Sunday, Jul 05, 2009 at 18:20
I have a 1HZ 4.2 and been in the same situation and still am!
Before i turboed the motor, it was doing that very same thing on the long hills.
then i put in the turbo and denco intercooler and does the same thing on ths same
hill just the same. So nothing to do with the turbo.
Changed to the PWR aluminium radiator high performance made no difference.
Added 2 and a half tubes of viscus fluid to fan, Still the same! then i purchased a new fan hub thinking i didnt do the job right, and still no better.
had the head off and nothing cracked or damaged there!. i lifted the bonnet at the brackets half an inch to alow more air flow. still nothing!
Stuffed if i know, my best mate has the same cruiser as
mine and he has an after market turbo with a denco and his never moves past half way on the tem guage, even pulling a 2 ton trailer flat out up the same
hill! he even has his boost on 14 psi and
fuel wound up. he said he has got the EGT around the 500 deg c
mine only gets to 470 max.
Im with you mate, but if you do find some information about sorting this out do let me know!
Chris
640405
