What's this noise after Troopy clutch replacement?
Submitted: Tuesday, Jun 09, 2009 at 18:12
Phoenix Owners Group
Posted this on another
forum but thought I'd throw it to a wider audience.
Had a new Daikin clutch installed in the Troopy ('02 TD, 115,000kms). The clutch now makes a noticeable chattering type noise when the pedal is out. Goes away when depressed. It's easily heard in the cabin.
Here's the noise recorded underneath very close to the gearbox after warm up. Starts with clutch in, then out, then in and so on...
clutch noise
Whole new clutch kit installed including throw out bearing and flywheel was machined. The clutch pedal has always been VERY heavy in this truck, it is VERY much lighter now to push in after replacement.
Been back to the mechanic (used before and Exploroz recommended) who had a listen with the steoscope and says the noise is 'gear rattle' and assures me it will do no harm.
Daikin say they're constantly being grilled about this chatter noise issue from 70, 80 and 100 series owners who have replaced clutches.
It's damn annoying and I still can't get used to it after 3wks. I'm also sure it would affect resale. Still wondering if I'd fitted OE whether it would be as bad.
Anyone had a similar thing?
Reply By: Atta Boy Luther - Tuesday, Jun 09, 2009 at 18:29
Norton says that the site you used youshare.com contains the virus VBS.Soraci , an exploit . cheers .
369167
Follow Up By: Phoenix Owners Group - Tuesday, Jun 09, 2009 at 21:49
Throw Norton out, I did, after it kept giving the false warnings.
636676
Reply By: Member - Pat (VIC) - Tuesday, Jun 09, 2009 at 18:39
Hi John
That sounds exactly like my 80 i replaced the clutch kit with an one and the noise was still there. I was told it was the gear box so i recond it and put a genuine clutch kit in it and it is still the same.It's been 3 years now all works
well but the noise is still there. Apparently the gearbox was ok.
I have learnt to live with it. (Its a diesel thing).
369171
Follow Up By: Member - Pat (VIC) - Tuesday, Jun 09, 2009 at 18:49
oops should of read it first. i replaced it with an after market one first then spent the big $$$ for nothing.
636643
Follow Up By: Phoenix Owners Group - Tuesday, Jun 09, 2009 at 21:53
thks Pat, that's makes me feel a bit better about it, I'm sure I'll get use to it.
636677
Reply By: Member - Greg T (ACT) - Tuesday, Jun 09, 2009 at 18:55
John,
it sounds like it is rubbing on something.
a quick guess would be the throw out bearing is rubbing on some uneven pressure plate fingers. which would also mean that the bearing isn't getting pushed back enough from the return spring (on the outside of the bell housing.
and when the clutch is pushed into the fingers they are running true due to the throw out bearing flattening them.
the lighter clutch feel would also be due to the fingers not being as strong as the OEM.
thats my first guess. any other thoughts?
369173
Follow Up By: wild dog - Tuesday, Jun 09, 2009 at 20:47
I agree with you Greg, some clutch slave cylinders don't let the clutch release bearing come completely free of the pressure plate.
This lets the bearing ride on the fingers with the clutch disengaged and can wobble until the pedal applies pressure.
With a new clutch there shouldn't be too much variation in the fingers though.
636663
Reply By: tim_c - Tuesday, Jun 09, 2009 at 19:12
Hi John, had something similar on my old 1982 Jackaroo, but usually after/during a long trip. It would gradually fade away from constant city use, and come back after a couple of hours on the highway?!
The transmission mechanic said it was gear rattle caused by
the springs in the clutch plate being too heavy. Between the clutch friction material (outer part of clutch plate) and the gearbox input shaft spline at the centre of the clutch plate, there are a series of springs that serve to absorb the uneveness caused by the power strokes of the engine (ie. the engine by it's nature doesn't supply constant power but only on combustion which means the power is produced in a series of 'bursts' , each 'burst' corresponding to the power stroke of one of the cylinders, each in turn (ie, for a 4 stroke 6 cyl, you will get 6 'bursts' for each 2 engine revolutions - think of a pushbike where you're only pushing down on the pedals - in that case (2 stroke!) you get two 'bursts' of power for each full revolution of the crankset). If these said springs are too stiff, you get gear rattle.
However, having listened to the recording, it's unusual to hear this sound without load on the gearbox/drivetrain (ie. when you are just idling, as recorded). I also wouldn't expect it to be *that* noticable. Generally, if you get noise when releasing the clutch in neutral it indicates that the bearing on the gearbox input shaft needs replacing.
BTW: the sound of that diesel engine idling is music to my ears (at least until you released the clutch!).
369178
Reply By: Member - Graham H (NSW) - Tuesday, Jun 09, 2009 at 19:34
A new clutch always gives a lighter pedal. Is due to more leverage applied by the diaphragm fingers on the pressure plate as the clutch plate is thicker when new
369190
Reply By: Richard Kovac - Tuesday, Jun 09, 2009 at 19:45
John.
Try checking the free play of the pedle and the throw out lever.
I listen to the WAV. and it is load, have you taken it to chutch and gearbox place for them to listen?
And by the way why was the clutch replaced? My 2003 Troopy has done 145000 km now and all is fine she weights in at 3.5 tonne all the time and we sometimes tow a caravan beit only small.
Richard
369193
Follow Up By: tim_c - Tuesday, Jun 09, 2009 at 20:13
I was wondering the same thing - my Jackaroo had 225,000km on it before the clutch was replaced, so far I've done another 170,000km on it and no
sign of worn clutch yet. I'd have thought the Troopies should have a heavier duty clutch in them than a Jackaroo?!
636659
Follow Up By: Phoenix Owners Group - Tuesday, Jun 09, 2009 at 22:18
Hi Richard,
Yes, I thought it was louder than it should be, a real clattering noise.
Mechanic checked the pedal freeplay and lever. I was thinking of getting a second opinion from a specialist clutch place.
The clutch was getting tired, we have towed a 3.2t van for 2yrs full time travelling and there have been times when it has had to go beyond the call of duty.
Troopy weighs about 3.3t and it's chipped so that may of added to the wear. I don't drive hard at all but did tend to slip the clutch when starting off on unexpected steep hills with the van and we all know how good those Landcruiser handbrakes are.
Saw the old clutch plate and it was on it's last legs, probably still would have worked fine for another xthousand kms. I now think I could've waited. I thought the recent notchyness in the gears was a
sign of clutch failure.
636680
Reply By: Member - Phil G (SA) - Tuesday, Jun 09, 2009 at 21:07
I take it the noise was not present prior to the clutch replacement. If this were the case, I'd think it rules out the gearbox as the source.
If the noise is coming from the release bearing contacting the diaphragm spring (Toyotas have no freeplay) then it should go away with very light pedal pressure (before the clutch is released), and is unlikely to happen with new parts.
An alternative cause is that the clutch centre was damaged during installation by having the weight of the gearbox hanging off it. If this were the case, the noise would not go away until the clutch is fully released.
369213
Follow Up By: Phoenix Owners Group - Tuesday, Jun 09, 2009 at 22:28
Hi Phil
Correct, no noise beforehand.
Noise only goes away when clutch is released, pedal fully depressed.
Daikin are suppose to be emailing me some blurb on it all, so will be interested to see what they reckon causes it.
BTW. Does your Ctek 7amp do the job charging your rear AGM when your away or would you go the 15amp one next time?
Just looking at getting a Ctek for the rear 100ahr fullriver.
636681
Follow Up By: Member - Phil G (SA) - Wednesday, Jun 10, 2009 at 08:54
I still find it hard to believe that a Daikin Clutch will cause that loud noise which wasn't there beforehand. Sounds too "crunchy" for gear rollover noise to me, and that noise is uncommon on the H150F box at 115,000k.
Its definitely not the noise from release bearing/ diaphragm spring contact.
My money is still on a damaged clutch plate centre. Worth asking them whether the clutch plate centre could have been damaged during installation of the heavy gearbox.
My CTek is used to maintain charge on my 100Ah AGM and starting batteries at home. I never use it away. I use an in-line ammeter and it does exactly what is described in the book - puts a constant 7amps into the battery and then current tapers at 14.4 or 14.7V until fully charged.
If I were to use a charger in a caravan
park, I'd go for 15 or 25 amps, so there's enough to power the fridge and lights while still recharging the batteries.
636716
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Jun 10, 2009 at 08:04
Sounds like the gearbox rollover clatter to me, my old 80 series diesel did it too. I had the cluth and gearbox replaced/ rebuilt and it was still there.
Maybe they moved or removed some sound proofing around the transmission tunnel and this is allowing you to hear it more.
Basically it sounds normal to me.
Listen to any manual truck (that isn't fitted with a roadranger gearbox) and it will sound the same as you push the clutch in and out.
Dave
369258
Reply By: Rod W - Wednesday, Jun 10, 2009 at 09:16
In 1998 a brought a 1993 troopy. In the test drive there was a bit of shudder/chatter when changing gears, the owner said its cause your not use of the vehicle, he also said that it recently had the gearbox overhauled by Bigrock Toyota. I brought the vehicle. After awhile an oil leak developed at the rear of the motor so I put it in to have fixed which meant the gearbox etc had to come out. The mechanic rung me and asked who put the clutch in I told him and asked why, he replied that they put it in back to front. I've never had a problem since... touch wood.
369265
Follow Up By: Member - Phil G (SA) - Wednesday, Jun 10, 2009 at 22:58
Putting a clutch plate in backwards would certainly cause some noise. I did that once - 35 years ago on a Corolla and the clutch wouldn't release properly because the clutch plate centre was pushed against the flywheel.
636850
