Pintle Coupling
Submitted: Tuesday, Sep 02, 2003 at 22:47
Member - John
G'day all, does anybody know if the 3 tonne pintle hook with ball is legal in Australia? It is listed in the Caravan Accessories book, but before I go and ask them direct, thought I would get some advice from here.Any body used/using one? Wishing to replace towbar with this, seems to be a good way of saving lots of weight. Any help greatly appreciated.
Reply By: Hughesy - Wednesday, Sep 03, 2003 at 06:36
John I've got one on my cruiser and can't find anything wrong with em'. They are a lot more heavily constructed than a normal towball setup. Also gives a good place to snatch from.
29955
Follow Up By: Member - John - Thursday, Sep 04, 2003 at 10:20
Thanks, but are they legal to tow with?
21146
Follow Up By: Hughesy - Thursday, Sep 04, 2003 at 17:50
As far as I know they are John, most small to medium trucks use them. You would have to ring up the appropriate road authority in your state and check (the bird on the phone probably won't know what your on about) or go to a road worthy place and ask.
Hughesy
21177
Reply By: Willie - Wednesday, Sep 03, 2003 at 12:21
I bought an ex army trailer once with the ring and pintle. Very strong construction but I found the clunking noise it made when travelling quite annoying.
Willie
Never a dull moment
29982
Follow Up By: Member - John - Thursday, Sep 04, 2003 at 10:22
Thanks for the reply, I thought that using the ring would be very noisy, but the one I am looking at has a ball also, so you can use that instead of the ring.
21147
Reply By: Member - Peter- Friday, Sep 05, 2003 at 20:39
I've towed a Cub supamatic all over Oz using a pintle and ring coupling for over 20 years with absolutely no problems. Towed all sorts of stuff as
well as snatching stuck vehicles off the back of the trailer.
You can get rid of the clunk by twisting a rubber plumbers ring (used to seal the joins on old earthenware pipes) into a figure 8 and placing it over the opening bit.
I have always had a swivelling ring on the trailer and a fixed pintle hook.
I have recently fitted the pintle with a ball built into it on the Humvee (needed a ball as
well with no towbar) and it tends to wear the ring a bit due to the hardened ball I suspect but will probably stop when they match better.
I can send a pic of the ring if you want.
30229
Follow Up By: Member - John - Saturday, Sep 06, 2003 at 10:14
Peter, thanks for the reply, yes a photo would be good. Thanks jlsulli@net-tech.com.au
21300
