Pajero rear diff/wheel clicking
Submitted: Monday, May 18, 2009 at 16:39
mkberry
I have a 2003 NP MY04 Pajero GLX Wagon and recently went on a sandy track (
sand dunes). I noticed a rapid fire (machine gun type) clicking sound coming from the rear diff/wheel area when the
wheels began to spin. This was when in 4H and 2H so I am thinking that this may not necessarily be a 4WD issue but maybe a rear wheel/diff issue.
Has anyone experienced such......do I have a problem ???
Thanks, Mark
Reply By: Outbackswine - Monday, May 18, 2009 at 16:45
I would guess it is your traction control working that you heard.
365514
Reply By: Flywest - Monday, May 18, 2009 at 16:47
Could be a uni joint on the tailshaft on the way out maybe!
Or it might be the rear diff is LSD type.
A stone caught between rear breake disc and rotor.
Wheel trim not fitted correctly?,
Thats 4 possibilities I can think of.
365515
Reply By: MrBitchi (QLD) - Monday, May 18, 2009 at 17:28
These machines sometimes have an issue with dry splines on the rear CV joint/axle stub. Can be cured by taking
the nut off the stub axle, which allows you to pull the shaft slightly out of the hub and put some grease on it. Make sure it's properly torqued up when replaced.
See
The Pajero Club forum for more details.
365524
Reply By: Honky - Tuesday, May 19, 2009 at 09:56
