Boiled water or distilled
Submitted: Monday, Jun 15, 2009 at 18:30
Member - Kroozer (WA)
Hi again folks, i remember reading an article a few weeks ago but cant find it anywhere, about just topping up batteries with boiled tap
water. I just checked battery level, and yes i need a top up, but wanna know if i have been doing my batteries damage all these years by using tap
water. Article said that boiling doesnt take out the minerals or something like that and it does the battery no good. Never brought distilled
water before ever, so how much is it worth for piece of mind? Or is tap
water fine to keep using as long as its boiled?
Reply By: tim_c - Monday, Jun 15, 2009 at 18:42
As long as you don't live in
Adelaide the tap
water should be fine. I've heard (from reliable sources) that many of the battery manufacturers just use tap
water for the initial fill so it makes it a bit of a joke 'topping them up' with distilled!
370143
Reply By: Member - Phil B (WA) - Monday, Jun 15, 2009 at 18:59
Hi Kroozer
Sorry to contradict you Tim C but I would not use boiled
water because the minerals are still present and if you boil the
water long it with be even more concentrated.
I would also strongly suggest you don't use tap
water. Distilled/ de mineralised
water doesn't cost much especially if you buy it in Coles or Woolies - 4 litres for about $3 or $4. I use it in my radiator as
370150
Follow Up By: Member - Ian H (NSW) - Monday, Jun 15, 2009 at 19:17
Yep, wot he said.
637483
Follow Up By: Member - Timbo - Monday, Jun 15, 2009 at 19:40
No prob Phil (I don't pretend to have the final undisputable word!) but I agree, boiling won't remove the minerals. Usually tap
water doesn't have too much in the way of minerals anyway though (it's safe to drink in Oz) - I certainly would recommend using
bore water tho'
637490
Follow Up By: Michael ( Moss Vale NSW) - Monday, Jun 15, 2009 at 19:57
Bore water would be the worst to use, depending on its make up Timbo!! Michael
637495
Follow Up By: Member - Timbo - Monday, Jun 15, 2009 at 20:30
Oops, I meant to say "I certainly wouldN'T recommend using
bore water tho'", as Michael pointed out, it would be the worst to use!
What a slip up...
637504
Follow Up By: Serendipity of Mandurah (WA) - Tuesday, Jun 16, 2009 at 09:06
I would not use tap
water around
Perth as most of it is
bore water. I have heard from
water authority workers the
water is near black with minerals when it comes to the surface and then they filter it a bit. Still tastes like it has too much minerals. Many people in the northern suburbs are installing house under sink filter systems as the
water is just too hard to drink.
There is no way I would put this in my battery. I would not even put it in my radiator. I would not even put it in my coffee. Dogs and cats probably develop calcium kidney stones from it.
David
637569
Reply By: Member - Kroozer (WA) - Monday, Jun 15, 2009 at 19:52
Okie dokie, looks like its distilled
water then. Havent had a non maintenance free battery for a while so wasnt sure if it was considered the norm to use tap
water still. Oh
well, i always got good lives out of my batteries, but probably without a doubt would of gotten more by looking after them better.
370169
Reply By: Member - Toyocrusa (NSW) - Monday, Jun 15, 2009 at 19:56
Hi all. Just wondering,would filtered tap
water be suitable after going through the two stage unit type filter.Thanks,Bob.
370173
Follow Up By: Member - Captain (WA) - Monday, Jun 15, 2009 at 21:54
Hi Bob,
Filtering only removes the particulates, it does not remove the dissolved solids. The main solid of concern is calcium as it reacts with the sulphuric acid to form calcium sulphate (gypsum). Once this is formed and coats the plates, your batteries are cactus!
Captain
637513
Follow Up By: Member - Tony S (WA) - Tuesday, Jun 16, 2009 at 01:46
Truly CACTUS.
Bite the bullet and get a reputable gel.
Yea. I know they cost.
In the long run they are better off road
Tony7
637541
Reply By: Roughasguts - Monday, Jun 15, 2009 at 20:29
I guess if your really desperate, you could catch the condensation
water from your Airconditioning and use that.
370182
Follow Up By: Shaver - Tuesday, Jun 16, 2009 at 08:04
Just curious, but wouldn't
water condensing over the evaporator be contaminated with a metal ?
637555
Follow Up By: Roughasguts - Tuesday, Jun 16, 2009 at 17:07
Yeah I see your point! but then distilling
water or boiling through a copper pipe would do the same. Unless they distill the
water in glass.
637674
Reply By: TerraFirma - Tuesday, Jun 16, 2009 at 11:31
I have topped up
mine with rain
water before as I didn't have distilled. The real issue is and I'm guilty as
well, is that if you check your batteries before you travel and do the topping up with distilled then, there would be no issue.
370287
Reply By: MrBitchi (QLD) - Tuesday, Jun 16, 2009 at 12:32
Rainwater is fine. Best de-mineralised
water you can get.
370300
Follow Up By: austastar - Tuesday, Jun 16, 2009 at 13:58
Yep! Rain
water every time - keep a couple of juice bottles of it in the garage, and the wife collects and uses it in the steam iron.
637624
