grill plate
Submitted: Sunday, May 31, 2009 at 19:26
Mav1
Have a 2 burner primus gas stove - there are cast iron 2or 3 burner plates for around $20 and also a thin aluminimum curved side plate with teflon coating for about $28 for the same.
Like the idea of the light weight of aluminium plate but being so thin might burn stuff. anybody used these ally ones or better off with heavy cast one
Reply By: Member - Graham H (QLD) - Sunday, May 31, 2009 at 20:40
Buy the heavy one it retains the heat better and gives a nice flavour to the steak.
367829
Reply By: Tenpounder - Monday, Jun 01, 2009 at 11:13
Hi. we have both: the aluminium one is cast, not pressed sheet, but it still warped, which gets in the way of cooking! So I'd go cast iron also.
Chris (SA)
367889
Reply By: AdrianLR (VIC) - Monday, Jun 01, 2009 at 13:15
Just to be different.........we have the Coleman pressed alluminium plate (not the cast version). Has worked
well for us and being light can be stored with less hassle in the space available. We have a cast iron version that sits on the fish burner on the home stove and it is certainly better for steaks. The aluminium one works more like a frypan. The only thing to watch is that the Coleman has a non-stick coating that seems to be good quality but must not be scratched by using metal utensils. Usually use ours for pancakes, french toast, toasted sandwiches and bacon & eggs. Steaks go on the open fire plate.
Adrian
367913
Reply By: Mav1 - Monday, Jun 01, 2009 at 14:27
Thanks,
might forgo the lightness this time and get a cast iron one
367925
Reply By: Member - peter C (VIC) - Monday, Jun 01, 2009 at 16:23
hillbilly
camping have a steel plate which should fit.check there web site or see them at any caravan/
camping show. their ph. no. is 0407540005. made of the same steel they use for their frypans peter
367958
