Redline Oil ??
Submitted: Monday, Apr 20, 2009 at 16:35
ThreadID: 68044 Views:4321 Replies:6 FollowUps:0
Hi all,
New to the website and so far has been very helpful. The wife and i are planning a trip around Oz starting latter this year, we have sold the house and bought a Nissan Patrol 4.2TD that has been well set up for touring. I read an article about Redline Oil saying that it's good stuff and you can get upto 25000 kms before having to change it. have done some research and from what i can find it seems to be fairly good, does anyone out there know anything or has used this brand of oil?
Cheers Simo
Reply By: Bushwhacker - Monday, Apr 20, 2009 at 16:43
Hi Simo & Stace, not an expert, and dont know of this oil. However, I have been a mechanical fitter for 40 years, and find that often it is not just the quality of the oil, its whats IN the oil that might cause you grief. Spent most of my days repairing gearboxes, (industrial), and 'dirty' oil was #1 killer I reckon. Diesels are not renowned for being a 'clean' engine. Just a thought.... have a great trip, 'whacker
AnswerID: 360552
Reply By: ben_gv3 - Monday, Apr 20, 2009 at 17:09
Redline oil is the top-shelf oil to use. It's used by a lot of racing cars etc.
I wouldn't run it in a car since it's not very economical, and I've been told by a diff rebuilder not to bother to use it as well, for the reason of price (I changed my diff ratios and put in an ARB).
I would rather just change the oils at the recommended intervals. For the diesel I would just buy good quality oil without being too extravagant - Penrite maybe?
AnswerID: 360555
Reply By: RV Powerstream P/L - Monday, Apr 20, 2009 at 17:13
Red Line is a synthetic and is very expensive.
If you go online and look up the specs on Amsoil you will find it every bit as good as Red line and not as expensive.
J&J Diesel Service stocks Amsoil and you can contact Jason on 0438674050.
Amsoil in imported from USA.
Ian
AnswerID: 360556
Reply By: kiwicol - Monday, Apr 20, 2009 at 17:35
The TD 4.2 is old school techknoldgy, and doesn't matter what type of oil you use it will still have to be serviced at the 5000k mark as per the original service specs. I have the same motor, as do many other users on this site and all swear by them, but wouldn't go over the 5000ks service intervals. Sometimes cant be helped when travelling, but rule of thumb. Col
AnswerID: 360560
Reply By: D200Dug- Monday, Apr 20, 2009 at 18:32
One of my mates is a tech ( electrical engineer ) working for Toyota he swears by the stuff but he also drives a Subaru WRX (the go faster Megadeath special version :)
Personally I think change oil often and use good quality oils would be the best option.
AnswerID: 360566
Reply By: Flywest - Wednesday, Apr 22, 2009 at 17:35
25,000 km extended oil change intervals are possible, BUT (n.b. its a big but), NOT without several modifications to oil filtration AND having regular used oil analysis performed on the oil during it's lifespan to protect against excessive wear.
1. Youd need to add a sub micron bypass filter to remove a lot of the carbon (soot of combustion) from the oil - otherwise it becomes like a grinding paste and wears your cylinders and rings and bearinsgs etc.
Sub Micron means less than ONE micron in size. you standard filter allows particles about 25 microns or less in size to pass - and this onclused all the soot of conbustion (carbon particles).
2. Another way to remove this soot of combustion is with a centrifuge oil filter, like the Land Rover Doscovery T diesels run standard.
3. You COULD run both sub micron bypass AND centrifuge filters in addition to your stadard oil filter/
4. You still need to take samples of the oil and post them off to the lab (CATERPILLAR HAVE SUCH A LAB HERE IN WA) at westrac equipment - for used oil analysis to see if the oils lubricity and viscocity remain within specification for youre engine and to check for excessive wear metals presence as well as soot buildup levels.
5. Another reasn to run the Used Oil Analysis - is to check the condition of the oil "add pack", chemicals added by the manufacturer - to neutralise acids formed by combustion and blow by of combustion gasses past the rings and into the sump and it's oil.
These USED to be calcium in large mounts >3500ppm in some cases, but now with more modern diesels, and the advent of catalytic converters in the exhaust systems - companys are re-formulating their oil toi use much lower amounts of molybednum as a neutralising agent in their diesel oil.
One problem with that - is that the moly has a break down temperature a LOT below what some of the older Japanese turbo diesels normal operating temperature runs at and as a result these new fangled synthetics don't last the distance in some of the older Jap T diesels (Like my old 4.2liter 1HD-T Cruiser) and at standard 5000 km change intervals - i get used oil analysis saying that high oxidation levels are detected (burnt oil from excessive heat).
Personally I've given up trying to get extended oil change intervals - and I have sub micron bypass filtering fitted - and use expesive Mobil Delvac 1 fully synthetic oil, as well.
The used oil analysis results consistently come back telling me that the add packs used up within 5000 km's and to change oil.
What cost a new diesel engine - versus what cost regulat 5000 km's oil changes?.
You can read a LOT (and ask questions) about extended oil change intervals & Redline oil etc at BITOG forums (Bob Is The Oil Guy) if you google search for it.
Some people do get 25,000km intervals on their oil, BUT they also do the relevent testing to make sure they aren't causing damage to their engines - and it seems aLOT of the new oils are better suited to the NEW US manaufactured diesels than they are to the older Japanese diesels.
There are findamental differences in design between thesetwo types of T diesel engine in the distance down from the corwn on the piston to the first compression ring - with the USA engines having the top ring much closer to the top of the piston and the Japanese design having them much lower down.
Usual operating temps are a lot different too.
Some of the best oils out of the USA do well in USA designed T diesels, and sometimes not so well in Japanese designed ones.
Principally it is due to the difference in ambient operating temps and the type of add pack added to the oil.
Extended oil change intervals isn't smething to get involved in unless you know EXACTLY what your doing in my humble opinion - speaking as someone who has dabbled a bit in this area!
AnswerID: 360901
