Central Locking Problem
Submitted: Wednesday, May 20, 2009 at 21:58
ThreadID: 69019 Views:2624 Replies:3 FollowUps:6
I left my 100 series in shed for 4 weeks and main battery died, now the remote key won't work the central locking. The locks work OK with key in door or switch just not the remote. Tried to reprogram by turning on/off 20 times etc. as per Toyota instructions, with new batteries in car and remote, but no luck. Any suggestions to rectify please?
Reply By: Member - Graham H (QLD) - Wednesday, May 20, 2009 at 22:54
You have to do the whole 20 times bit WITHIN the time stated for doing it
Cant remember the remote one but for my alarm its 9 times and must be done WITHIN like less than 9 seconds to make it go into programming mode.
If I remember rightly u have to open a door put key in and turn it on and off 20 times all within the 20 secs so u have to move fast.
Doesnt say that exactly so I went to Toyota and they showed me how to do it.
It chirps twice if you are in programming mode so u will know when u get it right
Sometimes if u have no programmed remotes its harder to do and toyota have to do it.
Best of luck
AnswerID: 365909
Follow Up By: vk1dx - Thursday, May 21, 2009 at 09:41
Is this how, what they refer to as a "clone" copy, will get programmed?
We bought the LC at Christmas and the seller claims he couldn't find the second key.
FollowupID: 633661
Reply By: Mandrake - Thursday, May 21, 2009 at 11:49
Dont forget to stand on your left leg with the right leg out of the passenger window - otherwise the Microwaves won't work ..
Isnt this business just SOOOO crazy -
The old Jeep had to have drivers door opened and flick key
on and off 5 times and then it would beep the error code
in question and usually it beeped 5 and 5 - which means
something not specified is in error !!
Good luck
Rgds
Mandrake
AnswerID: 365952
Follow Up By: vk1dx - Thursday, May 21, 2009 at 13:47
Thats shot me. My left leg was anputated just this morning.
FollowupID: 633710
Follow Up By: tim_c - Friday, May 22, 2009 at 21:01
Can you borrow one? just until you get your central locking sorted? :)
FollowupID: 633963
Follow Up By: vk1dx - Friday, May 22, 2009 at 21:10
Nah Rolf Harris needs it.
Thanks for the help getting that photo access sorted out.
I gather its fine now.
Cheers and have a good weekend.
FollowupID: 633965
Reply By: Member - Graham H (QLD) - Thursday, May 21, 2009 at 15:34
My 2005 TD has a seperate Remote and I bought one on Ebay and the local agent did it for me as i couldnt get it to work
Maybe it works with keys as well
Your local Mr Minit can do them also .
The little seperate remote is only $38 new from Toyota
AnswerID: 365967
Follow Up By: Horacehighroller - Thursday, May 21, 2009 at 20:30
One of our 100 series remotes is not working - could it be a battery issue or do I need to buy another remote?
FollowupID: 633760
Follow Up By: Member - Graham H (QLD) - Thursday, May 21, 2009 at 20:53
If its the little oval shaped one press the button and see if the little red light in the end away from the keyring groove comes on.
If so its not the battery.
I havent got my handbook but I think it tells you how to reprogram them in there.
Otherwise take it to a dealer and they may either do it , show you how , or tell you how to do it..
As I said a new one which will still need progamming is about $38.
FollowupID: 633772
