2004 Patrol 3.0Ltr Additional Power/Torque
Submitted: Thursday, May 21, 2009 at 23:39
ThreadID: 69055 Views:4219 Replies:6 FollowUps:5
Hi all
My enquiry is regarding affordable power up for my patrol, can you advise approximate cost and % of power increase and value for money or each option
1) Electronic Chip?
2) Big bore exhaust?
3) Snorkel?
4) LPG Gas?
I have 4 kids and tow an off road trailer.
Cheers and thanks in advance
Rob
Reply By: psproule - Friday, May 22, 2009 at 06:23
There is a lot of experience over at http://www.patrol4x4.com/forum/ including how to prevent yours from imploding as many have done, before you go hunting for more power.
Pat
AnswerID: 366076
Reply By: Olsen's 4WD Tours and Training - Friday, May 22, 2009 at 07:18
The gains to be made from the 3 litre are in my view not worth the expense or risk. There are many mods on the site mentioned above but most of them are to eliminate what the owners see as an unacceptable risk of a terminal engine failure.
AnswerID: 366079
Follow Up By: PATROL_ST_2004 - Friday, May 22, 2009 at 22:43
Hi Olsens
There seems to be plenty of people lining up to bag these motors, but none of them have offered a cause for these failures. Does anyone know what the weak point is and have Nissan offered an explanation? My patrol has 110k now, is there any common time frame when these failures are happening?
Cheers Rob
FollowupID: 633986
Follow Up By: Olsen's 4WD Tours and Training - Saturday, May 23, 2009 at 06:13
Plenty of people have offered reasons for the problems. There is enough detail on the Patrol forum mentioned above to keep you reading for days, and some fantastic solutions as well if you are handy with the tools.
FollowupID: 634008
Reply By: Rosss- Friday, May 22, 2009 at 07:26
6.2 lt Chev, roughly $20,000, 10 times the power, excellent value for money.
AnswerID: 366082
Reply By: Member - Graham H (QLD) - Friday, May 22, 2009 at 09:33
Prices are Chip $1300-$1600
Exhaust $1000- $1500
LPG $3000-$4000 minus rebate maybe
New engine 6 months later $8000- $15000
LOL
What the guys say is good advice
AnswerID: 366111
Follow Up By: Member - Graham H (QLD) - Friday, May 22, 2009 at 09:34
Snorkel $400 plus fitting
FollowupID: 633829
Follow Up By: Member - Redbakk (WA) - Friday, May 22, 2009 at 12:04
ROTFL Kiwi.....well said.
FollowupID: 633853
Reply By: kiwicol - Friday, May 22, 2009 at 19:20
None of the options your looking at will fix the lack of torque and power below the 2000rpm range of your donk
AnswerID: 366238
Follow Up By: Leroy - Saturday, May 23, 2009 at 08:05
A DTronic will help to a certain degree.
Leroy
FollowupID: 634013
Reply By: Member - Captain (WA) - Sunday, May 24, 2009 at 08:52
Hi Rob,
Asking for info about the GU 3.0TD Nissan brings a howl of disaster on this forum! While this motor does has more than its fair share of problems, a bunch of owners have pretty much worked out how to fix what Nissan should have done originally. Jump on to the Patrol forum and you will find a wealth of info there.
I used to own a 2003 GU and went thru the same questions you have. I had a snorkel fitted from new, but that was for water crossing insurance and not for power gains (won't help power IMHO).
I fitted a Dtronic and found it had a significant improvement. It certainly helped the bottom end power, especially the 900 - 1500rpm band. Less than 900rpm was still an issue (comparing to my old 1HZ 80 series).
After reading about the EGR and MAF issues, I blocked my EGR valve and never looked back. This significantly improved any turbo lag and I kept the vehicle like this for 5 years. I was very happy with the power and economy, and while the bottom end power wasn't quite what I would like, it was acceptable. I never had an issue with motor reliability (but do acknowledge others have).
Now others in my 4WD club have also added the big bore exhaust and LPG gas and they were of the opinion that if they had their time again they would do the following in this order;
1) EGR block (free)
2) Dtronic (~$500 2nd hand - $1400 new)
3) Big bore exhaust (~$1000).
Those who did the LPG gas wouldn't do it again, not only did they have issues with reliability (mainly installation related issues) but the need to fill with diesel then move to the LPG bowser meant they often didn't fill the LPG tank, (as well as availability in places). Also, the loss of the sub tank affects range.
I have a large pdf file (~7Mb) from the Patrol forum that has been complied from owners around the world for 3.0TD fixes. if you want a copy, get my email address from my profile below and let me know.
Captain
AnswerID: 366437
