Friday, Jun 05, 2009 at 23:39
I prefer Manuals - but got an auto because the manual transmission option F truck wasn't available in Oz in the dually 4 door 4wd F truck.
Let me tell you theres heaps wrong with auto's, plain "they suck" is the right description.
Usually they can't stay cool enough to operate properly in our Oz conditions.
They are OK for the short distance city driver which most of our populace are these days.
Your transmission oil is the lifeblood of your auto trans & Australia gets damn hot on the road, The torque converter slip can add to heat soak buildup and short trans fluid life, and hence premature transmission failure.
This table shows why they aren't really suited to MOST Australian offroad conditions. (with cold location exceptions like Tassie and the Snowys etc).
This is where all the wet clutch wear crap ends up in your trans pan.
This is the type of in pan filter the auto transmissions come standard with - but MOST mechanocs don't have an inch pounds tprque wrench to be able to re do the pan bolts so never bother to replace them at service time.
One of the big problems, is when the torque converter lets go and shards of metal get pumped all thru the alloy valve bodies of the transmission scoring everything and destroying it.
IF the manufacturers had even half a clue they would put a filter in line between the transmission and the oil cooler to trap any blown up torque converter trash and keep it outta the valve bodies / gear change part of the box (the expensive part to fix / replace) but typically they don't.
The vehicles service manuals only suggest dropping / changing the trans oil via the trans pan sump at servoce - thus some 4 or 6 liters of old contaminated and burnt trans oil gets left in the system at service time - trapped within the torque converter and in the cooling lines and oil cooler itself.
That hardly "fixes" all the contaminants bye getting rid of it all!
Were they instead to drop the return line from the cooler into a bucket and connect the suction side on the trans which is under vacuum oil pump pressure from the trans, to a clear pipe inserted into a new drum of trans fluid and run the engine in drive with the hand brake on and
wheels chocked at idle, - with the suction side in a new drum of trans fluid and the outlet into the waste bucket - they could "exchange the entire fluid amount" by just watching until the old dark burnt and contaminated oil is expelled into the waste bucket and that line starts to run with clear fresh red new oil and then stop, re - connect the line and top off the box thru the dipstick until it reads full on the dipstick.
THAT way at least you get ALL NEW trans oil and get rid of the contaminants build up that destroys boxes just as bad as excess heat does.
A NEW box fitted to the F truck is over $20 grand yet a manual would probably last 20 years with maybe a new clutch every once in a while.
Autos CAN be made suitable for Australia but largely they arent.
To tow with
mine I made these modifications:-
Deep alloy transmission pan with cast alloy cooling fins
It holds an extra 3 quarts of trans fluid - to allow the aftermarket trans oil cooler I added, time to cool the oil properly.
Transmission Oil Temp Gauge so I can monitor it against that temp chart and keep it within low wear limits.
2 x 100 liter stainless steel
water tanks connected via a 12 V marine deckwash pump to garden mister sprayers behind the grill that cool the after market trans oil cooler down on hills etc when the trans oil temps climb, operated from a switch on the dash.
1 x inline trans oil filter to catch any
debris before it goes to the cooler and blocks it up and to stop any torque converter
debris in the event of a failure from being pumped thru all the delicate alloy valve bodies in the transmission leading to huge repair bills.
Its POSSIBLE to run a auto trans in Oz towing etc in our heat but don't expect longevity in the format that manufacturers supply them to us - unless you make special adaptations designed to overcome the designer / manufacturer shortcoomings you can expect transmission woes at some time in auto 4wd ownership.
Me - I'd far prefer a manaual but maufacturers in their wsdon don't give us those choices - then they wonder why they GM, the workds largest coprporation is filing chapter 11 bankruptcy proceedings despite a multi trillion $ govt bailout?
Simple - when you stop listening to your customers and don't give them the choice they want - then your days are numbered.
Toyota launched the 200 series with only auto trans - and this is the first ever year they have posted multi billion losses.
Doesn't take Einstein to work it out, does it?
368660
Follow Up By: get outmore - Saturday, Jun 06, 2009 at 09:24
Manuals were available in the 4 door dual cabs - i used to drive one for work - but gee wizz it had one hell of a tough clutch
636203
Follow Up By: _gmd_pps - Saturday, Jun 06, 2009 at 11:52
rofl..
transmission temp gauage is standard, additional oil filter in output line to cooler
is standard, extra larger oil cooler for heavy duty tow pack, etc etc .. with a decent auto
you paid the price for driving a Ford and the F350 did not even come with
decent trim or long bed in Australia. Just don't generalise about autos, you can
only talk about Ford autos can you ?
good luck
gmd
636211
Follow Up By: get outmore - Saturday, Jun 06, 2009 at 15:15
should also add the manuals werent without issues - When I first started there it was in the
shop for weeks somthing to do with clutchlines burning through as they ran against the turbo
636224
Follow Up By: Rolly - Sunday, Jun 07, 2009 at 13:21
"Toyota launched the 200 series with only auto trans - and this is the first ever year they have posted multi billion losses.
Doesn't take Einstein to work it out, does it?"
Haven't you been listening to the news for the last couple of years?
I doubt that the global recession has much to do with the gearbox in a 'Yota.
Sounds more like: "My mind's made up. Please don't confuse me with reality".
636321
