Landcruiser 80
Submitted: Sunday, Jun 21, 2009 at 08:28
Ray
Hi. I have a 1993 80 ser. Landcruiser. While travelling very slow
(up to 15kph) I get a clunk in the transmission as though something has wound up and the released. Is this a common occurrence with this model and can it be overcome. It is a AWD model
Reply By: Oldsquizzy (Kununurra) - Sunday, Jun 21, 2009 at 08:49
Check for play in your front drive plates and shafts ...The splines wear and produce a loud noise.
371123
Reply By: Member - G N (VIC) - Sunday, Jun 21, 2009 at 11:00
mate had similar, thoough diff was buggered but turned out splines on diff end of front axle were totaled.
$2000 for bits from toyota and $400 from after market comes complete with axles which many mechanics use around town without anyone realiosing anyhow.
regards'GN
371144
Reply By: Gazal Champion - Sunday, Jun 21, 2009 at 11:05
Hi Ray, The constant velocity joints and splines in the front axles often give similar noises. Backlash, a clunking noise heard when backing off the accelerator sometimes, is also a problem sometimes in these AWDs.
You say your problem is in the transmission though from which I presume you are saying gearbox. It therefore might be in the centre diff. This is as helpful as I can be given the info supplied.
Regards, Bruce.
371145
Reply By: Member - Brian A (QLD) - Sunday, Jun 21, 2009 at 16:04
Hi Ray
I have an 80 series, auto, petrol model and I get the same problem when basically 'Free Wheeling' down our street which has a slight downwards slope towards the 'T'
junction at the base of the '
Hill'.
Mine has been doing it since new some 15 years ago. Personally I do not see it as a problem! I find that if it becomes annoying a slight increase on the throttle cures it.
Brian
371185
