Xantrex 40amp charger users.
Submitted: Saturday, Jun 13, 2009 at 10:29
RovingOz (QLD)
Does anyone run this charger of a HONDA 1kva successfully or does it need the 2kva ?
Image Could Not Be Found
Trying to avoid lugging a 2kva around.
Thks
Reply By: Tenpounder (SA) - Saturday, Jun 13, 2009 at 10:46
According to a couple of websites, the unit delivers a peak of 40amps at around 15.5v, or 620w. They also claim around 80% efficiency, implying a 240v input at around 780w, which would be a bit much as a continuous rating for the 1 kw genny. However, one would seriously doubt the unit would be running at 40w output continuously. Does this help? (or why use experience, when you can use theory?)
369779
Follow Up By: Member - Andrew (QLD) - Saturday, Jun 13, 2009 at 13:50
why would this a bit much for a 900w continuous rated genny?
Andrew
637218
Follow Up By: Tenpounder (SA) - Saturday, Jun 13, 2009 at 14:36
Hi Andrew. As you say, the Honda EU10i has continuous rating of 900va, not 1000, and so 800 is 89% of the max continuous. A bigger margin seems sensible to me, and I am sure others have also indicated on this site that they'd prefer to see these little units running at perhaps 75% to be safe.
The saving grace is that the charger would not sit on 40A too long.
637221
Follow Up By: Member - Andrew (QLD) - Saturday, Jun 13, 2009 at 14:47
Thanks Chris. Whilst i recognise that the 40A drops off on these units (my xantrex 10A is hardly ever on the 10A setting), i would thought having 75% as a safe margin rather low....750w would be ok i would think. (we run the kawasaki models so i'm not sure of the honda variants).
Andrew
637227
Reply By: Robin Miller - Saturday, Jun 13, 2009 at 12:39
I don't John , however I would expect it to work properly from the honda.
369793
Reply By: Geoff (Newcastle, NSW) - Saturday, Jun 13, 2009 at 15:55
John,
My experience with my own EU10i Honda tells me this would be an excellent combination.
The 40A Xantrex will keep a good solid load on the little Honda virtually eliminating the biggest killer of small generators, underloading.
I use a 30A 3-Stage charger on my own EU10i and it does it with ease, even with the eco throttle on and a couple of lights connected to the 240V side as
Geoff
| Geoff,
369820
Reply By: paulnsw - Saturday, Jun 13, 2009 at 17:39
I run the Xantrex Truecharge 40 on the Yamaha EF1000is with no issue.
The Yamaha is a superior unit to the Honda EU10i
Yamaha has steel cylinder sleeve and Honda is aluminum and dont last
No
fuel tap on the Honda EU10 is the pits and they leak
fuel all the time.
Compare how much better the
Yamaha EF1000is here
Using both at work we will no longer buy Honda
369830
