Location of GPS
Submitted: Wednesday, Jun 17, 2009 at 07:30
Member - Howard T (QLD)
Hi All
Am having trouble reading street names on my GPS with the unit located on my windscreen.(old age)
Has anyone come up with an idea of locating the unit any closer to the driver? Am thinking a Pod on the dash if there is such a thing or some other invention on the dash somewhere.
Vehicle is a 120 Series Prado.
Thanks in anticipation.
Howard
Reply By: navaraman - Wednesday, Jun 17, 2009 at 07:39
If your eyesight is that bad maybe you shouldn't be driving.
370448
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Jun 17, 2009 at 07:59
I think he was after some positve advice. I dont think negative advice will help him. Michael
637761
Follow Up By: Member No 1- Wednesday, Jun 17, 2009 at 08:17
generally,
when one gets older the close smaller printed word becomes harder to read until you actually should have to wear glasses to read ...but Your VISION for distances one needs to have for driving Is As GOOD as the younger person in the next car.
Ever noticed some people holding a book or newspaper, or even their watch, back further than the norm ..say at arms length...its so they can focus on (the near) small print...this gets worse as time goes on till you finally stop being vain and go get +1 (or +1.5 or what ever) glasses from the CHEAPY STORES. Vision of being able to focus at further distances is not impaired at first.. it is just the nearness of the smaller items that become so hard to focus upon, .....but as you become older further distances MAY become more of a problem, like street signs and then cars etc etc.....another reason why it is that when we get to a certain age one must have a medical clearance to get a licence....
i'm guessing your still
young enough and dont need glasses.......however, i can tell you, that you will suffer this impairment sooner or later
637768
Follow Up By: Bob of KAOS - Wednesday, Jun 17, 2009 at 09:34
Member No 1
Its called aged related presbyopia. From WP : "Presbyopia (Greek word "presbys" (p??sß??), meaning "old man" or "elder", with Latin root "-opia", meaning "eye"[1]) describes the condition where the eye exhibits a progressively diminished ability to focus on near objects with age. Presbyopia's exact mechanisms are not known with certainty, however, the research evidence most strongly supports a loss of elasticity of the crystalline lens, although changes in the lens's curvature from continual growth and loss of power of the ciliary muscles (the muscles that bend and straighten the lens) have also been postulated as its cause.
Similar to
grey hair and wrinkles, presbyopia is a symptom caused by the natural course of aging; the direct translation of the condition's name is "elder eye"[1]. The first symptoms (described below) are usually first noticed between the ages of 40-50. The ability to focus on near objects declines throughout life, from an accommodation of about 20 dioptres (ability to focus at 50 mm away) in a child to 10 dioptres at 25 (100 mm) and leveling off at 0.5 to 1 dioptre at age 60 (ability to focus down to 1-2 meters only)."
My visual change is due to my age (55), unlike Navaraman, who is likely to suffer vision loss through other causes :-)
637788
Follow Up By: Member No 1- Wednesday, Jun 17, 2009 at 10:05
geez Bob...your too technical for me....... but I suffer from it too..hahaha
637795
Reply By: Member - TonBon (NSW) - Wednesday, Jun 17, 2009 at 07:44
Not sure how the Prado dash board is set out, but on my D-Max the instrument panel has the large speedo in the middle. Because the GPS speed is more accurate, i have the GPS mounted behind the steering wheel, in front of the speedo. I can still see all other instruments and the GPS is at a good viewing distance and angle. GPS unit is a Garmin Nuvi 265 with 4.3 inch screen. The only drawback is you cant use the GPS unit whilst driving, however, you shouldn't be doing that anyway, same law applies for GPS units as it does for mobile phones.
Tony
370449
Reply By: Member - Stephen L (Clare SA) - Wednesday, Jun 17, 2009 at 07:47
Howard
I have a Garmin Nuvi 5000 with 5.2" screen, very easy to read, and located as you can see. My vehicle is also a 120 Prado.
Image Could Not Be FoundImage Could Not Be Found
370450
Reply By: Michael ( Moss Vale NSW) - Wednesday, Jun 17, 2009 at 07:55
Garmin have a stick on pad that comes with the unit. It is for dash mount for states that do not allow anything to be stuck to the windscreen.. That would bring it a little closer to your vision.. It is a disc with double sided tape on one side and high gloss the other side that allows suction to the GPS holder.. Hope this helps.. Michael
370452
Follow Up By: MP - Wednesday, Jun 17, 2009 at 08:03
That's what I use. I also stick a peaked cap over it so from outside the car it just looks like a hat sitting on the dash & acts like a sun visor when using it.
Mark
637766
Reply By: Bob of KAOS - Wednesday, Jun 17, 2009 at 09:26
Howard
I too need to wear glasses to see detail on the GPS.
If the GPS is mounted high in your field of vision you need to swap between glasses for the GPS and unaided vision for the road. Not really satisfactory, contributes to fatigue, and increases time the eyes are off the road.
With the GPS mounted low I can wear "look over" glasses, enabling me to glance down at the GPS and then back to the road without moving my head or moving the glasses.
I removed the suction cup that came with the GPS holder and glued it to the dash so it is just beyond my left hand when I hold the wheel in the 10 to 2 position. In this location, passengers can see the GPS too.
370467
Reply By: Shaker - Wednesday, Jun 17, 2009 at 09:55
What make is the GPS?
Garmin have a "Bean Bag Mount" that can be postioned on the dash.
370472
Reply By: Member - Graham H (QLD) - Wednesday, Jun 17, 2009 at 11:13
Easiest solution is to use a GPS with spoken street names and you just listen and it tells you when and where to turn.
After all you should be watching where you are going not looking at a screen whist in traffic.
What make and model are you using.
My TOMTOM has this feature but was not turned on by default.
370479
Reply By: tim_c - Wednesday, Jun 17, 2009 at 11:35
I stick my GPS to the top of the windscreen just next to the centre mirror - I put it there to shade it from the sun and also so that the circle left by the suction cup isn't visible to would-be thiefs looking for evidence of a GPS in the car (the suction cup mark is in the tinted band of the windscreen & not visible from outside). Because of the slope of the windscreen, it would also be closer to your eyes for viewing.
370482
