Hiclone Fuel Saver Question
Submitted: Saturday, May 02, 2009 at 16:08
cobber
Has anyone with a LC100 series V8 Petrol ever used the Hiclone
fuel saver device, if so dose it work, and what difference did you notice when using it, or is it a the old Snake-oil salesman con?
Reply By: Roughasguts - Saturday, May 02, 2009 at 16:13
No they don't work mate. But if you wan't to try something get a 12 volt bilge blower and hook that up, that will also swirl the
fuel air mix and maybe boost up the pressure a fraction.
362803
Reply By: Shaker - Saturday, May 02, 2009 at 16:22
If you try a
forum search for Hiclone, you will get 253 threads to peruse.
362804
Reply By: Ino - Saturday, May 02, 2009 at 16:39
Hmm... to paraphrase Homer Simpson: "The price of snake-oil will climb ever higher" :)
What's this one based on? Magic magnets? Swirly air? Unobtainium acting as catalyst for some never-heard of chemical reaction? :)
Ino!~
362807
Reply By: Axel [ the real one ] - Saturday, May 02, 2009 at 17:11
Go to local
shop , buy can of soft drink , drink till empty , go home and go to kitchen drawer and find scissors , cut can so have flat sheet of alloy , draw circle the diameter of air intake hose post air filter , cut tin so have circle ,, draw lines to create
windmill , cut tin and bend so have a minature
windmill , undo air intake hose post air filter and insert your minature
wind mill [ this part is critical and model specific ,its what you pay hiclone all the $$$ for] exactly 32.5 bees dick widths from the 3rd clamp after the oxygen sensor ,,,,,,, Just saved $300 odd , and quenched your thirst ,,,,
fuel saved over 1 year or 25,000klm will be just enough to buy another can of soft drink and you can repeat the exercise every year untill the actual "swirl " is so intense that vehicle wont use any
fuel at all except at start up,,,,,,,,,,
362813
Reply By: Bonz (Vic) - Thoughtfully- Saturday, May 02, 2009 at 17:30
I have two in the Patrol, not a 100 series cruiser, but I found that the car ran smoother and used less
fuel and also the turbo spooled in about 400rpm earlier.
Same deal with a mates Landrover Defender Extreme.
Many naysayers, MANY MANY naysayers, but Hiclone offer a money back guarantee which I checked out and didnt use.
Give it a try, and if it doesnt work take it back and get your money back.
A reputable 4WD mag did a controlled test and found some improvements also.
362819
Follow Up By: garrycol - Saturday, May 02, 2009 at 18:25
It failed all "scientific" testing by motoring authorities and some universities.
Garry
630481
Follow Up By: Member - JohnR (Vic) - Saturday, May 02, 2009 at 19:50
Bonz isn't 'scientific' Garry.
Bonz, you sure any 400 revs earlier wasn't the demands of the chip you put in? I can't see it would be some shaped plastic. There is an air spinner standard in the inlet of a LC to spin out dust to a catcher in the air cleaner.
Mine spools up quicker without the restriction. A saw dispensed with it neatly
630490
Follow Up By: fisho64 - Sunday, May 03, 2009 at 02:35
its the 'MACHINEGUN THEORY" of advertising, Bonz.
Spray enough bullets and one is bound to hit a target-somewhere. Maybe even two!!
Sorry
630520
Follow Up By: fisho64 - Sunday, May 03, 2009 at 02:37
"A reputable 4WD mag did a controlled test and found some improvements also."
I dont doubt it-but which one?
630521
Follow Up By: Bonz (Vic) - Thoughtfully- Sunday, May 03, 2009 at 07:55
John, It was fitted in Mortlake, driving over there, the turbo boost arrived around 1800rpm, driving home around 1400rpm, no chip about that, also noticed an immediate before and after imprivemnt at idle, which was noted and commented on by the other driver when I moved the Patrol so he could get his fitted.
Fisho, the test was done by 4x4 Australia. A vehicle run over a set course, fitted one Hiclone and ran the same course, then fitted a seconed and ran the same course. Improvements were noted and reported.
Garry, nice shot, did you hit the pot?
630523
Follow Up By: Axel [ the real one ] - Sunday, May 03, 2009 at 09:28
That air spinner is also present in 80 series LCs , cut ours out when fitting the snorkle , revs dropped due to less restriction ,
Got 2klm a lt better after fitting a Snorkle and removing the plastic spinner on our Rodeo ,,, spinning /swirling the intake air with an after market item like a Hiclone can do NOTHING as they are fitted before the TURBO which would negate any prior swirl..
630528
Reply By: GerryP - Saturday, May 02, 2009 at 17:57
Hi Cobber,
It really depends on the car methinks. What it is supposed to do is cause a swirling airflow, which in turn is supposed to give a better mix of
fuel and air.
This may
well work with carby systems and even some indirect
fuel injection systems where the air and
fuel mix prior to entering the manifold or cylinder. Even then, it would need to be placed in an optimum location.
However, with direct injection, as used by most newer vehicles, the
fuel is injected directly into the combustion chamber. Hence causing a swirl somewhere upstream will have no effect in mixing the
fuel air components.
Having said all that, I have seen them, but never used them. Some will claim benefits, but most will not.
As mentioned above, they do have a money back guarantee, so you only have some postage (and time) to lose.
Gerry
362826
Reply By: Time - Saturday, May 02, 2009 at 18:02
Go
here and read.
My favorite device is a magnet placed above the accelerator it cuts my
fuel consumption heaps, but to work I must be wearing my steel capped boots!!
362829
Follow Up By: Member No 1- Sunday, May 03, 2009 at 15:19
wont work on a lead foot...but
630586
Reply By: Mandrake - Saturday, May 02, 2009 at 18:20
I put one in my Jeep Cherokee 4.0L petrol and reduced "normal"
fuel consumption from 15 to 14 Litres / 100 kms - which is not the full %age they claim but it did "appear" to work .. I do monitor my
fuel costs very carefully so I know this is accurate .
The new Cherokee CRD is currently running at 10.5 Litres per 100 Kms which is fantastic !! and it only went up to 12 towing the POD
Mandrake
362832
Follow Up By: Member - Allan B (QLD) - Saturday, May 02, 2009 at 23:09
Pure magic ....... or is it an illusion?
630514
Follow Up By: Axel [ the real one ] - Sunday, May 03, 2009 at 09:18
So , some quick maths says that over 20,000 klm you may have used 95 lt less ,and the cost of the hiclone $$$$ compared to the cost of 95 lt of
fuel ???? Sure that your saving was not just a slight lifting of the right foot after sucumbing to the hiclone myth ???
630526
Follow Up By: Mandrake - Sunday, May 03, 2009 at 12:18
Just to put this in perspective - I log my fuel consumption every
tank full in a program I wrote as part of my personal accounts system ..
The Jeep pre Hicloning was using between 14.6 and 15.6 L/100Km .
over a 18 month period - after inserting the hiclone AND resetting the Jeeps engine computer - which makes it re-learn fuel/air mixture etc - the Lires /100 Km dropped by 1 - 1.5 Litres / 100Km -
I work and my main travelling is 90 Kms per day to and from work over the same boring old highways .. I do drive carefully but did not as far as I can tell "take my foot off " because I had the hiclone in ..
So I still maintain it "sortof" worked but not to the extent claimed by the manufacturer and I guess I didnt save much at all .
Yibbada Yibbada thats all folks !!
630555
Reply By: troopyman - Sunday, May 03, 2009 at 11:05
I dont have a hiclone but i drive around 90 on the highway and i am a lot less fatigued and use a lot less fuel . While driving around town i drive my corolla .
362918
Reply By: Member - Graham H (QLD) - Sunday, May 03, 2009 at 14:57
Working on their theory that they save 20% of fuel go the whole hog Fit 6 and tow a trailer to store the fuel it will spew out.
The use of a Hiclone is like when u go to the Doctor with a headache and he gives you some sugar pills, they dont work but cos u took them u feel better..
Car probably goes better cos your wallet is lighter
As stated Cruisers already have a similar thing in them and they actually breathe better without it. I took
mine out and fitted a 90mm polypipe thru the inner guard and it breathes even better.
ROFL
362954
Reply By: Maîneÿ . . .- Tuesday, May 05, 2009 at 22:03
garrycol posted:
"It failed all "scientific" testing by motoring authorities and some universities"
Garry,
can you post the link to the test your referring to, or nominate the "testing authorities and some universities" your referring to, in your post above, please ?
Mainey . . .
363419
Reply By: The Top End Explorer - Wednesday, May 06, 2009 at 00:16
I have unfortunately bought 2 of these useless devices.
Here in lies the challenge.
If any one out there, can with absolute 100% proof, prove that these useless devices can do what the advertising says, I will give $1000 to your favorite charity.
Cheers Steve.
363431
Follow Up By: Best Off Road - Wednesday, May 06, 2009 at 06:36
Steve,
Can you send me your email to
jimbest at bestoffroad dot net dot au
Something I want to discuss.
BTW, thanks for the note about "Why Warriors.....", Son and Girlfriend were over for lunch Sunday, I googled it for her and she was surprised she hadn't come across it and was most interested.
Jim.
631094
Reply By: Jarse - Friday, May 08, 2009 at 10:21
You can look here for info:
Fuel Saving - An Engineer's View
IMHO, installing one of these things actually
places a restriction in the intake ducting, so how can it be of benefit?
363823
