for $19,500.
Last October I wanted to upgrade and bought a 2005 ZD30 Patrol with 110K on the clock. Travelled less than 2K when I blew the motor up. There is a couple of threads on this
forum started by me titled "Four Cracked Pistons" this will give a completely unbiased view from an owner from both sides of the fence.
I rebuilt the motor myself and, with the help of patrol4x4.com/
forum now understand what causes these engines to overheat (and burnout pistons). Fit an Exhaust Gas Temperature (EGT) Gauge and watch the temps.
Just yesterday I did a test towing an empty car trailer at 100 km/hr both in and out of overdrive. What did I find - and I have been guilty of this as
well - using overdrive is most probably what caused my piston to blow - DO NOT TOW ANYTHING WITH OVERDRIVE ENGAGED !! The exhaust temperatures was going over 500 degrees C lagging along at 2200 rpm in overdrive. Shifted out of overdrive and rpm went to 3200 and temps dropped back to around 440 deg C.
Overboosting is what causes these engines to overfuel causing the higher EGT.
Link on ZD30 Engine Problems posted by Chaz. He has helped me to understand that these engines are not as bad as some people make them out to be.
One things for sure, you'll certainly notice the difference when you are filling up at the bowser. I get 10 litres/100km running in and out of town in
mine.
Next Thursday I have a 5000 km round trip down to NSW and back towing a camper trailer with my rebuilt engine. Good test for it.
Malcolm
360458
Follow Up By: Member - Troy and Kate - Monday, Apr 20, 2009 at 01:18
Hello
Malcolm,
I have never driven a 3.0lt ,so i really should comment on them.
When it comes to power and all that information that you supplied i am no expert at all. thanks anyway for you help, it all goes up top and when i need it ,i hope i can recall the information.
Thank's
Troy
628238
Reply By: GregF - Monday, Apr 20, 2009 at 11:41
Howdy Just Goin.
I have one for sale. 2004< lots of good stuff. Let me Know where u are if u want to have ayarn.
360501
Follow Up By: just goin - Monday, Apr 20, 2009 at 15:21
Hi All,
Thanks for all of that great feedback and info on these particular vehicles. Wish we had oodles of spare cash to find out for ourselves if we like the Patrols but given the varied feedback we might not bother and stick with our current vehicle.
1999 Holden Rodeo 4WD 2.8L Turbo Diesel Dual Cab - we havent had any troubles with it at all in the 5 years we have owned it but did consider updating for the comfort factor ONLY really for the front passengers as
well as the 2 kids in the back....
Might just leave things as they are now for the time being
Thanks again for all your advice!!
628327
Follow Up By: Member - AJB (VIC) - Wednesday, Apr 22, 2009 at 18:34
Wise move keeping the Rodeo. I had a 92 dual cab, sold it in 99, then bought a GU 3-0. I wish I still had the Rodeo. Simple, bulletproof and reliable. All things the Nissan ain't.
628656
Follow Up By: Member - Graham H (QLD) - Thursday, Apr 23, 2009 at 18:24
If you are changing for comforts sake you will be wasting your money buying a Patrol.
I had one thought it was Ok then took a 2005 GXL Cruiser for a run over same rough bit of road i went over to get to the dealer.
Wife didnt want to spend the money until we went for the ride.
Got back to the dealer and out came the chequebook..
In saying that we bought it for long distance travel with a van and not off road bushbashing.
628847
Reply By: bilgolabands - Thursday, Apr 23, 2009 at 16:13
Just Goin,
We have owned a 3.0 litre Patrol for about 4 years now (Series 3) after having owned Patrols since 1987.
The GU is the best of all and they have all been very good.
I became sick of the rantings of some of the contributers (Kiwi Grenade particularly) to these forums and began questioning 3 litre owners that I met in car parks, tracks and
trails as to how they felt about their vehicles.
About 79 owners later they all enjoy their trucks and one had his Series 1 motor burn out a piston and stop. He commented Nissan had picked up the bill in full (out of warranty) and he knew of 3 other owners with similar stories. All repaired by Nissan.
I believe the problem revolved around insufficient oil and an over rich run on high speed lengthy stretches.
My mechanic, who owns one, says we all need to watch the Mass Air Sensor (or thereabouts) and do not use non Nissan air filters. CRC make an aerosol spray to clean those sensors and the necessity to keep it clean it applies to ALL turbo diesels.
If you have a bloke come up to you and ask if you a happy with your 3 litre it may
well be me.
Bilgolabands
361095
