Solar panels
Submitted: Friday, May 29, 2009 at 20:29
ThreadID: 69309 Views:2315 Replies:2 FollowUps:8
Just interested to know if solar panels can be wired in series.
Ian
Reply By: Member - joc45 (WA) - Friday, May 29, 2009 at 20:52
In a word, yes. The nominally-12v panels consist of many solar cells connected in series to give an output of about 22v with no load and this drops to actual battery voltage under load. But the number of cells are optimised for particular applications, ie, you wouldn't normally add more cells for a 12v system.
Rooftop systems are connected in series to supply about 300v to the inverter.
I assume that you intend charging a 24v system or higher.
Gerry
AnswerID: 367482
Follow Up By: Member - Ian F (WA) - Friday, May 29, 2009 at 21:18
Thanks Gerry,
I was interested in when we had a station 40 odd years back, when we had to rely on the old 32V power supply!!! If they had been available, apart from being very expensive, could 12V panels be wired in series. The snag would be the high amperage rate required.
Ian
FollowupID: 635145
Follow Up By: oldtrack123 - Friday, May 29, 2009 at 21:52
Member - Ian F (WA) posted:
Thanks Gerry,
Ian
Lifetime Member: My Profile Send Message
If you were asking about the possibity to series connect for higher voltages such as your old set up,yes this is the standard thing for domestic use .
Use high voltage low current .
THe voltage will be the sum ofthe solar panel output voltages the current will be the current rating of a single panel
They can also be connected in a series parallell combination to give higher currents. OF course must have appropriate control equipment & battery bank
FollowupID: 635150
Reply By: Member - Mike DID - Friday, May 29, 2009 at 21:07
The batteries will take twice as long to charge, compared with having the panels in parallel.
AnswerID: 367491
Follow Up By: Member - Mike DID - Friday, May 29, 2009 at 21:07
. . . . and you may blow up your regulator.
FollowupID: 635137
Follow Up By: _gmd_pps - Friday, May 29, 2009 at 22:34
only if you use crap hardware.
With a MPPT solar regulator this is not a problem within certain limits.
My Outback MPPT steps down from 32V to 12V without major loss
of wattage. If you have 48V input it does only 24V.
I run two 200W panels in parallel each of which does 32V output
and would not run efficient with any non MPPT controller.
have fun
gmd
FollowupID: 635160
Follow Up By: Boobook2 - Saturday, May 30, 2009 at 06:39
_gmd_pps , the Outback MPPT can be set to 12v output for up to 140V of solar input.
The output can be set to 12, 24, 36, 48 or 60. To get 32V you could set it to 36 then set that voltage to 32V.
They are a great controller hey? If I have to have a long cable run to the panels I run them in series to lower the voltage drop. If they are close I run them in parallel to minimise shading effects.
FollowupID: 635176
Follow Up By: _gmd_pps - Saturday, May 30, 2009 at 12:03
that is wrong .. you obviously do not own or have installed one
have fun
gmd
FollowupID: 635208
Follow Up By: Boobook2 - Saturday, May 30, 2009 at 12:53
_gmd_pps
It is correct. If you must know I have a MX60 and the manual specifically states:-
Page 63
" PV open circuit voltage 150 VDC Maximum (ETL Rating for UL1741
Standard); operational max = 141 VDC
temperature corrrected VOC"
and
"Voltage step down capability = Down convert from ANY PV array voltage within PV voc limits of 141 VDC to ANY battery system voltage.
Examples: 72V array to 24V; 60V array to 48V
You should check your facts before making blind assumptions. Perhaps you have a cheaper version.
FollowupID: 635216
Follow Up By: _gmd_pps - Saturday, May 30, 2009 at 21:16
well I do not remember the exact page
but maybe you check again
regards
gmd
FollowupID: 635303
