Concealing holes in dashboards etc.
Submitted: Friday, May 01, 2009 at 13:55
ThreadID: 68414 Views:16508 Replies:10 FollowUps:0
Hi all,
I'm in the process of re-arranging things in the Patrol and when I remove such things as the old hands free mobile phone cradle which is mounted on the centre console, I'd like to fill the screwholes to make things look at least reasonable!
Does anyone happen to know whether there is some sort of plastic button/filler/whatever to conceal screw holes in dashboards and other interior plastics? And of course, where do you get such?
Andy
Reply By: GoneTroppo Member (FNQ) - Friday, May 01, 2009 at 14:02
Depends on how good you want to make it look.
I've used those plastic goof plugs you get for garden watering systems for when you need to plug up a hole in the poly pipe.
They seem to fit a screw hole really well and cost next to nothing.
Downside is they only come in black
AnswerID: 362605
Reply By: Member - Lionel A (WA) - Friday, May 01, 2009 at 14:16
Hi Andy,
Try those little plastic screw head covers, cabinet makers use them all the time. Any hardware will stock them, range of colours, about $2-3 per bag of 50.
Fix them down with a dab of acyrlic gap filler so when set remain relatively flexable.
Cheers.....Lionel.
AnswerID: 362606
Reply By: Ron173 - Friday, May 01, 2009 at 14:16
Go look in supercheap, they have the 'champion' racks with the small packets, there are heaps of different types n colours of plugs.
Mainly designed to replace the ones that fall out of footwells etc. but i'm sure you would find something suitable.
Plenty rubber grommets too, good for the larger hole.
Ron
AnswerID: 362607
Reply By: Tenpounder - Friday, May 01, 2009 at 14:22
Hi there. I have bought a kit called a 'dashboard vinyl repair kit' which is a set of little pots of colour (ie mix to match what's there) and some goo that makes a paste which you mix with the colour, and which sets hard.
In the old days (when I was a lad!) cars had vinyl dashboards and nice vinyl padding (black usually, with nice yellow foam underneath which showed up when the vinyl cracked), and these kits were a way to delay the inevitable.
I'd try the usual Repco etc.
Hope this helps
Chris (SA)
AnswerID: 362609
Reply By: garrycol - Friday, May 01, 2009 at 14:44
That is why things like double sided tape and velcro with sticky stuff on one side or even contact adhesive should be used so you dont have the problems with holes - these really detract from a car when you go to sell.
But to the question all of the above suggestions can be used but none work really well - yes that fill the hole but often make it more noticeable than it was with just the holes. I look for cheap little accessories like a phone holder from super cheap or other items that are useful and cover the holes.
Garry
AnswerID: 362614
Reply By: Rockape - Friday, May 01, 2009 at 14:53
Andy,
you could remove the console and slightly countersink the holes with a larger drill bit. (turn it by hand so it doesn't bite in)then place electrical tape over the back of the holes and fill them from the front with plastic body filler.
Cut the filler down level to the surface of the console with a stanley knife blade and say about 240 then 800 grit paper, making sure not to damage the console surface.
Alternatively: If the console has a ripple effect you can place a piece of play doe on the surface of the console and then peel the doe off and transfer it over the holes the console surface, then fill the holes from the back, this will allow the filler to blend into the console surface.
Buy a can of vinly paint that is a close colour match to your console and paint, be sure to follow the instructions eg; thin light coats and low humidity.
The paint will last for many years no problems at all if applied properly.
AnswerID: 362615
Reply By: lozza - Friday, May 01, 2009 at 15:26
If looking for a proffessional job have a look through your yellow pages for a vinyl repair company in your area these guys are normally mobile.
AnswerID: 362625
Reply By: Member - DAZA (QLD) - Friday, May 01, 2009 at 16:44
One of my mates had the same problem with holes in the Dash ect, he borrowed some of my Black Roofing Silicon I use for Colorbond Roof Gutters ect, it did a reasonable job, it blended in very well.
Daza
AnswerID: 362640
Reply By: ACH - Friday, May 01, 2009 at 17:54
Thanks all for your most useful responses - much appreciated! Looks like I've got a few options to go with. Tks agn!!
Andy (ACH)
AnswerID: 362649
Reply By: DIO - Friday, May 01, 2009 at 18:31
If the holes are small screw size then you could do what I have done on plastic. Use clear Silicon over the hole, heap it slightly and let it dry. Once dry I use a razor blade to slice surplus Silicon off flush with the plastic. Because it's clear it picks up some of the surrounding colour of the plastic and helps to 'disguise' the patch.
AnswerID: 362657
