GU Power Loss Problem
Submitted: Tuesday, May 12, 2009 at 02:46
Member - Si (WA)
Hey all,
Now before everyone jumps down my throat, I have looked at the forums but thought I would put it out to everyone just in case I missed something.
The GU is doing what most have at some point or another. It is loosing power when I accelerate. It only started to do it yesterday on our return from
wedge island.
I went down to Nissan today (after loosing power most of the way) and brought a brand new MAF for $250. Fitted it in the car
park and drove it home with no problems at all (about 15kms) and actually found that it really did run better.
The wife took the car out tonight and said that it drove fine on her way out but when she went to come home (about 6hrs Later) it was back to square one.
I have had another look under the bonnet and found one of the clips for the air filter was off. Reconnected it with high hopes but just took it for another drive and what do ya know. Same thing is happening.
I have also given the accelerator solenoid a little tap and sprayed the contacters but no change noted. There seems to be lots of stuff about over boost and alike but I just don't seem to find things that match my problem as most of these seem to be talking about highway driving and not from take-off and the lower gears.
The only other thing that I thought I might mention is that Natrad serviced the radiator the other day, not that it probably has anything to do with the problem but thought it would be worth adding.
Helpful comments would be appreciated, sorry for the big spill.
Reply By: Member - Mick O (VIC) - Tuesday, May 12, 2009 at 06:53
I'm at a bit of a loss as usually the MAF is a big contributer to this type of situation.
Fuel? How new is the filter, perhaps a dirty load of diesel. Have you tried a search and/or post on the
NISSAN PATROL FORUM. Pretty knowledgeable bunch there. What did Nissan say?
Mick
364420
Reply By: Ozboc - Tuesday, May 12, 2009 at 07:23
As Mick o has said - i had this same prob with my 4.2 - ended up the little filter that is INSIDE the
fuel pump was partially blocked and starving the
fuel pump at revs
have you checked that ? just follow
fuel lines into the
fuel pump ( steel line) it has a 17 MM Bango style nut - filter is under
the nut - its in pretty deep so you may need to use something like a cotton tip to get it out ( make sure you dont loose the spring that holds the filter down
hope this helps
Boc
364421
Reply By: Member - John - Tuesday, May 12, 2009 at 07:46
Si, maybe the MAF is contaminated again, maybe worthwhile having a look............ Good luck. John
364422
Follow Up By: Member - Mick O (VIC) - Tuesday, May 12, 2009 at 10:26
Yeah, I remember a few people mentioning that they had oil contamination of the MAF from oil blowback. I can't quite recall but I think it may have have something to do with them removing/blocking the EGR hoses on the Patrol???? Food for thought.
Mick
632121
Reply By: Member - Malcolm (Townsville) - Tuesday, May 12, 2009 at 10:56
Si
When was the
fuel filter last changed? It may have a blockage.
Only replace with genuine Nissan Filter.
If you can, I would go back and get your old MAF sensor - keep it as a spare. These can be cleaned (with some success but not always) using CRC MAF Cleanser.
Malcolm
364450
Follow Up By: PATROL_ST_2004 - Tuesday, May 19, 2009 at 22:49
Hi Si
CRC MAF Cleanser is that like degreaser? How do you apply it? Do you spray, and wipe dry or spray and leave it? Can you use this to clean other the intercooler and other intake areas that have oil on them?
Cheers Rob
633453
Follow Up By: Member - Malcolm (Townsville) - Wednesday, May 20, 2009 at 00:25
Hi Rob
CRC MAF Cleaner is like an electical circuit board spray. Only use it for the MAF. Spray cans of degreaser from SC are $2.08 each and a couple of cans is all that is needed for the intake manifold (if you remove it), intercooler and hoses. Make sure you do them off the vehicle, wash thoroughly with
water and dry in the sun.
HTH
Malcolm
633465
Reply By: Member - Ron M (NSW) - Tuesday, May 12, 2009 at 15:24
What is MAF in inglish
364478
Follow Up By: Member - Oldplodder (QLD) - Tuesday, May 12, 2009 at 16:48
Mass Airflow Meter
It tells the computer how much air is coming into the engine, and the computer tells the
fuel pump to feed
fuel to suit the MAF, throttle setting and a few other sensors around the place.
632157
Follow Up By: Member - Malcolm (Townsville) - Tuesday, May 12, 2009 at 17:59
Mass Airflow Meter - Not exactly
MAF - Mass Air Flow SENSOR (it is not a meter)
Malcolm
632171
Follow Up By: Member - Oldplodder (QLD) - Wednesday, May 13, 2009 at 08:14
Thanks for the correction
Malcolm
632251
Reply By: Madfisher - Tuesday, May 12, 2009 at 20:59
Just a thought, check all conections to all sensors. When they fitted the radiator they may not have connected all sensors back up. or not properly.
Good luck Pete
364564
Reply By: Patrolman Pat - Tuesday, May 12, 2009 at 21:35
I had a problem with
mine some time ago, no power when driving uphills or trying to overtake. it was a split in a vacuum tube that went to the turbo, it drove fine 90% of the time just struggled under load.
364576
Reply By: Member - Si (WA) - Wednesday, May 13, 2009 at 00:49
Thanks for your comments, it is all appreciated. The problem is still there but only intermittently. After reading some of the comments made, the only other thing that I did on Saturday that was out of the normal was fill up with Gull bio diesel due to our location.
I generally avoid using bio fuels and I'm not saying that this is the cause but I will be interested to see if the problem is still present after I fill up next time.
Again, appreciate the helpful comments.
364598
Reply By: snow - Thursday, May 14, 2009 at 15:10
I can almost relate to your problem as I was beginning to think
mine was losing power also but then I realised that it really is just an underpowered and underbraked lump of a vehicle.
364836
