Tyres - how much bigger?
Submitted: Wednesday, Apr 22, 2009 at 17:02
beelzebug
We're off to the cape in early July in the wife's Navara. It came standard with HT tyres in 255.70.R16's, so these will have to go.
I want to go AT's in a slightly bigger size, as replacements will be more available if needed while up that way.
I'm leaning toward Bridgestone 694 LT's in 265.70.R16.
Is there anything to be gained to going up one size to 265.75's?
Looking forward to good advice as always.
Gary
Reply By: Geoff (Newcastle, NSW) - Wednesday, Apr 22, 2009 at 17:32
A little more clearance under the diffs for starters.
You should also get a little more footprint out of them when deflated a bit for offroad work.
Geoff
| Geoff,
360899
Follow Up By: Member - Mfewster(SA) - Wednesday, Apr 22, 2009 at 18:59
More footprint when deflated? Now I'm not sure about this and welcome the views/experience of others. The general theory that I have heard developed is that wider does not give better footprint deflated as the "bagging" that gives the extra footprint takes place longitudinally and narrower tyres "bag" longitudinally better than wider tyres.
628668
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Apr 22, 2009 at 19:05
I had a bit of a play with my Troopy, a tape measure and a couple of tyres. A 7.50 x 16 and a 285-75 x 16
The 7.50 x 16's bagged about 8mm longer but are narrower than the 285-75 x 16's.
Therefore length x width gives area and in my test similar length times greater width equals more surface area.
Geoff
| Geoff,
628672
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Apr 22, 2009 at 19:07
is ti happy hour at the Lambton hotel is it Geoff????
alls good mate.....hahhahahahaha. :-))))
628675
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Apr 22, 2009 at 19:13
No but it's beer o'clock whilst watching the news!
How was Evans Head ya cheeky
young bugger?
And do you have written permission to use my photo in your profile??
Geoff
| Geoff,
628678
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Apr 22, 2009 at 19:15
all he needs ( in the pic) is a fishing rod.....lol!!
628680
Follow Up By: Member - Mfewster(SA) - Wednesday, Apr 22, 2009 at 19:22
Hi Geoff.
Now this is interesting. What is the width of the narrower tyre? If I understand the markings you gave, you gave the aspect ratio and the diameter.
628684
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Apr 22, 2009 at 19:32
I actually mixed my metrics and imperials just like any good tyre thread!
The 7.50 x 16 is the standard 7.5" wide rag tyre fitted on split rims to Troopy's ex factory. (About 190 mm wide in metric parlance) They are I think equivalent to something like a 235-65 or 70 x 16.
The 285-75 x 16 is as stated, 285 mm wide and on a set of 100 Series factory alloy rims.
And I made the length measurements in millimetres!
Have I confused you yet?
Geoff
| Geoff,
628687
Follow Up By: Member - Mfewster(SA) - Wednesday, Apr 22, 2009 at 20:03
I'm a little confused, but trying to stay with you. How much did you deflate the tyre? I would have thought that a deflated trye would give considerably more than 8mm increase in track length.
628695
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Apr 22, 2009 at 20:15
I can see were you are confused, both tyres deflated to 16psi.
There was 8mm difference in their length when deflated.
The 285-75 x 16 was say 300 mm in length when deflated to 16 psi, the 7.50 x 16 was say 308 mm in length when deflated to 16 psi. (Those numbers aren't correct as I can't find my notes but I think you'll get my drift)
That's how I arrived at the notion the wider tyre had the greater footprint even though its footprint was 8mm shorter than the narrower tyre.
Geoff
| Geoff,
628700
Follow Up By: Member - Mfewster(SA) - Wednesday, Apr 22, 2009 at 20:19
OK Geoff, now I follow. That looks convincing.
628702
Follow Up By: Malleerv - Wednesday, Apr 22, 2009 at 21:07
Taller tyres give better/longer footprint and more so when run at low pressure.
Also, most of the time a wider tyre is also taller in spec than a narrow tyre in the same profile range thus giving a wider and longer footprint.
Matt
628710
Reply By: Member - Mark G Gulmarrad - Wednesday, Apr 22, 2009 at 18:01
Gary
i have Cooper 265/70 R16 on my navara........no problem running that size. they have done a great job on and off road,cheers.
360910
Follow Up By: Member - Chris & Debbie (QLD) - Wednesday, Apr 22, 2009 at 19:18
Gary
and others, just be aware, that not all Coopers are rated the same even for the same type, such as ATR's, which I assume you have. THe 70 profile is only passenger construction, you need to go to 75 profile to get light truck tyres.
I found the ATR's on my D40 staked easily, and after looking into it, found this information so ended up changing to 265/75 R16 which are 10ply light truck contruction.
Chris
628681
Follow Up By: beelzebug - Thursday, Apr 23, 2009 at 08:36
Thanks Chris,
I was told by the tyre dealer that the 70 profile Bridgestones 694's he quoted is LT construction.
I will have this confirmed before ordering.
Gary
628757
Reply By: Isuzumu - Wednesday, Apr 22, 2009 at 18:09
In Qld you are only allowed 15mm over the palacard size so the 265/70 x 16 are 14mm over dia.
360913
Follow Up By: Lex M (Brisbane) - Wednesday, Apr 22, 2009 at 19:08
Careful Bruce. We cant have a 4wd running around that's legal now, can we?
628676
Reply By: Patrol22 - Wednesday, Apr 22, 2009 at 18:36
Gary - I'm running 265/70R16 BFG ATs on my D40 and they (and the vehicle are performing
well). Can I suggest that if you have already done so that you fit a set of
underbody guards like those available from TJM. I understand that a
Brisbane company called Tosca Industries also make them. The existing FUG on the Navara is crap to say the least and you have a much better than even money chance of damaging radiator, intercooler, tx oil cooler - maybe the lot - if you don't have proper protection for this trip.
Pete
360919
Follow Up By: Patrol22 - Wednesday, Apr 22, 2009 at 18:36
oops that should read "if you have not already done so"
628658
Follow Up By: beelzebug - Thursday, Apr 23, 2009 at 08:33
Thanks Patrol22, I have the front plate from TJM ready to go on the car next week.
628756
Reply By: Robin Miller - Wednesday, Apr 22, 2009 at 18:51
I'd go for taller but narrower 235/85/16 LTs if its the diesel Navara.
360921
Reply By: Malleerv - Wednesday, Apr 22, 2009 at 21:02
According to the bridgestone web site tyre specs
255/70-16 has an OD of 764mm
265/70-16 has an OD of 779mm
265-75-16 has an OD of 808mm
As you can see just going wider you are also getting a taller tyre and more so with at higher profile tyre such as the 75 series.
I see plenty of navara's with 265-75-16 tyre's around here. They seem to be a more common size if you need a replacement too.
Matt
360950
