Power Inverters
Submitted: Sunday, May 24, 2009 at 08:54
ThreadID: 69121 Views:2419 Replies:3 FollowUps:6
Looking through E-bay I see than many of the inverter advertised there are 220 or 230 volt. I understand that our voltage is 240v.
How efficient would these lower voltage inverter be
Reply By: Robin Miller - Sunday, May 24, 2009 at 09:37
Makes no difference Ray , all our devices are designed to work from about 200-260 vac
AnswerID: 366441
Reply By: _gmd_pps - Sunday, May 24, 2009 at 09:38
Generally not a problem for most devices in the contrary. Less voltage (within reason) is less power consumption.
I have a 1800W 230V Xantrex Pure Sine Wave and it works a charm.
Microwave, Espresso machine, Pc, Hair Dryer, Chargers etc etc work no problem.
have fun
gmd
AnswerID: 366442
Follow Up By: Member - Captain (WA) - Sunday, May 24, 2009 at 12:00
Hi gmd,
Less voltage is less power consumption...???
For a given load, less voltage means MORE Amps and the SAME power consumption! But agree that it wouldn't make a difference to overall equipment performance.
Captain
FollowupID: 634168
Follow Up By: oldtrack123 - Sunday, May 24, 2009 at 13:38
Hi Captain
Less voltage applied to a light bulb , heater of any sort, gives LESS amps & less power!!
Can you explain you come to your conclusion.??
FollowupID: 634186
Follow Up By: Member - Captain (WA) - Sunday, May 24, 2009 at 19:15
Yep, my bad :( ...was thinking inductive load only and not resistive load - posting too late at night with other things on my mind and didn't think about it (currently overseas in USA EST timezone). For a resistive load, less amps is certainly true :)
Captain
FollowupID: 634228
Reply By: Member - Captain (WA) - Sunday, May 24, 2009 at 19:13
Captain
AnswerID: 366518
Follow Up By: oldtrack123 - Sunday, May 24, 2009 at 20:45
Hi Captain
Inductive loads are no differant to resistive loads they both have to obey ohms law !!
Perhaps you can explain how an inductive load will draw more current @ a lower voltage.?
FollowupID: 634258
Follow Up By: Member - Captain (WA) - Sunday, May 24, 2009 at 23:12
I think I have confused the issue with some assumptions and my jetlag means a less than precise answer . First of all, I was thinking about the power draw from the 12v source to the inverter. If the inverter supplies a regulated 240V to the load, then the load on the inverter is constant - regardless of inductive or resistive. Now as the inverter is supplying a set load, if you lower the supplied DC voltage to the inverter then the amps must increase.
But as I have just realised, that is not the original question asked - it was about the AC voltage supplied being lower, not the DC. And yes, supply a lower inverted AC voltage to any load and it will draw less amps - will crawl back into bed and get some sleep after chastising myself for not reading the original post properly :)
Captain
FollowupID: 634295
Follow Up By: oldtrack123 - Monday, May 25, 2009 at 12:09
Hi Captain
No problem, easy enough to do.
WE are now in agreement ,with one qualification .
The inverter & many other devises can be designed to draw more amps with falling voltage ,BUT there is a limit @ which the input components are overloaded.
I posted because I have seen the statement that POWER is a constant so many times elsewhere that I have been amazed.
It has lead to some long & somewhat heated discussions, with many ,I believe, refusing to accept their view was wrong
Enjoy your trip
FollowupID: 634335
