nissan 2.7 deisel missing
Submitted: Wednesday, Sep 03, 2003 at 10:21
losa
2.7 nissan navra missing and blowing smoke above 2000 revs -changed air &
fuel filters- blown out
fuel lines & bled
fuel system - still missing- blowing smoke & down on power- can any kind nissan owner help -
Reply By: Stewy - Wednesday, Sep 03, 2003 at 11:05
Time to have your
fuel injection system overhauled, both pump and injectors need full treatment, do it now before you damage your motor, I had similar problem in an 80 series on a trip and blew the number 6 pot because my injectors were stuffed and giving poor
fuel mix, it is worth it and cheaper than a rebuild!!!!!!
29972
Reply By: howesy - Wednesday, Sep 03, 2003 at 18:40
Have you gat a turbo on it?
What colur is the smoke?
Take it to have the pump and pressures and injectors checked and also check cam lobes and put some nulon in in case a valve is sticking slightly. It could even be too little clearance. there are a thousand and one possibilities but one thing for sure is that you don't F**k with a diesel. get it to someone and sorted before you have a major repair bill.
30020
Reply By: losa - Wednesday, Sep 03, 2003 at 23:57
thanks to you guys that offered solutions for my problem- i have just had the problem sorted it turned out to be a small filter blocked where the
fuel enters the injection pump - one for the memory bank - once again thanks guys
regards losa
30062
